Old 01-04-2009, 10:38 PM   #8281
Red face
I don't know my right from my left. I had my steering knuckles backwards. That's why I had so much droop travel. I was thinking there was something not right with that. What a stupido. Thanks
giovanni is offline   Reply With Quote
Old 01-04-2009, 11:00 PM   #8282
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
Originally Posted by zake540 View Post
How do you check the "2mm over" droop settings on Josh H. setup. What's the equivelent of that setting on the drop gauge I got with the kit?
TIA
I just put the same setup on my car (thanks for posting, it's a GREAT setup!) and the droop measured 4mm on an integy gauge for me.
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 01-05-2009, 05:58 AM   #8283
Scottmisfits's Avatar
TIA
It's easy to measure. Set your ride height. Say you want your ride height at 5mm. You want 2m over or 2mm downtravel. Place the car at 7mm after you have adjusted the ride height to 5mm. Don't adjust the springs to 7mm though, just put the car on the ride height gauge at that. Now adjust the droop screws so that the tires "just" touch the ground. That's 2mm over or 2mm downtravel.
Scottmisfits is offline   Reply With Quote
Old 01-05-2009, 08:54 AM   #8284
Hi guys
Did you have vidéo of HOW TO tc5 ,am newbe with on-road tc5
tx Steph
revolver1 is offline   Reply With Quote
Old 01-05-2009, 09:09 AM   #8285
speedsterblade's Avatar
Originally Posted by revolver1 View Post
Hi guys
tx Steph
How to what? Build it? or more of a tuning guide?
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 01-05-2009, 09:37 AM   #8286
tuning guide vidéo ya
Old 01-05-2009, 11:52 AM   #8287
jag88's Avatar
In your setup you use 2-b for the rear link position. How do you get the ball cup to fit inside the wheel ?
Thanks.
jag88 is offline   Reply With Quote
Old 01-05-2009, 11:56 AM   #8288
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
Thanks.
I had to take a dremel and shave off part of the top of the ball cup to get it to fit under the wheel.
Associated B44.3/Viper/RevTech
Associated B5M/Hobbywing/Orion
S & N's Trackside
AssocRacer is offline   Reply With Quote
Old 01-05-2009, 12:07 PM   #8289
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Thanks.
I believe Josh is using the Losi JRX-S captured rod ends. They expose the top of the ball stud so you don't have to pop it off to make a change and provides clearance for inside the wheel.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-05-2009, 12:38 PM   #8290
padailey's Avatar
Ok guys I need help finding a setup.. here's what I'm going to be doing.
We have a 4 hour enduro coming up that our team is going to be running 13.5 or 17.5 foam. Three guys running one car for 4 hours. Track is 98X48 (Hobbyplex in Omaha) and don't know what the layout will be but usually for enduros they are not too technical. Traction should be low/medium. I know there is a bunch out there on the Associated site but we run mostly rubber tire here so haven't tried foam setups on my TC5 (original version). I've got a couple weeks to tweak it to our styles but could someone point me to a good easy to drive setup for us to start with. I suppose we would be considered intermediate drivers if that helps.
Thanks in advance.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 01-05-2009, 03:06 PM   #8291
Yes.....I do run the losi ball cups that Kraig posted............But don't worry even though they are a losi part they don't make the car any slower!!
Josh Hohnstein is offline   Reply With Quote
Old 01-05-2009, 03:09 PM   #8292
AssocRacer's Avatar
Do those pop on like ball cups or do you have to use a screw and washer to retain them?
S & N's Trackside
Old 01-05-2009, 03:11 PM   #8293
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
I'm not too experienced w/ road racing, but I'm looking at a Factory Team TC5. They're $280 on Amain right now and I think there is a $25 coupon until the 9th.
What is the dimensions of the battery tray? What's the biggest Lipo battery you can run? I'm thinking of a castle creation setup, in there, perhaps something in the 6xxx kV range.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 01-05-2009, 03:12 PM   #8294
They are just like a regular ball cup.........just open on the top.
Old 01-05-2009, 03:34 PM   #8295
Trader Rating: 23 (100%+)
I have looked at the set-ups on associated's site. Which do you guys recommend for foam tires, 17.5, medium traction. New to touring, so also looking for something pretty easy to drive.
thanks
bmcallister is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
