Old 11-17-2008, 08:32 PM   #7891
ILDRVR's Avatar
Thanks, I am running the new jaco non-dish greens. Is there a rubber difference between the green dish/non-dish wheels? (more or less traction?) Should I try out some blues? I thought the blues are a harder compound?
What about take-off 27s? I ran those last year until my lhs could't get them anymore, but he has some in stock now.
Thanks again for the advice
Tarara Racing
Tea's Hobby Shop & Raceway Park
Cheese City Xtreme RC
ILDRVR is offline   Reply With Quote
Old 11-17-2008, 08:46 PM   #7892
Scottmisfits's Avatar
The Blues are a 32 rating compared to the 27's, yet they have more grip, as long as they are the new ones. I haven't run the new greens though. Try the new Blues with the prism wheels and if it's not enough grip, try the new greens.
What we have found on a few of our local track where we were running double pink foams, traction levels were about that of purples with the Jaco Blue's. You don't lose a whole ton of traction with them. I really like them.
Scottmisfits is offline   Reply With Quote
Old 11-17-2008, 08:58 PM   #7893
ILDRVR's Avatar
Thanks, has anyone else had any experience with any of these tires on low bite ozite?
Thank you
Tarara Racing
Old 11-18-2008, 12:23 AM   #7894
treemagnet's Avatar
Trader Rating: 17 (100%+)
Default lipo
hey everyone
i plan to go lipo soon and need advice. first i think im going to use a bitty design tray, although some ppl reckon i dint even need a tray, thoughts? also does it matter what way the leads come out of the battery? i mean some lipos have the leads coming out of the top while others come out the side. which would be better for mounting?
thanks
tree
treemagnet is offline   Reply With Quote
Old 11-18-2008, 08:50 AM   #7895
[QUOTE=Josh H;5063118]You should be safe running the associated #3 pistons. If I had to guess I would say a 57 piston is between a #2 and a #3.
I thought 57 was 2nd to largest and looking at assoc #'s. #1 looks like the largest.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 11-18-2008, 08:55 AM   #7896
fiveoboy01's Avatar
Originally Posted by treemagnet View Post
hey everyone
thanks
tree
Depends on the lipo. I use the intellect 3800s with the bumps on the bottom that fit in the battery slots in the chassis. I had all sorts of problems with it shifting, coming out, rubbing my belt, etc even on lighter hits.
I shoe-goo'd the hold down strap to the top of the battery like Josh suggested. The battery does not move at all now no matter how hard I clock the barriers If you have more than one lipo you'll need an extra holddown but it's worth it to keep the battery in place.
Mine have the terminals on the top of the case, I just have straight bananna plugs on the end of my ESC which I plug directly into the battery. I orient them towards the rear, the one is close to the cog for the rear belt but it won't touch as long as the battery stays secure.
Bill
JR Vibe 50, and that's it!
fiveoboy01 is offline   Reply With Quote
Old 11-18-2008, 11:25 AM   #7897
I don't think I understand what your trying to say.
Josh Hohnstein is offline   Reply With Quote
Old 11-18-2008, 11:39 AM   #7898
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
The larger the number, i.e. 57, the smaller the hole. So if you had a 60 piston and a 57 piston from Losi the 60 would have smaller holes in it.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-18-2008, 11:50 AM   #7899
Default Piston equivalent
Guys here is a quick reference for the pistons between Losi and AE,I believe it is based on the volume of oil that will go thru the subsequent "holes/valves".
Losi #60 Natural is (.040) no AE equivalent but close to Kyosho 3B
Losi #57 Black 3 Hole (.043) is equivalent to the AE #3
Losi Red #56 (.0465) is Equivalent to the AE #2
Losi Orange #55 (.052) is equivalent to AE #1
Hope this helps
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 11-18-2008, 11:55 AM   #7900
Hope this helps
Thanks. A guy that drives a losi told me that a 60 was the largest. Thats the reason why I asked.
Steve Walter
Old 11-18-2008, 02:36 PM   #7901
Default Anti-squat
Hello Josh,
Thank you for posting your setup. I just recently tried the B mounting position on the bulk heads, with good results. Looking forward to try this.
You are running negative anti-squat, what does that do? My setup books only describes positive anti squat.
Best,
Peter Knudsen
Denmark
petk is offline   Reply With Quote
Old 11-18-2008, 02:44 PM   #7902
Originally Posted by petk View Post
Hello Josh,
Best,
Peter Knudsen
Denmark
I've tested back and forth from flat pins to pro squat (forward angle) its very hard to feel the difference...........The major thing I could feel is I can be more aggressive in the on power turns. Meaning I can stay full throttle and steer into the turns without the back end breaking loose. So I "think" it smooths the weight transfer from front to back.
Old 11-18-2008, 03:25 PM   #7903
PartTime's Avatar
Just thought I would show what I did for lipo mounting.
Pics are worth a 1,000 words soo....
DK
PartTime is offline   Reply With Quote
Old 11-18-2008, 07:43 PM   #7904
trailranger's Avatar
Just make a new battery strap
I use a LiPO plate under my TC5 so I had to invert my LiPO. I made a wider battery strap to fit between the nubs. I installed helicoils into the battery post so that the plastic would not wear out. Works great, except that I needed to add a transponder holder and the G10 flexes more than graphite would.
"If everything seems under control, you're just not going fast enough." - Mario Andretti
trailranger is offline   Reply With Quote
Old 11-18-2008, 08:44 PM   #7905
Default Lipo mounting in TC5 made easy
First off this is for top plug Batts.Orion 3800 or SMC top wiring/plugs.This is for use with the steel top and side plates. Get a batt. box for the old associated rc10. They are two wedge shape plastic halfs. Cut the mounting tabs off one side (outside) of boxes (away from belt). Novak clear tape to lower steel plate,move about 1/6 in. in from edge.Then tape outside steel plate to (outside) of boxes.When you set it in the car it should be about 1/4in. from belt,and just clear the bulkhead in the rear.For the SMC you need to grind about 1/16 off bulkhead.It does not effect chassis at all.This box allows you to swap all top wired batts,and still use the stock batt. strap. Very cool when done! Makes it easy to remove from car...remove strap,tilt up and slide out box,lift out batt. Hope this help...
TC5-TC4-KSG-Tekin-Novak-3PK-Hitec-PRS-Gears-John's BSR-Racing-Tires Tri-State Raceway In Hamilton ,Ohio-Much More-Spektrum Associated-Team Magic-APS-SMC Competition Electronics-Ice.
8up-Club Dayton,Ohio
108% Certified 8up
8up-racing is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
