Old 10-28-2008, 09:32 PM   #7726
Maybell's Avatar
Originally Posted by quietstorm76 View Post
Ok I set the diff like the book says. How do you set your diff?
This is kind of hard to describe but I will try...
I dont believe in the "tighten the diff completely and then back it off a certain amount of turns" technique...I think when you tighten a diff completely, the carbide balls put pot marks in the rings...
After running pancars forever you learn to manually feel how tight to set a diff by holding the tires and forcing the diff to slip a little with your hand on the gear...I estimate in my mind how much force it will take for a motor to make the diff slip and set the diff a little tighter than that...
When building a diff I tighten it down till there is just a little pressure on the balls, then I work the diff a little, then tighten a little more...I keep repeating the process till I get to a point when the tightness is in the ballpark...then I slide a 050 allen driver in each outdrive and force the diff to slip a little to feel the tightness...then I keep working and tightening the diff till I feel it is right...then I put it in the car and run it 2 minutes without pulling full throttle...then adjust till it is perfect...
I hope this was understandable and will help you....
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 10-28-2008, 09:37 PM   #7727
Scottmisfits's Avatar
I know this has been asked before but what's a good starting point for rubber on carpet with a 17.5, gearing wise? It will be 48 pitch. Setting it up for a buddy but I run 13.5 wit 64 pitch. Would 5.5 be a good place to aim for?
Scottmisfits is offline   Reply With Quote
Old 10-28-2008, 09:44 PM   #7728
SteveJa's Avatar
Trader Rating: 17 (100%+)
17.5 should be more like 3.5 ~ 4.0 more like 3.8......
HATCHER RACING !!!!
Impulse R/C
http://www.aphlikshunfingerboards.com/
http://stevejavorsky.zenfolio.com
More and More its BEARDMORE !!!!!!! (Thanks Todd)
SteveJa is offline   Reply With Quote
Old 10-29-2008, 02:01 AM   #7729
treemagnet's Avatar
Default tc5
im still a newbie to RC but with reference to the diff questions i have probably only rebuilt my diff 4 times but the first couple i rushed it not cleaning all the old grease out of it etc etc but the last couple of times i took my time and used team associated grease and just generally was very patient when building it and the dfference was amazing to say the least!!!!
treemagnet is offline   Reply With Quote
Old 10-29-2008, 02:09 AM   #7730
Mr.Che's Avatar
@ guietstorm
Steering position c is self made...in the middle of a+b little more forward.
Bulkheads are cut to gain more flex..so you dont need the o rings...
I will post some Pic s later
Mr.Che is offline   Reply With Quote
Old 10-29-2008, 09:46 AM   #7731
I have mine at 4.17 with the Orion Vortex 17.5, very quick in the infield and holds it own on the 80' straight. Laptimes are the same as my PHI with the same FDR and motor, (10.8's-11.2's).
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 10-29-2008, 09:52 AM   #7732
It depends on the motor and speedo.
I ran my trinity duo 17.5 at 4.44 on a 100 x 50 track with the lrp speedo.
Josh Hohnstein is offline   Reply With Quote
Old 10-29-2008, 10:34 AM   #7733
Uh-Oh!, looks like the Dr. is gonna hand out some whoopins this weekend
Old 10-29-2008, 10:49 AM   #7734
Sorry Eric.....I won't even be there.
I was just testing motors and trying to find a good ratio to recommend.
Old 10-29-2008, 02:18 PM   #7735
fatbear's Avatar
Send a message via Yahoo to fatbear
If you really want a smooth diff check out this Website. I installed the rings and balls in my TC5 and followed the instructions supplied for breaking in the diff.
This produced the smoothest diff I have ever felt. And then even after a whole nights racing in modified on High Grip carpet the diff was still very smooth, certainly still better than a fresh standard diff built to the instructions.
I will only use BFast RC's products for my diffs from now on.
I know this sounds like a commercial for the guy(Fred) but the product is that good and I have no association with him what so ever and live on the other side of the world.
http://www.bfastrc.com/index.html
fatbear is offline   Reply With Quote
Old 10-29-2008, 02:24 PM   #7736
Mr.Che's Avatar
Not the best Pic...but you can see the cuten rear and front Bulkhead+new Steering block position.
Lars
Old 10-29-2008, 02:36 PM   #7737
Mr.Che's Avatar
Old 10-29-2008, 03:36 PM   #7738
Default Newbie with questions about shocks
I bought a slightly used TC5. I was changing the springs on the shocks & noticed the shocks all feel different. Some don't hardly spring back at all, while another comes back 100%. I've tryed removing the big foam pad & refilling with oil, but they are still different. Any suggestions on what I might be doing wrong? I've also noticed one seems to have white milky oil like it has tons of very tiny bubbles. Are they aftermarket parts that are better than the standard ones?
Thanks for any help anyone can give a first time guy!
DannoTC5 is offline   Reply With Quote
Old 10-29-2008, 03:52 PM   #7739
artwork's Avatar
Trader Rating: 54 (100%+)
Sounds like you need to rebuild all of the shocks. New bladders, new orings, new oil. Stock shocks are just fine...no need to replace them.
Setting rebound (the amount the shaft comes out when you release it) in shocks takes some practice.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 10-29-2008, 04:50 PM   #7740
quietstorm76's Avatar
Makes since to me. Will follow your precedure. Thanks for the info.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
