Old 10-28-2008, 11:11 AM   #7711
I have found that using the the white plastic insert and diff nut from the TC3 diff rebuild kit makes assembling the diffs simple!!! the nut already comes inserted into the plastic!.. piece of cake to get together.
BillySnarf is offline   Reply With Quote
Old 10-28-2008, 03:38 PM   #7712
quietstorm76's Avatar
Yep these work great I have 3 in my parts box plus 2 diffs already built with the white t-nut.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 10-28-2008, 03:46 PM   #7713
Originally Posted by Mr.Che View Post
I tried this Weekend Joel s Setup at the 2 BaWü Cup...:-)
I dit some minore changes on the Steering ...with New Sorrex 28R for 4 runs just perfekt .
with more run s the back starting to by loose.
The only problem is still the Diff...good for 1 run ...it was High grip Carpet..Normali the Diffs will last for 1-3 runns on Lower Grip Carpet
http://www.ps93.ch/setup/asso-tc5_rc..._weisskopf.pdf
Mr. Che can you explain what you mean by F+R bulkhead cut? And what new steering position is C? Is there a new steering knuckle?
Primary Weapon: ?
Secondary Weapon: ?
Old 10-28-2008, 03:50 PM   #7714
BobbyS's Avatar
IMO I think that AE put the wrong washer in the diff bag in these kits, if you use the thin washer from the unused parts you'll find that the diff goes together just fine. The other options are all good, but there's no need to wait or to buy additional parts to assemble them.
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 10-28-2008, 04:05 PM   #7715
How often are you guys having to rebuild your diffs? I had to rebuild mine twice in one night. It's not melting but it just gets really notchy after about 2 runs. Any advice?
Primary Weapon: ?
Secondary Weapon: ?
Old 10-28-2008, 04:44 PM   #7716
Trader Rating: 38 (100%+)
Every couple months. Are you using plastic or aluminum outdrives?
or8ital is offline   Reply With Quote
Old 10-28-2008, 04:44 PM   #7717
Maybell's Avatar
I think you might be setting your diff too loose at build time, once a ball diff starts to slip, its a quick death from there...
After I build a diff I run the car for 2 minutes without pulling full throttle...then check how tight it is and adjust...if set correctly your diff will last for many race days even with mod motors...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 10-28-2008, 04:48 PM   #7718
PartTime's Avatar
Mine gets notchy when its too tight. kinda hard to set it. A little lose and its fine but I like to run a little tighter diff so after tighten it up I have to check the next round to see if it gets notchy. Wish we had a light weight spider diff with oil. Easyer to tune and last longer.
DK
PartTime is offline   Reply With Quote
Old 10-28-2008, 04:53 PM   #7719
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
spider diffs cannot phyiscally react as quickly as a ball diff can. They can take more abuse but are much slower acting and can't handle the higher rpms that the smaller 1/10th scale cars do. Also, ball diffs are MUCH easier to tune....build em, adjust em, then loosen or tighten them to your liking....spider diffs.... build em, put fluid in em, take em apart, replace fluid to tune....too much work, too messy.
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 10-28-2008, 05:16 PM   #7720
Verndog's Avatar
Trader Rating: 16 (100%+)
When that starts happening to me, its usually from not cleaning out the pulley slots where the diff balls set well enough. A small brush with some motor spray or degreaser, followed by compressed air with clean motor spray should take care of it. There tends to be left over remnants of fine particles that get caught in there, and its tough to see them.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-28-2008, 05:22 PM   #7721
Verndog's Avatar
double post
---Team Hoarders---
Old 10-28-2008, 05:34 PM   #7722
Ok I set the diff like the book says. How do you set your diff?
Primary Weapon: ?
Secondary Weapon: ?
Old 10-28-2008, 05:35 PM   #7723
Will watch out for this. Thanks
Primary Weapon: ?
Secondary Weapon: ?
Old 10-28-2008, 07:24 PM   #7724
hanzo3's Avatar
Trader Rating: 55 (100%+)
The ITF main chassis thickness is 2.5mm? What is the regular carpet chassis thickness? 3?
Chris • TRF419 • TA05V2 •
TQ RC Racing • Powered by teeth
hanzo3 is offline   Reply With Quote
Old 10-28-2008, 07:26 PM   #7725
geeunit1014's Avatar
IFT is 2mm, regular is 2.5mm
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
