Old 12-12-2008, 03:36 AM   #8041
PartTime's Avatar
It just seems odd to me that the whole right side of the car is 1/2 a turn higher then the left. Thats all.
DK
PartTime is offline   Reply With Quote
Old 12-12-2008, 06:26 AM   #8042
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Maybe you have one spring stronger than the other. Try to flip them from side to side and see what happens.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-12-2008, 11:17 AM   #8043
NeverATiteLine's Avatar
Send a message via AIM to NeverATiteLine Send a message via Yahoo to NeverATiteLine
Originally Posted by PartTime View Post
Here is somthing I hope you guys can help with.
Ok, Chasiss is balanced left/right perfectly. Spring collars are exactly the same left/right. Drop is perfect. Put it on a tweak board and it's all set BUT.....when I check ride height the right side of the car is .5mm higher ?!?!?!?!?!
Any idea's ?
DK
I had the same issue so, I had a buddy of mine come over w/a hudy complete set up station and was having the same problem when the shock collars were exactly the same. When we put it on the tweak board it looked like a bus hit it, it was THAT bad. Now granted i SUCK at building shocks and im sure that was part of the problem, also he has some sort of spring tester that he got from his work (he make springs for big trucks) that will test the size, type and ft pound per spring. Sure enough EVERY spring we tested was different from the other. We tested 6 blue springs out of 3 different spring kits and they varied as much as a 1/2 pound difference, so apparently when AE makes these springs or whoever makes them for AE are not real accurate.
So after figuring all this out, i set the ride height where i wanted it and they threw it on the tweak board, sure enough it was still way off. In order to get the tweak out of the car I just went ahead and adjusted the spring collars and here are the results that I got.....of course they will not be the same car to car but I just thought I would let u know how far off mine are for your reference.
Front (blue) right side shock collar is 2.67mm higher then the left
Rear (silver) right side shock collar in 1.88mm higher then the left
Set up like that, the car was on rails, so that means to me that the collars do not need to be even. Also means I should prob. get a few lessons on building shocks, but Set-up like that was good enough to win the main, So I am not gonna change what is working!!
MBX6-ECO
The 4 most famous words in motor sports: SECURITY TO THE PITS!!!
NeverATiteLine is offline   Reply With Quote
Old 12-12-2008, 12:39 PM   #8044
Layin' Wood's Avatar
Does anyone have a link or know what company makes the carbon fiber brace with the two fans on it for the esc and motor? It mounts right to the chassis. I've seen it before but lost the link and can't find it on Google. Thanks in advance for the help.
Layin' Wood is offline   Reply With Quote
Old 12-12-2008, 01:40 PM   #8045
Suspended
cool can fan man..i beleive
i am cornholio is offline   Reply With Quote
Old 12-12-2008, 01:43 PM   #8046
You nailed it cornhole thanks.
http://www.coolcanfan.com/usa/AE.php
Old 12-12-2008, 08:11 PM   #8047
Suspended
congrats to kevin for the 13.5 win...any chance of getting your setup..or is it the same from iic?? thx
Old 12-13-2008, 06:29 PM   #8048
TCRacer101's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to TCRacer101
Where do you mount it?
E-Revo Brushless.....4s lipo/Coming SOON: HPI savage flux HP
Electric Monster Truck Association (EMTA)~~ electricmonster.webs.com
TCRacer101 is offline   Reply With Quote
Old 12-13-2008, 07:46 PM   #8049
Trader Rating: 8 (90%+)
His car is phenomenal in 10.5 at fast cats this weekend.
Johnny Carey is offline   Reply With Quote
Old 12-13-2008, 09:28 PM   #8050
Send a message via MSN to Adim_X
Do any of you gents have a vta setup for a standard tc5? I like lots of steering.
Adim_X is offline   Reply With Quote
Old 12-14-2008, 03:58 AM   #8051
mr crum's Avatar
Send a message via Yahoo to mr crum
wat do u mean by vta
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 12-14-2008, 06:42 AM   #8052
TCRacer101's Avatar
I think he means Vintage Trans Am
Old 12-14-2008, 06:49 AM   #8053
TCRacer101's Avatar
My TC5 loves carpet right now. DIDN"T TOUCH A BOARD!!!!!!!!!!!!! Here's what I got in the electronics dept. and looks/downforce;
ESC; Tekin G11 pro
Motor; Fantom Limited Ed. stock rated 23,500 RPM @ 5.0V
Radio system; Spektrum DX2.0
Body; Parma Mowhawk 190mm, Protoform Nemesis 200mm grabbed it by mistake looks intimidating!
Old 12-15-2008, 09:00 AM   #8054
Jerry P's Avatar
Trader Rating: 44 (100%+)
What's up TC5 Guys...
I just picked up 2 TC5's (TC5F and TC5R) and cant wait to get home and start the build. Is there anything i should know before i start the build. Any little tricks that will help during the process. I've been running Losi Type R's since they were available and was wondering if there is any thing that the car needs to make it right.
I've read to through a lot of pages of this thread and know i could run a search but figured i would take the easy way out today.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 12-15-2008, 09:13 AM   #8055
BobbyS's Avatar
The washers that the instructions say to use with the diffs are too thick, there are some thin ones in one of the other open bags, use those and you won't have any problems putting the diffs together.
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
