Old 11-24-2008, 07:09 PM   #7966
geeunit1014's Avatar
Originally Posted by baf1 View Post
#1tighten your rear diff. #2check your chassis for wear marks.#3 go with the blue springs all four.#4check and reset ride height. let me know if that helped...
#1 and #3 will make it worse..
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-24-2008, 07:19 PM   #7967
PartTime's Avatar
Originally Posted by BLUE 2 View Post
Hi
It is running a R9-F body
rubber tyres - outdoors - Bitumen ( med grip ) sorex 36's
I will fill out a setup sheet & post it on here .
Here we go
See ya
1) I think the 36's might be too hard. I ran on a light to med grip track and 32s were as hard as we could go.
2) If its turning harder one way then the other your chassis is out of balance, out of tweak, droop is wrong or your steering end points need some touching up.
3) 2 deg of rear toe is not enough. goto 3.
4) isnt that a foam body? Try a stratus or mazda 6
5) Make sure your belts are the same tention. A loser frt belt will make the car lose coming out of slippery corners no matter what you do.
6) Stand rear shock up to 3b for more forward traction.
Other than that, looks fine.
DK
PartTime is offline   Reply With Quote
Old 11-24-2008, 07:35 PM   #7968
BLUE 2's Avatar
Trader Rating: 23 (100%+)
Talking
Hi Guy's
Thanks for all the suggestions & replys
I just checked belts & readjusted them ( has inproved a little )
Also i did move the rear shock mount to 3B ( has inproved a little more )
I will go to 3 deg rear toe ( see if it helps )
Also i think the chassis is left hand heavy ( when sitting on bench chassis has lean to left / motor side ) i think it needs more weight on batty side .
Yes it does right hand corners really good ( in & out )
Will go tune more & see how i go .
PS - this is my mates car so i don't want it to go to good ( can't have this car going better than mine ) but still want close racing .
Cars Offroad : TLR 22B- TLR 22B 2.0- TLR 22-4B- TLR 22T- TLR 22SCT- TLR TEN-SCTE 2.0
Cars Onroad : HB Cyclone TC - TRF 416X - Tamiya TA05 - Serpent s411 eryx 2.0
BLUE 2 is offline   Reply With Quote
Old 11-24-2008, 08:16 PM   #7969
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Yes if you are running a lipo you will need to add weight. I would venture to guess that because of the weight difference that is why it spins out one way and doesn't always spin out the other way.
Make sure your left and right side of the car are balanced. Take some fishing line and put it in the middle holes on the shock tower and lift it off the ground. This will get you started to see how far off you are. There is more to this but it will get you closer than what you are now.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-24-2008, 08:48 PM   #7970
revo61's Avatar
Trader Rating: 18 (95%+)
If you are going to run rubber you need a r9-r body. I will tell you the r9 has no rear downforce and tons of front bite. It can make the rear end very loose.
JQ The Car White Edition/Reds R7E/Reds 2113 pipe
Airtronics MT4/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM /WWW.DIALEDHOBBIES.COM /WWW.TALLAHASSEERC.COM
revo61 is offline   Reply With Quote
Old 11-24-2008, 09:47 PM   #7971
BLUE 2's Avatar
Talking
Hi Guy's
I just moved some weights around & added some till the chassis is sitting level on the bench & the over steer on power out of the corners is all but gone . ( this is with no body on )
Going to balance the chassis tonight & put rear toe to 3 deg & try it tomorrow with body .
Thanks for all your help
See ya
Old 11-24-2008, 10:00 PM   #7972
Mr.17.5BR's Avatar
Hi
Here we go
See ya
i am running mike blackstocks 10.5 foam setup from the gate with a few changes.. i run schumaker green 18 lbs front and schumaker blue 16 lbs rear. every thing else is mikes set-up .. i run on a low bite asphalt track . track temp 60 deg .. i run 17.5 stock against 13.5 super stock at my track and im 1 lap on the field i am also running the r9-f body .... foam or rubber bodies . it doesnt matter if you run foam with rubber body or rubber with foam body .. a body in just another tunning aid.. if you are running rubber on asphat or carpet .. and you have plenty of stiering and not enough rear traction then you will be better suited for a foam type body for it has less front downforce and more rear bite..
Mr.17.5BR is offline   Reply With Quote
Old 11-25-2008, 01:21 AM   #7973
ntc3racing's Avatar
Originally Posted by PartTime View Post
Wish they had 4deg blocks. Would love a set.
DK
integy makes the 4deg castor blocks!!
*TEAM ASSOCIATED*RCMADNESS*NOVAK*NTC3*RC18T*XRAY T2 008*KO PROPO*DIGGITY DESIGNS*TRINITY*SMC*
ntc3racing is offline   Reply With Quote
Old 11-26-2008, 12:13 AM   #7974
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
My tc5 has sterring slop is there any fix for it.
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 11-26-2008, 06:45 PM   #7975
NeverATiteLine's Avatar
Send a message via AIM to NeverATiteLine Send a message via Yahoo to NeverATiteLine
Not sure if anyone else has had this problem, but for some reason the screws that hold my servo to the servo mounts keep backing out and letting my servo move back and forth slightly causing slop in my steering. Unfortunately it took me 2 weeks to figure this out cuz I always over look the "simple" things. If that is tight make sure you have the small spacer that goes between the top deck and the bell crank in there....I accidentally forgot that one time while I had it apart and that too caused some slop.
hope this helps
MBX6-ECO
The 4 most famous words in motor sports: SECURITY TO THE PITS!!!
NeverATiteLine is offline   Reply With Quote
Old 11-27-2008, 12:03 AM   #7976
HEY poochy THANKS ALLOT FOR YOUR HELP IT'S FIXED
Old 11-27-2008, 06:57 PM   #7977
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Questions??
I want make the slipper spool. Looks like all i'd have to do is take the diff balls and the 2 metal rings out and put in the slipper pads. Then tighten it down. Is this correct????
BIG DADDY8 is offline   Reply With Quote
Old 11-27-2008, 07:51 PM   #7978
fiveoboy01's Avatar
Trader Rating: 17 (100%+)
That is correct.
The manual shows assembling it without the thrust balls as well, but the word is that you SHOULD install those as it allows the diff to give and slip if you hit something, but it won't slip under normal driving conditions.
Bill
JR Vibe 50, and that's it!
fiveoboy01 is offline   Reply With Quote
Old 11-27-2008, 07:56 PM   #7979
BIG DADDY8's Avatar
Originally Posted by fiveoboy01 View Post
That is correct.
How tight should i tighten it?
Old 11-27-2008, 11:59 PM   #7980
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
any of you guys have any issues with CVA pins constantly breaking? Anyone know why and what can be done to remedy this?
Me and a team will be entering and endurance race in february but the main car we're lookin to use ive noticed breaking CVA pins at least 3-4 times in the last few months. I dont want this uncertainty during a 4 hour race. He runs 13.5 if that helps. My brother who also has a TC5 (but with front aluminum C-hubs, not sure if the rears are aluminum) has never broken the CVA pins but hes only ran it with a 27t brushed and only 2 runs now with a 17.5 brushless. Any help would be appreciated.
Syber Serulean is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
