Old 11-10-2008, 06:52 AM   #7816
speedsterblade's Avatar
Originally Posted by John Schoenauer View Post
What is the handling difference when changing shock rebound from say 25% rebound to 100% rebound?
Thanks John Schoenauer
wondering myself. Also I've heard some fast guys use negitive rebound...meaning if you pulled out the shaft it would suck back in. Can anyone elaborate? Thanks.
speedsterblade is offline   Reply With Quote
Old 11-10-2008, 07:37 AM   #7817
poochy's Avatar
Originally Posted by PartTime View Post
It seemed to have a little more slow speed steering than my stratus ap. But other then that, it felt the same. Neutral and stuck.
DK
ive tried the DNA1-good looking body but the mazda 6 is easier to drive with rubber (for me).
poochy is offline   Reply With Quote
Old 11-10-2008, 08:31 AM   #7818
Johnny Wishbone's Avatar
Default Aluminum spool issues.
I'm running a aluminum spool in the front and keep breaking the dog bone blades or pin cushions. Any one else have this problem and whats the fix?? This is without any contact with walls, so I don't think its impact related.
Old 11-10-2008, 10:13 AM   #7819
poochy's Avatar
another racer keeps doing that also running a 10.5 motor like me and so far-i have not broke one yet
the only thing i noticed was that his outdrives were a little damaged from running the car without the blades--are your outdrives damaged?
Old 11-10-2008, 10:15 AM   #7820
poochy's Avatar
has anybody else experienced a slop between the steering post and the bearing that holds it vertically? the slop seems a bit excessive imo. any advice?
Old 11-10-2008, 12:17 PM   #7821
fiveoboy01's Avatar
Trader Rating: 17 (100%+)
As long as we're asking questions, I'm having a helluva time keeping my lipo in place.
Yes I know, I shouldn't be hitting things but I'm a noob and I do bump the pipes on occasion.
The battery will either move outwards pushing the front fender out or it will shift inwards, rubbing the belt and putting excess tension on it.
I'm using the intellect 3800 packs which have the "bumps" on the bottom. They aren't wide enough for one thing so the pack can slide left/right about a 1/4 inch. I'm using the stock hold-down strap and screws. Is there a solid alternative or method to keep the battery in place? I don't expect it to stay put if I really clock something hard, but I'd like it to stay put with a small or moderate bump.
Bill
JR Vibe 50, and that's it!
fiveoboy01 is offline   Reply With Quote
Old 11-10-2008, 12:22 PM   #7822
The 2 options that come to mind are :straping tape instead of the stock hold down........or shoegoo your battery hold down strap to the top of your battery.
Josh Hohnstein is offline   Reply With Quote
Old 11-10-2008, 12:23 PM   #7823
New spool, so no damage of any sort. Is there a batch of pin cushions that are more brittle than others, the ones I have are a very shiney black plastic, not a dull black.
Old 11-10-2008, 12:24 PM   #7824
geeunit1014's Avatar
Thats because the DNA1 is a foam tire body, and the 6 is designed for rubbers
Most likely, you are hitting something, mine only break when I hit stuff (it doesnt take much to break them) Other than that, check if your cvds are binding
Tape. There are also many lipo mounting plates available
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-10-2008, 12:24 PM   #7825
Send a message via MSN to Bigger Brother
Hi
I've had the same problem, and got some tips from Rick Howart and Joel Myrberg....
Basically, its best if you can run the 'slipper spool' rather than the solid axle, which then allows a bit of give and protects the blades better.
Alternatively I have found the following - the blades are much less prone to breaking if you don't have any spacers on your lower wishbone mounts, ie run them bolted straight to the bulkhead with no 1/1.5/2 degree spacers.
Something I have tried this week which also seems to work well is using the blades from the Xray 008 (I know, its terrible) - if I'm honest I ended up doing this only as I broke one, had no spares, and the shop only had these.
Hope that helps
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 11-10-2008, 12:34 PM   #7826
Originally Posted by Bigger Brother View Post
Hi
Hope that helps
Oli
Thanks, I noticed that the Xray ones seem to be a more pliable plastic, i'll try them first before going to the slipper setup.
Old 11-10-2008, 12:36 PM   #7827
poochy's Avatar
wrap tape around the battery and battery strap as one unit-this wont let you down-no more worries
Old 11-10-2008, 06:44 PM   #7828
This is what I am using with my LiPo battery - http://www.manutech.info/rcracinghom...gproducts.html - I need to add extra weight and the battery dosent move. Look for the "TC5 LiPo weight"
John Schoenauer
Hadar R/C Raceway by OTWG 2011 race dates August 14, August 28, September 11, September 25
John Schoenauer is offline   Reply With Quote
Old 11-10-2008, 08:15 PM   #7829
Trader Rating: 24 (100%+)
ok, i feel really retarded for even asking this question.
building tc5r, now and car went together great except i saved the shocks for last.
the black seal or whatever that goes into the body is binding. am i supposed to force it, trim the four corners? never had a shock that didnt go smooth.
thanks for any help
vic0280 is offline   Reply With Quote
Old 11-10-2008, 08:20 PM   #7830
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
You've gotta force those in. It's a tight fit cause that's what holds the guts of the shock in place.
Lots O' Planes
AssocRacer is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
