Old 11-23-2008, 08:08 PM   #7951
ravex911's Avatar
Default Back in the hobby
I have taken a couple years off and the rc bug has returned. I see a few things have changed, mainly the li-po batteries and the AE has moved to a belt drive! I've went through a hundred or so posts and the TC5R has overall great reviews. I like mainly how Team Associated doesn;t change cars every 6 months and that they seem to have a well dialed car.
I had raced with a TRF414 but I am thinking about getting the TC5. Anyone have some up to date pro's / con's on the TC5R?
I was alos looking at the Tamiya 416WC edition but I like the idea of having easy to get parts and support from my local hobby shop. Any input would be appreciated.
J
ravex911 is offline   Reply With Quote
Old 11-24-2008, 12:40 AM   #7952
poochy's Avatar
Originally Posted by PartTime View Post
Wish they had 4deg blocks. Would love a set.
DK
integy makes the 4 degree-i dont know anything about them though.
http://integy.com/cgi-bin/webc.cgi/s...=5732&p_catid=
poochy is offline   Reply With Quote
Old 11-24-2008, 07:45 AM   #7953
AeRacer805's Avatar
J
You just answered alot of your own questions The TC5R out of the box on my local track is great because our track does not have alot of traction at times. If your local track has alot of grip the box stock setup might need to be changed, it all depends on your driving style. I'am use to driving with a ONE-WAY so I needed a little more on power steering so I changed the rear springs to Assoc Blue and moved the bell crank linkage to 2B instead of 1B per a suggustion on this forum and I found the steering I was looking for. The car seems to react to adjustments very well, you don't have to change a bunch of things in your setup to see a difference in proformance.
"When you are not practicing someone else is and when you meet that person they will beat you."
TC6, Top Photon, B4.1, SC10 FT, Orion Motors and Servos, Tekin RS
AeRacer805 is offline   Reply With Quote
Old 11-24-2008, 08:35 AM   #7954
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
ravex911
One thing that I noticed with the battery strap is that if you are not careful when you tighten it down to the battery it could have a tendency to bow the chassis. So some are using tape instead.
I myself took a 4-40 nut and put it on the threaded rod part. Then I put the battery strap on the nut to see just how far the strap is off. Then I elongated the holes so that the strap would sit down better. I am still messing with it though as I am not 100% happy with it and I am to lazy to use tape.
The only other thing that I wish the car had was is a center one-way. I prefer running two diffs and a center one-way for rubber tires on carpet but I will get over it.
Those are my only complaints so far.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-24-2008, 10:20 AM   #7955
ravex911's Avatar
[QUOTE=AeRacer805;5086646]You just answered alot of your own questions The TC5R out of the box on my local track is great because our track does not have alot of traction at times. If your local track has alot of grip the box stock setup might need to be changed, it all depends on your driving style. QUOTE]
Thanks for the resonse. Yeah I guess I kinda did answer my own ?s, just wanted confirmation mostly. I'm pretty excited about building a car again and getting back intgo the races. The TC5 looks really refined from the old TC3 design.
Where I live they have a high bite asphalt track, and a lot of the guys with the tc5's appear to run the silver/gold spring cobo. Does that seem right?
Old 11-24-2008, 10:45 AM   #7956
AeRacer805's Avatar
R they running the sliver spring in the rear or front? If thats what works at that track then thats what works. The gold springs are pretty stiff and the slivers are on the soft side thats why Assco came out with the blue springs. Stiffer than slivers but softer than gold Assco springs from hardest to softest are-----RED,GOLD,BLUE,SLIVER,GREEN for asphalt anyway.
Old 11-24-2008, 11:22 AM   #7957
ravex911's Avatar
Kraig - Thanks for the battery tip. I've always used tape on my batteries so that part doesn’t bother me. Is there anything else I should know about before building the car? I heard a few people were having issues with building shocks, though it doesn’t seem all that difficult.
AeRacer805 - I believe its silver in the back. I'll probably just start with the base setup and work from there. I'll pick up spring colors you mentioned though.
I really want to pick up a kit this week and build it over the holiday. Anyone know a good online hobby shop that has decent prices on the TC5R, or one with coupon codes? My LHS only carries the foam edition so I have to go the online route.
Anyway, I'll probably have a bunch of build/setup questions once I get started. The site/forum seems to help resolve all sorts of issues.
I'm pretty excited about getting back into the hobby, and the TC5 looks like the way to go.
Old 11-24-2008, 12:16 PM   #7958
EEChris's Avatar
Trader Rating: 21 (100%+)
In finding a TC5R with a decent price try: Speedtech RC (www.speedtechrc.com) or Ampdraw hobbies (www.Ampdraw.com). Prices are pretty good and so is their fast shipping!
Chris Ibarra
EEChris is offline   Reply With Quote
Old 11-24-2008, 02:07 PM   #7959
Trader Rating: 23 (100%+)
if anyone is interested in buying one, im selling a 5 run tc5r.
>>>TEAM ASSOCIATED TC5R ROLLER & NOVAK SS PRO 13.5 MOTOR<<<
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 11-24-2008, 02:21 PM   #7960
BLUE 2's Avatar
Questions??
Hi Guy's
I Need some help with a TC5-R
It is wanting to spin out when coming out of the corners ( on power ) it just wants to slide the ass ( its worse coming out of left hand corners & just a little coming out of right hand corners )
Any hints or tips would be great
See ya
Cars Offroad : TLR 22B - TLR 22B 2.0 - TLR 22T - TLR 22SCT - TLR TEN-SCTE 2.0
Cars Onroad : HB Cyclone TC - TRF 416X - Tamiya TA05 - Serpent s411 eryx 2.0
BLUE 2 is offline   Reply With Quote
Old 11-24-2008, 02:44 PM   #7961
revo61's Avatar
Trader Rating: 18 (95%+)
Originally Posted by BLUE 2 View Post
Hi Guy's
See ya
Please post what your setup is and what body you are using.
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 11-24-2008, 02:58 PM   #7962
BLUE 2's Avatar
Talking
Hi
It is running a R9-F body
rubber tyres - outdoors - Bitumen ( med grip ) sorex 36's
I will fill out a setup sheet & post it on here .
Here we go
See ya
Old 11-24-2008, 03:02 PM   #7963
Rick Hohwart's Avatar
Hi
Be back soon .
See ya
If you use a slipper spool, make sure it is tight.
Rick Hohwart is offline   Reply With Quote
Old 11-24-2008, 06:05 PM   #7964
baf1's Avatar
Default yo
#1tighten your rear diff. #2check your chassis for wear marks.#3 go with the blue springs all four.#4check and reset ride height. let me know if that helped...
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 11-24-2008, 06:07 PM   #7965
geeunit1014's Avatar
Hi
Here we go
See ya
Use a rubber tire body. THe R9-F is for foams, and has considerably less downforce than its rubber tire cousin, the R9-R, or a Mazdaspeed 6. The Speed 6 should work almost anywhere, try that and see if it helps
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
