Old 11-21-2008, 05:47 PM   #7936
PartTime's Avatar
Originally Posted by robk View Post
2B is a nice setting for normal humans. #1 (forward on the bell crank) is pretty reactive. #2 is usually where you want to be. I always felt that B gave more overall steering over A, especially on power.
Ok, so A is less steering. Thats what I was looking for. Thanks.
DK
PartTime is offline   Reply With Quote
Old 11-22-2008, 01:11 AM   #7937
Default One-way or spool
Hello guys,
I race in Denmark, this is our first year with 9.5 brushless in Super stock. We are using 5 cells, and rubber on carpet.
Last year we used 19T brushed, and one-way was fastest on almost all tracks. This year I'm in doubt, and I can of course just test the 2 setups back to back. But I thought that maybe 10.5 with Lipo was similar, so I could get some of your experience there.
My feeling is that 9.5 brushless is so much faster than 19T brushed, that it is faster to adapt a driving style where your brake before tight turns you approach fast. which is dificult with a one-way.
So what's the verdict, one-way or spool in super stock?
petk is offline   Reply With Quote
Old 11-22-2008, 05:20 AM   #7938
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
If you run a one-way turn down your brake epa so that it isn't locking up the rear wheels and causing the car to spin out when you do brake.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-22-2008, 07:14 AM   #7939
quietstorm76's Avatar
Originally Posted by PartTime View Post
Maybe a little longer on the rear dope? I have been running the Sorax's 28's rear and the 32's up front. Tons of smooth steering. Did I mention I love this car ?!?!?! Definitley one of the fastest cars Ive owned.
DK
I'll try your suggestions tonight and let you know.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 11-22-2008, 06:01 PM   #7940
poochy's Avatar
Originally Posted by baf1 View Post
go with #1pin blocks ... no more traction roll at the c...
no more traction roll with the above advice is correct - confirmed today--thanks man!
btw-anybody try these ---> http://diggitydesigns.com/D3_TC5_CasterBlockSet.html ?
poochy is offline   Reply With Quote
Old 11-23-2008, 07:20 AM   #7941
Originally Posted by quietstorm76 View Post
It occurs off power/ mid corner. Running a one-way now but I had the problem with the spool also. Only thing is I'm about .4 faster per lap with the one way but with the traction roll. What body do you run?
No more traction roll!!!!!!!!!!!!!!!!!!!!
Went to the regular Mazda 6 and Jaco blue fr/Rr and I picked up 2 laps. I did change my ackerman from 1B to 1A and it smoothed things out a lot too. Thanks for all the advice guys.
Primary Weapon: ?
Secondary Weapon: ?
Old 11-23-2008, 12:55 PM   #7942
Jsaves's Avatar
Josh H.
When you say 1.5 mm droop, which to me seems a little hard to get, I was wondering if you went back and checked the droop the old way at the arms?
If you did what did you get? I was wondering how little at the arms is the droop? Because it seems like there is very little droop ie. very high number on the arm droop gauge and the arms angled up.
I hope this is clear on my question.
Thanks and God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 11-23-2008, 05:10 PM   #7943
PartTime's Avatar
Originally Posted by poochy View Post
Wish they had 4deg blocks. Would love a set.
DK
Old 11-23-2008, 05:38 PM   #7944
artwork's Avatar
Trader Rating: 56 (100%+)
Originally Posted by Jsaves View Post
Josh H.
Many drivers measure the droop over ride height. So if you set RH to 6mm then droop would be 7.5mm.
Hope that clear...
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 11-23-2008, 06:25 PM   #7945
gixxerman's Avatar
Originally Posted by Josh H View Post
Here is my current carpet rubber tire setup. It looks kind of crazy on paper, its based off of Joel's setup but adapted for stock.
Without a doubt the fastest, most stable carpet rubber car I have ever driven.
Josh Hohnstein
Josh....thank you for posting the set-up. Had second fastest lap at my track today and would have finished second in the main but it thermaled on the last lap! Damn. First time in a while I made the A. I was ready to get rid of the car after last week-end! Again THANK YOU!!!
gixxerman is offline   Reply With Quote
Old 11-23-2008, 07:32 PM   #7946
Jsaves's Avatar
So make sure I am doing this correct.
You set your ride height, say 5.5 mm, then you want 1.5 droop.
So you slide the ride height gauge underneath to 7 mm and adjust the droop screws until the tires almost lift off.
Is this correct?
Do you have to watch the shock spring tension while doing this?
CRC GT-R
CRC WTF-1
Old 11-23-2008, 07:46 PM   #7947
Is this correct?
Thats exactly right.
If the AE gauge is easier for you just set the droop with the ride height gauge and then see what that equals on the AE gauge.
Yes you do need to watch the spring preload when the droop gets below 2mm. The spring should spin fairly free on the shock when the tires are off the ground.
Josh Hohnstein is offline   Reply With Quote
Old 11-23-2008, 07:47 PM   #7948
That is good to hear.
A solid setup really makes racing more fun.
Old 11-23-2008, 07:51 PM   #7949
Jsaves's Avatar
Thanks Josh and Artwork.
This great help.
CRC GT-R
CRC WTF-1
Old 11-23-2008, 07:55 PM   #7950
olhipster1's Avatar
Trader Rating: 91 (100%+)
Send a message via Yahoo to olhipster1
Default DROOP
Usually, there are a few way to get Xnumber over ride height (all basically the same idea)
1. set ride height...the usual way...with a ride height gauge.
2. begin setting droop, lift car on whichever side you are setting droop on, life until the tires just start to come off.
-turn the droop screws until the desire droop setting is established.
-keep doing step 2 until desired goal is achieved.
it's super easy...
time permitting somtimes after the first two step...i would use droop blocks to get the equivalent number off the block and mark my setup sheets, this also might help with identify if something is tweak'd.
just my process.....quite a few people do it differently.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
