Old 01-06-2009, 10:06 AM   #8326
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Team STPN View Post
Josh, on your Carpet set up you show 1 mm of Hex spacing. Does this mean to shim between the bearing and wheel hex axle pin or shim between the rim and wheel hex?? Do you still need the shim currently between the hex axle pin and bearing??? If so do you include that shim to the total of 1 mm?? Last question what part number do you use for sims to space this out 1 mm?? This seems like a lot of questions on something that may be simple but I want to get this right for this week end race, thanks..
Will you be helping to take down the xray klan in 13.5 this weekend???? AE needs to fly out a rubber tire hot shot to help out. This weekend should be a ton of fun. Good luck to you and see you Saturday.
STLNLST is offline   Reply With Quote
Old 01-06-2009, 01:12 PM   #8327
jag88's Avatar
Anybody try the rubber o-rings on the top deck of the 'R' version on carpet ?
Results ?
Thanks.
jag88 is offline   Reply With Quote
Old 01-06-2009, 01:14 PM   #8328
carbon madness's Avatar
Originally Posted by bmcallister View Post
I have looked at the set-ups on associated's site. Which do you guys recommend for foam tires, 17.5, medium traction. New to touring, so also looking for something pretty easy to drive.
thanks
I am currently running this set-up from the novak race last year
http://www.petitrc.com/reglages/asso...ce20080106.htm But I am going to try Keven's latest set-up in a few weeks (I hope)
Originally Posted by padailey View Post
I was basically asking the same question and it sounds like Keven Hebert's from Cleveland that was posted a few pages back. Go back maybe 5 pages and look for it posted. A few questions about the setup have followed so just read the last few pages and you should have your answer.
That setup should work great, although if I understand it right it is easy to drive with it, but at the same time is very reactive.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 01-06-2009, 02:42 PM   #8329
Gone Racin's Avatar
Default o-rings
Hello, my son runs his R on carpet here in Florida, We ran this weekend at Minn reg warm up race for the birds` put on Mike Boylan. TQ and Won the 10.5 class with a 30.509 running all 8 o-rings, on asplath hes runs the same setup on Jaco blues. Ron H,
Gone Racin is offline   Reply With Quote
Old 01-06-2009, 03:12 PM   #8330
speedsterblade's Avatar
my kit has arrived! no questions yet. lol. bye-bye! tc4 ..first belt car, I wont know how to drive w/o all the old torque steer of the tc4!
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 01-06-2009, 03:31 PM   #8331
PartTime's Avatar
Originally Posted by hippie View Post
Im looking at getting a tc5 but have a quick couple of ?. Is there a big difference between the FTTC5 & the TC5r ?. Im asking because amain has the original TC5 on sale for $279.00 while the TC5r is $350.00 . Will the FTTC5 work good on carpet with rubber tires ?.
The new cars come with alum diffs and bigger belt tentioners. I have the old car with alum diffs and dont do to bad with it. Thick chassis and top plate. Seems to work just as well on carpet as ashfalt.
Good luck.
DK
PartTime is offline   Reply With Quote
Old 01-06-2009, 04:27 PM   #8332
mr crum's Avatar
Send a message via Yahoo to mr crum
Good luck.
DK
i like the thicker chassis my self ive had the ft tc5 since it came out and i love it i have upgraded the diffs other than that its a stock ft tc5
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 01-06-2009, 05:26 PM   #8333
GeorgePravata's Avatar
Trader Rating: 104 (100%+)
Any help with gearing Trinity 17.5 or 13.5 with rubber tires Spur and pin. size would be great..
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 01-06-2009, 06:34 PM   #8334
mr crum's Avatar
13.5 48 pitch 72 spur / 31 pinion =4.64 on a 130 x 60 track rubber tire asphalt
TEAM B.R. RACING
Old 01-06-2009, 06:43 PM   #8335
Jerry P's Avatar
Trader Rating: 44 (100%+)
George: i'm starting with 44/96 for rubber tire 13.5. similar roll out to what i ran on my losi.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 01-06-2009, 10:36 PM   #8336
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
What o-rings are you guys using for the top deck?
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 01-06-2009, 10:37 PM   #8337
trdsupra88's Avatar
What o-rings are you guys using for the top deck? Do you torque the screws as much as you would without the o-rings?
I cut my own hair ☆
Old 01-07-2009, 08:10 AM   #8338
Track size?
speedo?
Duo or Pulse?
Josh Hohnstein is offline   Reply With Quote
Old 01-07-2009, 09:15 AM   #8339
Scottmisfits's Avatar
Shock o-rings are used. Tighten them down until the orings are basically flush with the side of the cone washer.
Scottmisfits is offline   Reply With Quote
Old 01-07-2009, 10:14 AM   #8340
trdsupra88's Avatar
Which cone washer are you talking about? Any pics of them installed?
I cut my own hair ☆
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
