Old 12-23-2008, 12:39 PM   #8176
fatbear's Avatar
Send a message via Yahoo to fatbear
Originally Posted by Keven H View Post
Hi Guys,
I Know I am a little late but I just want to post the setup i used in Cleveland at the US indoor champs to TQ and win 13.5. I basicaly used the same Setup in modified very minor changes.
Front :
ride height : 4.2
camber : 2 deg
6 deg caster,
+- 1/2 toe out
no hex spacing
Hex spacing 2mm on both front and rear mount
numer 3 arm mount front rear
wheelbase 1 mm
Steering 2B
3mm under ball stud
25 pound spring ( copper )
number 1 piston with 50 oil
outside on arm
number 3 on tower (shock location)
Camber link 3
diff height mid low
Black front roll bar
Rear :
ride height 4.4
3 deg camber
toe 1 degree hub
1/2mm hex spacing
2mm wheelbase
Diff height full low
Shock:
60 oil,
losi 54 pistons
outside on arm
Blue spring
number 2 arm mount front and rear
1mm on front arm mount, 2.5mm on rear arm mount.
#2 on tower for shock location
camber link 5B with 3mm under ball stud
R9F body.
Let me know if you hve any question !!
Keven
Hi Keven,
Congats on your efforts at Cleveland.
I have a question. I see you are now using #1 AE pistons on the front shocks and #54 Losi pistons on the rear. Why have you gone to pistons with such big holes?
Where do the #54 pistons rate compared to the AE pistons?
And also you use 60Wt oil in the rear and 50Wt in the front, why is the back got heavier oil than the front.
And lastly what were the changes for your mod setup?
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 12-23-2008, 12:40 PM   #8177
carbon madness's Avatar
Hi Guys,
Front :
ride height : 4.2
camber : 2 deg
6 deg caster,
+- 1/2 toe out
no hex spacing
wheelbase 1 mm
Steering 2B
3mm under ball stud
outside on arm
Camber link 3
diff height mid low
Rear :
ride height 4.4
3 deg camber
toe 1 degree hub
1/2mm hex spacing
2mm wheelbase
Shock:
60 oil,
losi 54 pistons
outside on arm
Blue spring
R9F body.
Keven
What tires were you running, and with how much dope? Also how did the car drive, was it twichy, did it cut though the turns, or was it easy to drive?
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 12-23-2008, 01:23 PM   #8178
quietstorm76's Avatar
Originally Posted by AssocRacer View Post
Thanks. I'm actually not very happy with the steering in my car right now with the DNA-2 body. I'm gonna try the R9 and see if that helps out as well.
You shouldn't have steering issues with the R9-R unless your setup is way off. I've never tried a DNA but I heard it was too "stuck" on the TC5 but like I said I've never ran one. Try a Mazda Speed 6 it has lots of steering compared to the standard Mazda6.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 12-23-2008, 02:25 PM   #8179
Fatbear - Thank you !! the reason why I ran such big pistons is I think when you run a very big hole piston with heavier oil, it carries more corner speed. Also, the reason why the front oil is thinner is because it is outside on the front A arm and its only 2 hole piston instead of 3. The #1 piston would be close to a 54 tho.
For mod, I ran 4 mm instead of 3 on the rear ball stud, I ran a silver ball stud front, and I ran different tires.
Carbon madness- I ran Parma Coral tires in 13.5 and sauced about 1/3 to half of the front tires. For clubracing and when the bite is lower, I would run Magenta which are just a bit stiffer. When you run a softer tires, it makes the car easier to drive and not as twitchy but on low bite magenta are better.
The car was very easy to drive and it finishes the corner very good !
Hope you guys can try it out soon and give feedback.
2 weeks after Cleveland I went to Fastcats for the Holliday challenge and I made a few changes to that setup !!! I went inside on front arm and ran 80 oil instead of 50 and leaned the shock 1 hole so it is something you guys can try but it make the car steer a little more and might be too much.
Keven
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 12-23-2008, 03:09 PM   #8180
fatbear's Avatar
Keven
Keven, were the arm mounts in the A or B position?
And also what were your droop settings?
Old 12-23-2008, 03:47 PM   #8181
AdrianM's Avatar
Originally Posted by Takt View Post
I'm running the latest Josh H setup ...
On Saturday, I was running a track with a high speed sweeper to the left and the car wanted to spin out during the sweeper and then the significant hairpin at the end of sweeper.
On Sunday, I was at a different track with a high speed sweeper to the right and a 180 hairpin at the end ... and the car wanted to spin out at the sweeper and did on the hairpin.
Any suggestions on what is goofy with my car? Going to rebuild my diff this week ... but anything else to look at?
Try increasing the rear toe about .5 to 1 deg per side. A lot of time guys run less rear toe thinking it will increase speed but all it really does is make the car handle funny. Sometimes 3 deg of toe per side is perfectly normal.
You can also try standing up the rear shocks one hole on the rear tower.
Adrian Martinez
Old 12-23-2008, 04:49 PM   #8182
mr crum's Avatar
Send a message via Yahoo to mr crum
i heard as much as 3.5 per side i run 3.25 and use aluminum shims and get longer screws if u go more than 2 degrees gota get them longer screw
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 12-23-2008, 05:20 PM   #8183
EastCoasterVa's Avatar
What is the difference between a TC5 and and TC5F? My LHS has a TC5 and was told there is minimal difference. I plan on running on carpet but may run parking lot this spring. Is it worth it to pay a bit more on the TC5F?
EastCoasterVa is offline   Reply With Quote
Old 12-23-2008, 06:58 PM   #8184
Trader Rating: 20 (100%+)
I am pretty sure the plastic pieces on the original TC5s are the same as the TC5F. They have the same upper and lower chassis.
The TC5F will come with aluminum outdrives for the diffs and a slipper spool for up front.
You can pull up the manual at RC10.com and do a quick comparison of the parts list between the two.
In my opinion I would not buy the TC5F if you already have the TC5.
GTSSTANG is offline   Reply With Quote
Old 12-23-2008, 07:01 PM   #8185
xtrememadness's Avatar
Send a message via AIM to xtrememadness
the tc5f comes with all the hard parts
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 12-23-2008, 07:34 PM   #8186
mr crum's Avatar
the ft tc5 comes with plastic diffs and has all soft parts so to answer ur question yes it is worth it price the extras and i will come out to b more after u buy upgraded diff for the ft tc5 vs tc5r or f
TEAM B.R. RACING
Old 12-23-2008, 08:27 PM   #8187
Thanks,
That is what I was looking for. I will have the LHS order the TC5F for me. What type of LiPo should I get. I have a Novak GTB 17.5.
Old 12-23-2008, 08:34 PM   #8188
mr crum's Avatar
Thanks,
i run core 5000mah u can get them from schumacher usa good pack or the reedy 5000mah
TEAM B.R. RACING
Old 12-23-2008, 08:37 PM   #8189
rcterp's Avatar
Trader Rating: 35 (100%+)
Thanks,
SMC - the 28C batteries are the best on the market. Danny did just come out with 40+C batteries but I don't know anyone who has tried them.
rcterp is offline   Reply With Quote
Old 12-24-2008, 04:38 AM   #8190
Suspended
from the e-mail kevin sent me he is using the a mounts..that setup is a change of what he ran at iic..so if something is missing..combine the two setups...with the latter being the most updated...i havent ran the new inboard shock positions in the front..but it is very easy to drive...you wont be dissapointed...thx again kevin...see you guys at snowbirds...
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
