Old 01-05-2009, 03:36 PM   #8296
Truck_Buster's Avatar
Trader Rating: 63 (98%+)
I heard people have problems with tightning the diff and the nut stripping out. Is this a common problem?
Losi 8ight 2.0
Truck_Buster is offline   Reply With Quote
Old 01-05-2009, 03:52 PM   #8297
mr crum's Avatar
Send a message via Yahoo to mr crum
i had that problem when i first built my kit but i found very quickly that u dont have to tighten it that tight and a little secret use a t nut for the t3 it works alot better
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 01-05-2009, 03:56 PM   #8298
Ok thanks I want to purchase this car but I just wanted to know if this was a big problem.
Losi 8ight 2.0
Old 01-05-2009, 05:00 PM   #8299
Airflow's Avatar
Finished building my TC5R. Bought a DNA2 body and cut it... I was disappointed to see the TC5 bumper is too long and hitting the body.
So what Protoform shell can I use that will fit the tc5r without modifying the foam bumper?
Airflow is offline   Reply With Quote
Old 01-05-2009, 05:06 PM   #8300
Jim S's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to Jim S
the R-9 might but speed 6 works
Jim S is offline   Reply With Quote
Old 01-05-2009, 05:07 PM   #8301
Trader Rating: 23 (100%+)
Try the parma ulitmate bumper. I currently run one with the r-9 body and fits perfect. You can always sand the original bumper and little to make it fit.
bmcallister is offline   Reply With Quote
Old 01-05-2009, 05:07 PM   #8302
xtrememadness's Avatar
Send a message via AIM to xtrememadness
you want a mazda speed 6 or regular 6 the only 2 bodies you will ever need
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 01-05-2009, 05:13 PM   #8303
hey josh, what axle nuts do you use with the hex spacers. i cant seem to find any that will allow the nylon in the lock nut to reach the axle. the setup is working awesome for me but my wheels keep loosening up all the time thanx
Old 01-05-2009, 05:18 PM   #8304
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
if it's feasible mount the nuts backward, nylon first
ALBERTO is offline   Reply With Quote
Old 01-05-2009, 05:25 PM   #8305
thanx alberto but i cant find any without a flange
Old 01-05-2009, 05:39 PM   #8306
mr crum's Avatar
alberto has the right idea i used to do it back in the tc3 days and the t3 with certain wheels on the t3 u have to put them on that way hope it helps
TEAM B.R. RACING
Old 01-05-2009, 06:39 PM   #8307
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
Originally Posted by rearviewmirror View Post
I'm not too experienced w/ road racing, but I'm looking at a Factory Team TC5. They're $280 on Amain right now and I think there is a $25 coupon until the 9th.
What is the dimensions of the battery tray? What's the biggest Lipo battery you can run? I'm thinking of a castle creation setup, in there, perhaps something in the 6xxx kV range.
Anyone?
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 01-05-2009, 07:14 PM   #8308
Lebatek's Avatar
Send a message via AIM to Lebatek
Delete double post...
John Lebak
Sponsored by: Team Associated, Reedy, Airtronics, LRP, and Mugen
Lebatek is offline   Reply With Quote
Old 01-05-2009, 07:33 PM   #8309
Lebatek's Avatar
PADAILEY:
I have been running a setup nearly identical to what Kevin Hebert posted a couple pages back on this thread for the TC5 on carpet with foam. It is easy to drive and very responsive (a unique combination) but can be toned down a bit by slightly raising the front ride height to nearly equal ride heights or even a hair higher in front (less than .25mm higher). It will all depend on how agressive you want it, and how much traction your surface will have. I'm guessing that after a couple of hours of solid running, it will increase from wherever it is now.
We typically run magenta compound foams all around with full saucing in the rear and anywhere from 1/8 to 1/3 of the inside fronts. I prefer Paragon Ground Effects. Another way to tone down the agressiveness is to take a step back in coupounds and go back to double-pink rears and double-pink orange fronts. Many of our locals prefer the easier-to-drive feel of them...
The key thing with the TC5 will be to copy the EXACT setup. Missing one or two small setup items (even by a mm or two) can make a HUGE difference in performance. I help out many racers locally who say they have a certain setup on the car, and after some observation, in reality they have "some" of that setup on their car. Make sure to put the exact setup on and have someone double check the car. Camber is also very crucial on the TC5, so be sure to start at 3 in the rear, 2 up front...use a setup station if possible. The Protoform R9 is the best body I have found for foam.
Good luck!
REARVIEWMIRROR:
Reedy's original 5000mah LiPo batteries are approximately 46mm X 139mm X 24mm and they can be used with the stock battery strap. However, many of us are running the Diggity Design carbon fiber tray along with the PD Billet stainless steel weight that fit into the existing battery slots when running LiPo.
John Lebak
Old 01-05-2009, 07:44 PM   #8310
padailey's Avatar
Originally Posted by Lebatek View Post
PADAILEY:
Good luck!
Thanks... its going to be quite a challenge! We certainly don't want to fight an ill handling car for 4 hours. That's following a 2.4 hour mini enduro in the morning!
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
