Old 12-17-2008, 03:17 AM   #8086
PartTime's Avatar
Originally Posted by Airflow View Post
Hi, Im getting TC5R this week and will be setting it up for high speed runs
on cemented street surface. Just want to know the things I need to increase
its durability.
Found in this thread that I have to use longer screws on the suspension
arm holders... so what is the part number for the long screw?
You can buy or make a bumper that covers most of the front suspention under the foam bumper. Does wonders to protect the car.
Take your hinge pin holder and bolt it to the bulkhead. Measure it and thats how long your screw should be.
hope this helps
DK
PartTime is offline   Reply With Quote
Old 12-17-2008, 03:31 AM   #8087
hanulec's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Jerry P View Post
Any little tricks that will help during the process.
Jimmy Ballcups - one more thing to buy, and this is not because i know you hit stuff - the parma hard bumper for the TC5: http://www.shopatron.com/product/par...2133.22134.0.0
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-17-2008, 05:36 AM   #8088
Takt's Avatar
Trader Rating: 15 (100%+)
Originally Posted by mr crum View Post
u dont need to worry bout roll out on rubber with 17.5 u need 2 start with ur final drive at 3.5 to start maybe higher but its a good place to start
What spur/pinion combo are you running to get to the 3.5?
Takt is offline   Reply With Quote
Old 12-17-2008, 05:48 AM   #8089
Takt.........a 3.5 fdr is way too much for the little tracks aroud here. Depending on the speedo and motor you will be somewhere between a 4.2 and a 4.6.
Josh Hohnstein is offline   Reply With Quote
Old 12-17-2008, 07:15 AM   #8090
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Josh, thanks for posting that setup. I finally gave it a try in the main and I picked up almost .5 seconds a lap. Now if I just could stay away from those 17 second laps I would be ok.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-17-2008, 07:29 AM   #8091
Takt's Avatar
Thanks Josh ... I was told at I'll need to get a 17.5 fdr at 3.8 for the Novak Race ... sounds like that is too much...
I have a Sphere TC ESC and Novak 17.5
The other issue I have ... to get to a 3.8 (or 4.2) for that matter ... all the little pinions I've bought over the years are worthless ...
To get to a 4.2 ... my largest pinion is 40 (64p) ... so I need to find an 84 tooth spur...
What is the smallest 64p spur available?
Old 12-17-2008, 07:52 AM   #8092
quietstorm76's Avatar
Which setup did you try and with what body?
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 12-17-2008, 08:03 AM   #8093
PartTime's Avatar
94/39 is the smallest that will fit. ur gonna need to get bigger pinions.
DK
Old 12-17-2008, 10:31 AM   #8094
Super Moderator
Kraig's Avatar
This one with a speed 6 body. I am not as good of driver as he is but the car was really stable and easy for me to drive more consistantly.
Team Associated TC5
Old 12-17-2008, 12:37 PM   #8095
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Kraig when you ran josh h's setup what did you use to space out the arms and what foams did you put in the shock bladders?
wallstreet is offline   Reply With Quote
Old 12-17-2008, 12:51 PM   #8096
Super Moderator
Kraig's Avatar
I have an assortment of washers in my box and I measured all of them to get 1.6mm. I am pretty sure that the Xray ones are pretty darn close to get 1.6mm. Someone correct me if I am wrong but I think .8mm is considered 1 degree.
As for the foam, the stock blue pieces. There are 2 pieces each for each cap from what I can remember. At least that is what I put in there. I also had a VCS2 shock conversion kit next time since I was robbing the o-rings out of there to rebuild mine. I could have gotten them mixed up as well. Needless to say I was thrashing to get it done.
Old 12-17-2008, 01:26 PM   #8097
start with an 88 spur and a 40 or 41 pinion for the novak race.........hunt me down when you get there and we will get you figured out.
Old 12-17-2008, 01:30 PM   #8098
A standard 4-40 washer is .8mm and they have the perfect outside diameter for shimming the arm mounts.
Old 12-17-2008, 01:31 PM   #8099
wallstreet's Avatar
Josh or Kraig
What is the benifit of the pro squat in josh's setup over just running 3b on every corner in the rear ?
Old 12-17-2008, 01:40 PM   #8100
Team Associated TC5
OK I have that one. Time to get started.
Primary Weapon: ?
Secondary Weapon: ?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
