Old 11-12-2008, 02:11 PM   #7846
artwork's Avatar
Trader Rating: 60 (100%+)
Originally Posted by gixxerman View Post
I am having trouble burning up rear diff's and am in need of some suggestions on a possible fix. I have the original TC-5 and was having problems melting the rear plastic diff. Yes it would actually melt the diff rung to the outdrive. I switched to aluminum on both front and rear and am still having probs with only the rear diff! I do not beleive it's a tightening issue and the bearings are fine. This is the second season I have run the car and I honestly thought the alum diff would solve the problem. Again I am having no issues with the front diff at all. If it helps we run 13.5 LiPo on Jaco Greens.
I spend a lot of time on TC5 diffs. I check them almost every race day, but I think the key is to make sure you are putting a good amount of diff grease in the diff on build. Also make sure that you are not over tightening diff. The diff should be pretty smooth and should not bind in any way. Because the diffs are open they tend to dry out.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 11-12-2008, 03:36 PM   #7847
TJames987's Avatar
Trader Rating: 10 (92%+)
im looking to sell my Losi JRXS-r and either get a Cyclone tc or the TC5R, which car do you guy think would be easier to setup and better overall car for asphault racing on rubber tyre?
TJames987 is offline   Reply With Quote
Old 11-12-2008, 06:01 PM   #7848
Usually when diff parts melt it is because the diff is slipping too much causing heat - mleting plastic. I usually tighten the diff screw until it bottoms out and back it off 1/8 too 1/4 turn and fine tune from there. Looser is smoother but it wares out faster.
John Schoenauer
Hadar R/C Raceway by OTWG 2011 race dates August 14, August 28, September 11, September 25
John Schoenauer is offline   Reply With Quote
Old 11-12-2008, 06:12 PM   #7849
quietstorm76's Avatar
Anyone running the Mazda Speed 6? How much different is it from the regular Mazda 6?
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 11-12-2008, 06:46 PM   #7850
baf1's Avatar
Default go...
R9R
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 11-12-2008, 07:05 PM   #7851
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Originally Posted by NeverATiteLine View Post
Hey, I am trying to figure out everything and things are going pretty well, I tried a spool and hated it, so I put the diff back in and liked that much better...I would like to try a one way but now i hear talk of the slipper spool. Are a 1 way and a slipper spool the same thing? If not whats the difference?
A one way allows the front wheels to free spin off power, then locks up when power is applied. This allows the front wheels to keep rotating allowing the car to steer. When power is applied the one way locks up giving the car more pull out of the corner. The one thing to remember when using a one way is the brakes are only in the rear. If you are too aggressive with the brakes, the car can spin out easily. The spool has the pull of a one way out of the corners but gives four wheel brakes for more stable corner entry. The slipper spool adds some give over a standard spool. This give takes some stress off the drive train that occurs when using a spool or a one way, Hope this helps.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 11-12-2008, 07:31 PM   #7852
Scottmisfits's Avatar
Speed 6 has more aggressive steering while still being very stable. The R9R has even more steering but at the high price of very little rear grip. If you can make some mechanical grip through set up, it might be ok.
Scottmisfits is offline   Reply With Quote
Old 11-13-2008, 11:07 AM   #7853
poochy's Avatar
Originally Posted by i am cornholio View Post
hey anyone have a good setup for super high bite asphalt...lots of sweeping corners...used seans setup from nats last year..pushes pretty bad in sweepers..thx
try this if its really really good high bite asphalt--use the R setup from the manual and make a few changes
change the downstop (droop screw) to 8 all around
shocks -the 3rd hole from center out - all 4 shocks
remove the front sway bar-keep the rear black one with the one dot mount
camber front = 2
camber rear = 3
apply tire compoud -Jack "The Gripper" on all 4 tires
Check your lap times, let me know if this helps or not.
poochy is offline   Reply With Quote
Old 11-13-2008, 03:30 PM   #7854
So which do you prefer Speed 6 or regular 6?
Primary Weapon: ?
Secondary Weapon: ?
Old 11-13-2008, 04:10 PM   #7855
Suspended
Trader Rating: 4 (75%+)
I just got a new tc5 and was wanting to know what 64p gear can i run for a track thats 150x 75?
qcstrokr is offline   Reply With Quote
Old 11-13-2008, 05:37 PM   #7856
tenpins77's Avatar
Send a message via AIM to tenpins77
Originally Posted by Josh H View Post
The internal for the tc5 is 2.0
Gearing depends on track size and what type of motor and speedo.
With that being said......I gear my Trinity duo 13.5 at 100/41 which is 4.88 this is on a 100 x 50 track
For a Trinity 17.5 duo I gear at 100/45 which is a 4.44
I use an lrp speedo with full punch.
Josh Hohnstein
our track is rather small, the carpet track is probably that size, the asphalt track is maybe 85x45,its inside an oval, would i be okay with that gearing?
thanks,
tenpins
tenpins77 is offline   Reply With Quote
Old 11-13-2008, 08:15 PM   #7857
thanks,
tenpins
If your track is smaller.......start about 2 teeth smaller on the pinion. Check the temp on the motor after a few mins to make sure its not getting too hot.
Josh Hohnstein is offline   Reply With Quote
Old 11-13-2008, 08:56 PM   #7858
Trader Rating: 23 (100%+)
I have the tc5f and what spring kit is recommended?
bmcallister is offline   Reply With Quote
Old 11-13-2008, 09:05 PM   #7859
On the R with carpet and rubber the stiffest I have used are the coppers. Softest I have used are the greens which are the softest. The only ones you might not use are the yellow's and the whites, but it's cheaper just to get them in the kit. One kit should do you and figure out if you need multiples of any of them.
Old 11-13-2008, 09:12 PM   #7860
So another words go with the associated spring kit?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
