Old 11-28-2008, 05:07 AM   #7981
Scottmisfits's Avatar
My car only has had one issue in 4-4.5 hours of run time. Some idiot was standing in the middle of the straight. I was running 13.5 and I nailed him dead on. I broke a plastic c-hub. Never any issues with cva pins.
Scottmisfits is offline   Reply With Quote
Old 11-28-2008, 06:58 AM   #7982
poochy's Avatar
Originally Posted by Syber Serulean View Post
any of you guys have any issues with CVA pins constantly breaking? Anyone know why and what can be done to remedy this?
Me and a team will be entering and endurance race in february but the main car we're lookin to use ive noticed breaking CVA pins at least 3-4 times in the last few months. I dont want this uncertainty during a 4 hour race. He runs 13.5 if that helps. My brother who also has a TC5 (but with front aluminum C-hubs, not sure if the rears are aluminum) has never broken the CVA pins but hes only ran it with a 27t brushed and only 2 runs now with a 17.5 brushless. Any help would be appreciated.
same cva pin keeps breaking or sporadic?
check the CVA-in particular the slot created for the pin. if that slot gets damaged (happened to me) or becomes larger. the pins will start breaking or bend. you might also notice a kick left or right on hard throttle or from a dead stop--the larger CVA slot can cause a delay in cva axle rotation due to the larger gap-the other 3 wheels starts to spin a fraction of a second before the wheel with the larger cva slot--trust me took me 3 months to figure out the kick left problem i was having.
another thing to check--put the car on a car stand. give it some soft throttle and observe how all 4 cvas' rotation--make sure they don't wobble. if one does-look to see if the cva is slightly bent (happened to me).
poochy is offline   Reply With Quote
Old 11-28-2008, 07:05 AM   #7983
poochy's Avatar
Originally Posted by entitymugenmtx View Post
HEY poochy THANKS ALLOT FOR YOUR HELP IT'S FIXED
i cant take credit-somebody else on here gave me the advice-but im realizing nobody really knows about it
=the source of the majority of the tc5 steering slop is from the fitting between the steering post and its bearing (the upper bearing). put threadlock there and the remaining 10-20% is from the ballcups-no big deal there. this is a night and day result-try it!
Old 11-28-2008, 07:06 AM   #7984
poochy's Avatar
-this will also cure most of the chatter from the wheel when fully turned and on throttle.
Old 11-28-2008, 09:42 PM   #7985
BobbyS's Avatar
That last tip was worth the cost of a tube of ThreadLock all on it's own!
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 11-30-2008, 07:50 PM   #7986
Congratulations to Keven Hebert on his well deserved win in superstock foam in cleveland. Also a second place finish in mod foam.
Great job Keven!
Josh Hohnstein is offline   Reply With Quote
Old 11-30-2008, 07:54 PM   #7987
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
Great job Keven!
+1 to that! GJ Kev!
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 11-30-2008, 09:14 PM   #7988
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
VTA question. I am trying to fit an HPI '65 GT350 Mustang body on a TC5. The wheel wells match the wheelbase, but it seems the bumper is in the way of the front fascia. Has anyone else run across this, and if so, did you find a solution other than grinding away at the bumper? Thanks in advance.
Old 12-01-2008, 08:53 AM   #7989
robk's Avatar
Trader Rating: 22 (100%+)
Nice Job Keven!
Andrew-you may have to grind the foam bumper for vta.
robk is online now   Reply With Quote
Old 12-01-2008, 09:04 AM   #7990
ravex911's Avatar
Just got my new TC5R in the mail and am going to start building tonight!
I remember reading something about the picture in the instructions being deceiving. Do I use only using one foam spacer or both when building the shocks?
Thanks J.
ravex911 is offline   Reply With Quote
Old 12-01-2008, 09:37 AM   #7991
Rick Hohwart's Avatar
Great job Keven!
Congrats Keven!
Rick Hohwart is offline   Reply With Quote
Old 12-01-2008, 09:40 AM   #7992
Hide's Avatar
Has anyone else noticed that the stock body posts on the rear are so high up! I literally have 15cm of spare post sticking out of the car Gotta cut them down.
Losi 8ight-E 2.0, LRP Shark, Xray M18T custom extended, Traxxas VXL Revo
Hide is offline   Reply With Quote
Old 12-01-2008, 10:04 AM   #7993
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Keven your a stud
wallstreet is offline   Reply With Quote
Old 12-01-2008, 12:11 PM   #7994
fiveoboy01's Avatar
Trader Rating: 17 (100%+)
Originally Posted by BIG DADDY8 View Post
How tight should i tighten it?
Till it won't slip
I didn't put balls in mine and haven't broken anything yet in a crash(knock on wood). I just made mine "snug", the spring pressure does well to keep it from slipping.
Bill
JR Vibe 50, and that's it!
fiveoboy01 is offline   Reply With Quote
Old 12-01-2008, 01:17 PM   #7995
Gyro's Avatar
Thanks J.
I did not use any of the foams in my shocks, as I had read that was the best choice over on Associated's forums.
I normally see around 80% rebound which suits me perfectly.
More foams = more rebound.
Gyro
The Green Cuda Board Tagger :tire:
Gyro is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
