Old 11-20-2008, 06:00 PM   #7921
baf1's Avatar
Default hey .
go with #1pin blocks ... no more traction roll at the c...
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 11-20-2008, 07:51 PM   #7922
quietstorm76's Avatar
What's #1 pin blocks?
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 11-20-2008, 08:24 PM   #7923
Scottmisfits's Avatar
Hinge pin holders that have one dot on them.
Scottmisfits is offline   Reply With Quote
Old 11-20-2008, 10:40 PM   #7924
Airflow's Avatar
Question...
Can I use TC3 front arms to my TC4?
Are there any changes in wheelbase or width?
Airflow is offline   Reply With Quote
Old 11-21-2008, 03:33 AM   #7925
ok thanks. Where do I use them front and rear?
Primary Weapon: ?
Secondary Weapon: ?
Old 11-21-2008, 06:37 AM   #7926
PartTime's Avatar
Hey guys. I started to play with the akerman on this car at the last race and have a question.
If I remember correctly, the out side hole on the knuckle is B, So I started with 1B and moved to 2B. It smoothed out the car big time on power. Was wondering how the B hole compairs to the A hole with 1 and 2. Maybe some one can list the order from most steering to least ??
DK
PartTime is offline   Reply With Quote
Old 11-21-2008, 06:41 AM   #7927
PartTime's Avatar
Ive been running with #1 frt and #2 rear. The higher rear really helps the car rotate on power. The car drives up to the corner with no problem.
Latley I switched to the B hole (upper) frt and rear and REALLY like the way it feels. It does take some traction away but, its more consistint every where. If your running carpet give it a try. If your running asphalt use the A (lower) hole.
HTH
DK
Old 11-21-2008, 08:40 AM   #7928
poochy's Avatar
arm mounts 2 to 1
rp-30 to jaco blue
cant wait to try this setup
poochy is offline   Reply With Quote
Old 11-21-2008, 08:51 AM   #7929
Originally Posted by poochy View Post
arm mounts 2 to 1
rp-30 to jaco blue
You can try the setup changes at "The C". But the traction isn't going to be as high as last weekend.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 11-21-2008, 03:52 PM   #7930
HTH
DK
Do you widen the front of your car? I've been having some random traction rolls and have tried everything except a new body. I'm running a Mazda Speed 6. The car is quick but the traction rolls are killing me. I'm going to a regular Mazda 6 this weekend. Any advice? running blackstocks setup from IIC.
Primary Weapon: ?
Secondary Weapon: ?
Old 11-21-2008, 05:56 PM   #7931
PartTime's Avatar
No, my car is full narrow.
Did you try moving your wing back some more? That should help a bit too. I hear that the speed has more steering than the 6 but havnt had either to find out.
Looking at Blackstocks setup, mine is really close with only a few changes. The car should be pretty close. Where does it traction roll at? When you get off the gas? You running a spool or oneway?
DK
Old 11-21-2008, 06:15 PM   #7932
DK
It occurs off power/ mid corner. Running a one-way now but I had the problem with the spool also. Only thing is I'm about .4 faster per lap with the one way but with the traction roll. What body do you run?
Primary Weapon: ?
Secondary Weapon: ?
Old 11-21-2008, 06:27 PM   #7933
baf1's Avatar
Default ...
take it from me the guy with the most roof time at the c...
Old 11-21-2008, 06:33 PM   #7934
robk's Avatar
Trader Rating: 22 (100%+)
DK
2B is a nice setting for normal humans. #1 (forward on the bell crank) is pretty reactive. #2 is usually where you want to be. I always felt that B gave more overall steering over A, especially on power.
Old 11-21-2008, 06:40 PM   #7935
PartTime's Avatar
Im running a stratus ap with the wing full forward. Even trimed it down a little. It goes mid or rear for out door stuff.
I just tried the 2B akerman setup and it really smooth the car out in the middle of the turn. Made it easyier to drive also. Really consisnt compaired to the 1B setup
Other than that, the only thing I can think of is tires.
Maybe a little longer on the rear dope? I have been running the Sorax's 28's rear and the 32's up front. Tons of smooth steering. Did I mention I love this car ?!?!?! Definitley one of the fastest cars Ive owned.
DK
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
