Old 12-22-2008, 07:08 PM   #8161
Associated's customer service is top notch.
If there is an issue with parts they will take care of you.
http://rc10.com/misc/warranty.repairs.htm
Josh Hohnstein is offline   Reply With Quote
Old 12-22-2008, 07:11 PM   #8162
Trader Rating: 18 (100%+)
Problem solved.
I just used a 9/64 drill bit and counter sunk the holes by hand.. I just spun the drill bit with my fingers and it quickly cut a small bevel/countersunk into the bulk head screw holes to match the ones in the motor mount. Worked perfectly..
DO NOT USE a power drill or you will mess it up... ONLY use your fingers to twist the drill bit..
Last edited by GTSSTANG; 12-23-2008 at 07:44 AM. Reason: ended up using a 9/64 bit instead of 1/8...
GTSSTANG is offline   Reply With Quote
Old 12-22-2008, 08:23 PM   #8163
Default New Northern California Track, Chico
I am trying to get some more TC5 drivers to try out this new track in Chico, California--about 2 hours north of Sacramento.
Indoor Carpet. Racing every other Saturday, see link for schedule and directions:
http://www.amainhobbies.com/racetrack.php
Thanks,
Alan
Al S is offline   Reply With Quote
Old 12-22-2008, 09:25 PM   #8164
Default TC5 Foam Tires Setup
Hi Guys,
I Know I am a little late but I just want to post the setup i used in Cleveland at the US indoor champs to TQ and win 13.5. I basicaly used the same Setup in modified very minor changes.
Front :
ride height : 4.2
camber : 2 deg
6 deg caster,
+- 1/2 toe out
no hex spacing
Hex spacing 2mm on both front and rear mount
numer 3 arm mount front rear
wheelbase 1 mm
Steering 2B
3mm under ball stud
25 pound spring ( copper )
number 1 piston with 50 oil
outside on arm
number 3 on tower (shock location)
Camber link 3
diff height mid low
Black front roll bar
Rear :
ride height 4.4
3 deg camber
toe 1 degree hub
1/2mm hex spacing
2mm wheelbase
Diff height full low
Shock:
60 oil,
losi 54 pistons
outside on arm
Blue spring
number 2 arm mount front and rear
1mm on front arm mount, 2.5mm on rear arm mount.
#2 on tower for shock location
camber link 5B with 3mm under ball stud
R9F body.
Let me know if you hve any question !!
Keven
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 12-23-2008, 06:11 AM   #8165
Takt's Avatar
Trader Rating: 15 (100%+)
I'm running the latest Josh H setup ...
On Saturday, I was running a track with a high speed sweeper to the left and the car wanted to spin out during the sweeper and then the significant hairpin at the end of sweeper.
On Sunday, I was at a different track with a high speed sweeper to the right and a 180 hairpin at the end ... and the car wanted to spin out at the sweeper and did on the hairpin.
Any suggestions on what is goofy with my car? Going to rebuild my diff this week ... but anything else to look at?
Takt is offline   Reply With Quote
Old 12-23-2008, 07:13 AM   #8166
"IF" there is nothing wrong with the car (bad diff, shock with no oil, bent hinge pin) I would try a black front sway bar.
That sounds odd for that setup......have you had that problem before or did it just start this week?
Old 12-23-2008, 08:53 AM   #8167
TCRacer101's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to TCRacer101
Originally Posted by Lazer Guy View Post
It will depend on the layout Drew..... I'll know more as it gets closer to opening day, the first layout is going to have lots of turns and short straits.
Ok, thanks. Let me guess, you race at Lazer too?
Last year, I was in the stock TC class. In the A-Main, Nate was running a TC5 with a Novak 13.5 BL system and he got first. I think there were quite a few TC5's including me. Top 3 were running 13.5 I think.. Results
Stock TC A-Main
Place-----Name--------Laps-----Average MPH--survived?
1. Nathan Pray----19 laps-----16.86----------yes
2. Scott Brennen--18 laps-----16.68----------yes
3. Nick Sava------18 laps-----16.22----------yes
4. John Sigmund---16 laps----14.58----------yes
5. Barb Bury-------16 laps ---14.52----------yes
6. Drew Schmidt --15 laps----14.51----------yes
7. Tom Schmidt--- 11 laps----10.14----------yes
8. Frank Johnson-- 6 laps-----14.30----------no; broke
9. Mike Norton------DNS-------------------- no; DNS
My dad, Tom, his TC4's motor was running BADLY.
I was using a LRP runner digital; now replaced with a Tekin G11 Pro, Trinity Co27 pro tweaked, SMC 3800 side x side pack, and Hitec Lynx radio system; now replaced with a Spektrum DX2.0 system.
Drew
E-Revo Brushless.....4s lipo/Coming SOON: HPI savage flux HP
Electric Monster Truck Association (EMTA)~~ electricmonster.webs.com
TCRacer101 is offline   Reply With Quote
Old 12-23-2008, 09:17 AM   #8168
Takt's Avatar
Thanks ... I tried to go stiffer spring in front, and didn't help ... maybe I'll go back down and try the sway bar.
My other thought was maybe a body rub, but I went higher on the body and still happened. Will go through the car the next couple days to try and figure out.
Thanks for the help.
Old 12-23-2008, 09:29 AM   #8169
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
tim what body are you using???
josh call me
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 12-23-2008, 09:59 AM   #8170
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
Anybody try the R9-R body yet?
Associated B44.3/Viper/RevTech
Associated B5M/Hobbywing/Orion
S & N's Trackside
AssocRacer is offline   Reply With Quote
Old 12-23-2008, 10:13 AM   #8171
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
I have seen a few guys running them locally. The only one it seems to work well for is a driver using an Xray. Quietstorm has used one on his TC5, but he is faster with a standard PF Mazda 6. It seems to me that it would be a decently fast body but the setup required to make it work is a lot different due to the massive amounts of steering it provides.
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 12-23-2008, 10:53 AM   #8172
quietstorm76's Avatar
Like K Spec said I'm running the body.It was aggressive at first but once I found a setup that felt right I was .3 slower on my fast lap. But my average was very good (9.8 fast lap/10.0 average over 6 min.) with the R9-R body. I'm going to try something different this weekend and see what it does. I will stay with the R9-R if I can get my laps times back down. I think it can be faster through the corners than my Mazda 6.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 12-23-2008, 11:03 AM   #8173
Originally Posted by Keven H View Post
Hi Guys,
Thanks Keven!
Old 12-23-2008, 11:11 AM   #8174
AssocRacer's Avatar
Thanks. I'm actually not very happy with the steering in my car right now with the DNA-2 body. I'm gonna try the R9 and see if that helps out as well.
S & N's Trackside
Old 12-23-2008, 11:51 AM   #8175
islander360's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to islander360
What kind of steering are you looking for? Also if you post your setup it helps.
JConcepts - BMI Racing - Speed Passion - KustomRCGraphics - Core R/C
islander360 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
