Old 11-17-2008, 10:23 AM   #7876
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by racing_jason View Post
hey guys i was looking at getting a TC5 here shortly but i have herd alot of things about how the car becomes tweaked really easily! is this true or is it something some of the ppl at the shop are doing wrong?
Thanks jason
I ran the stock 2.5mm (F) chassis near 1 year then thoroughly checked on a PPD tweak plate. The chassis was out some (.015) but less then most other TC's after what mine had been though that year.
Most people are never aware of this and dial it out in setup...they're just left wondering why the shock collars are different to get ride height ..ect.
But...the ITF 2mm chassis is a different case. Since installing that, I've had a few impacts knock it out worse (.020 +). A bent bulhead, a bent screw, or poor tightening proceedure on top deck can tweak it, not to mention a perma twist in chassis plate itself. Using the 4 orings on the top deck helps. Bottom line...the thinner the chassis, the more careful you need to be...with any TC.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 11-17-2008, 12:07 PM   #7877
Layin' Wood's Avatar
Default Transponder Placement
I'm still somewhat new to racing and have had my TC5R for a few months now. I've gotten most of the add-ons I've needed (the weighted plates from VernDog work great) and I'm getting a transponder today. I've seen a lot of people place them in front of battery, is this the normal placement for it? I do need just a little more weight on that side so that should do it or be fairly close. And also would you normally run the wire under the the belt or through it? I think I have a couple images saved at home in my pit book to reference but I thought it'd be best to ask first.
Thank you in advance for the help.
Layin' Wood is offline   Reply With Quote
Old 11-17-2008, 01:12 PM   #7878
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
i put my transponder on the bottom of the steering servo and you want to run your wires thru the belt.
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 11-17-2008, 01:15 PM   #7879
revo61's Avatar
Trader Rating: 18 (95%+)
I have mine on the front bumper.
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 11-17-2008, 01:36 PM   #7880
Thank you for the information. I have my receiver in between the servo and speed control on the left so I will probably have to go on the bumper or the spot just north of the where the battery lays. I finally got a set of balance buttons so I can ensure that the weight is equal.
Old 11-17-2008, 03:43 PM   #7881
Here is my current carpet rubber tire setup. It looks kind of crazy on paper, its based off of Joel's setup but adapted for stock.
Without a doubt the fastest, most stable carpet rubber car I have ever driven.
Josh Hohnstein
Josh Hohnstein is offline   Reply With Quote
Old 11-17-2008, 03:47 PM   #7882
Scottmisfits's Avatar
How are you using camber hole 2-B? I bottom out in the ball cups and can't get any less than +1* camber. Did I use the wrong turnbuckles somewhere.
Scottmisfits is offline   Reply With Quote
Old 11-17-2008, 03:52 PM   #7883
2-B shouldn't really be a problem.....I did cut a little off the turnbuckles to run 2-A.
You could try some shorter turnbuckles or dremel about a 1mm off of each end of the stock turnbuckles.
Old 11-17-2008, 03:55 PM   #7884
Sorry, 2-A. Been a long day.
I tried to get 2-A a couple of weeks ago and I couldn't get it. The 2-B is what I normally run.
Old 11-17-2008, 04:45 PM   #7885
Trader Rating: 35 (100%+)
Default josh
hey josh quick question, should i assume your rubber setups are with all the soft arms and knuckles? thanks
nazman01 is offline   Reply With Quote
Old 11-17-2008, 06:09 PM   #7886
ILDRVR's Avatar
Josh, this weekend I was racing against a Corally driver who was still using one of your old setups. He spoke very highly of you.
In this last setup you used piston 57...what assoc. piston will be close to it? Should I buy the losi pistons(I think 57 is losi?) ?
How will that setup work on low traction ozite? My current set-up is running silver (front) and green(rear) springs to gain enough traction. I am also using jaco greens. Thanks for the help.
Tarara Racing
Tea's Hobby Shop & Raceway Park
Cheese City Xtreme RC
ILDRVR is offline   Reply With Quote
Old 11-17-2008, 07:04 PM   #7887
No...I run all hard parts on my car.
I forgot to put that on the setup sheet.
Old 11-17-2008, 07:09 PM   #7888
You should be safe running the associated #3 pistons. If I had to guess I would say a 57 piston is between a #2 and a #3.
The setup works well on low bite. But if your running the old jaco greens(dish wheel) those don't make very much traction on low bite tracks.
Old 11-17-2008, 07:11 PM   #7889
Default setup
guess i shouldnt assume! thanks...
Old 11-17-2008, 07:25 PM   #7890
ShadowAu's Avatar
Default I know its probably been covered... but...
I am considering buying a TC5-R as my new car for the next year or so... what upgrades and spares do people recommend?... as in MUST HAVES
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
