Old 01-13-2009, 06:52 PM   #8431
Suspended
Originally Posted by Team STPN View Post
So let me get this right, same set up, spool, 6 degree caster and full long link are the changes?? Wow I must be a DA but what do you mean by a full long rear link???
it means inside hole on shock tower link..and outside hole on rear hub...and the same on front end..makes the link longer
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 01-13-2009, 08:20 PM   #8432
carbon madness's Avatar
Originally Posted by mike nelson View Post
I went with the Manutech plate, mine came marked at 182g , I drilled out the holes in the center of the plate to balance the car. I also used a dremel and made little sections for the battery to set down inside to help keep the battery locked in. I know you can get it from Manutech or Stormer also carries them, just look under Manutech at stormer hobbies. Hope this helps.
That weight has the rised side on top to help hold the battery in place left to right, right?
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 01-13-2009, 10:06 PM   #8433
mike nelson's Avatar
yep, has sides that stick up
TEAM ASSOCIATED--NOVAK--J-CONCEPTS--REEDY--LEISURE HOURS HOBBIES--FUTABA--COMPETITION ELECTRONICS--UP-GRADE RC--TRAKPOWER--
mike nelson is offline   Reply With Quote
Old 01-14-2009, 12:39 AM   #8434
Broady Racing's Avatar
Send a message via MSN to Broady Racing
Default Diff problem
Hey guys, We have just rebuilt our diffs and one in particular slips and loosens straight away. We do all the normal clean and lube , tighten and loosen 1/8 etc etc . Has anyone had a dodgy diff and if so what part caused it . We are running mod motors . Thanks in advance
Broady Racing is offline   Reply With Quote
Old 01-14-2009, 06:23 AM   #8435
Originally Posted by steve eaves View Post
Josh,thanks for the help,needed more than 2 packs of practice,car was getting close had a tire unglue in the main hope to race with you again soon.
No problem Steve.
Out on the hub and in on the tower...........it really helped it get through the turns.
Josh Hohnstein is offline   Reply With Quote
Old 01-14-2009, 07:03 AM   #8436
Could someone tell me what side of car you tight differentiel on tc5
i know its not clear ,i am a french man lolll, i rebuild my differentiel
and now what side it goes ?? it is important ??
tx Stef
revolver1 is offline   Reply With Quote
Old 01-14-2009, 10:00 AM   #8437
speedsterblade's Avatar
Originally Posted by mikel33 View Post
http://www.ppdbillet.com/ - link to the plate I used. I don't use the side plate, that's too much weight.
http://www.corallyusa.com/istar.asp?a=6&id=SRC79867!SRC - battery tray
Thank!
This one seems just what I was looking for. Appears it has the pack hangin off the chassis some which is just what I was looking for. Trying to move some of the existing weight to balance it out more and I won'thave to add as much lead.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 01-14-2009, 10:42 AM   #8438
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by speedsterblade View Post
Thank!
The SRC batter holder is great. The one thing you have to keep in mind is it raises the batter strap quite a bit. It made it so my SMC 4000 packs need something on top to hold it on. I switched to SMC 5000 packs and they fit perfectly.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 01-14-2009, 11:35 AM   #8439
Sweet. 5k is what i'm running in it.
You can also use a long screw through the blue thumb 'bolt' and makes them easier to use, allen driver instead of your fingers. I did this on my b44 with the long rear shock/chassis screws off my t4. ..but the whole metric switch you'll prolly need the thumb bolt & screw from an Standard AE kit and fresh battery posts... the threads seem close but not the same when I tried this on the tc5 thumb bolts.
www.nashrcracer.com
Old 01-14-2009, 11:46 AM   #8440
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
what is the corally part made out of?
Associated B44.3/Viper/RevTech
Associated B5M/Hobbywing/Orion
S & N's Trackside
AssocRacer is offline   Reply With Quote
Old 01-14-2009, 12:56 PM   #8441
mikel33's Avatar
Trader Rating: 2 (75%+)
I think its aluminum but I won't swear to it, some kind of metal. The battery strap posts connect to the tray and the tray is screwed into the chassis using the holes where the battery strap posts were. There are several mounting holes to adjust how far inboard or outboard the battery is.
Michael Larson.
Village Idiot Racing
mikel33 is offline   Reply With Quote
Old 01-14-2009, 01:15 PM   #8442
Send a message via MSN to Adim_X
Couple questions:
Do you consider this lipo holder better than the diggity designs unit?
How far do you thread your shock ends on?
Adam
Adim_X is offline   Reply With Quote
Old 01-14-2009, 01:23 PM   #8443
cutjo3's Avatar
Originally Posted by Adim_X View Post
Couple questions:
I have both and I can say that I like the Specialized RC tray better. It allows a few more mounting options than the Diggity one. Like someone else already mentioned you can move the battery out further to the edge of the chassis to help compensate for the reduced weight of the lipo.
One thing to note is that the Orion Platinum 4800mah packs are a little more narrow than some of the newer packs on the market. Unlike the Diggity brace you have no option on the cutout based on battery dimensions. Diggity offers a 'wide' option for the newer packs.
Current Rides
MGT 8.0
Old school RC10
Old School Losi JRx Pro
Previous Rides: B44, RC18MT, RDX PHI, FT RC18T, RC8, TC5(2), RC8T :(
cutjo3 is offline   Reply With Quote
Old 01-14-2009, 01:37 PM   #8444
jag88's Avatar
Rick Hohwart, any plans on some new cvds and axles that actually fit the bearings ?
Current axles have to small a dia. and therefore create slop.
Thanks.
jag88 is offline   Reply With Quote
Old 01-14-2009, 02:15 PM   #8445
fatbear's Avatar
Send a message via Yahoo to fatbear
Thanks.
And even new hubs with bigger bearings so they can take a little more load.
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
AKA www.raceaka.com
Ryper Hobbies www.ryperhobbies.com.au
fatbear is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
