Old 10-27-2008, 12:35 PM   #7681
Catalyst's Avatar
Originally Posted by JuhoL View Post
I've been using the 12R5 aluminium front rideheight spacers on the TC5 arm mounts. They are 0.5mm, 1mm and 2mm though, so one spacer is not 1 degree but you can still work with them. On the plastic spacers one degree is .030 in which is about 0.8mm.
Juho...thanks for the tip. I'll have to pick some of those up for sure. Sounds like between 2mm and 2.5mm should be similar to running the 3 degrees inboard toe I've been running. Might try out 2mm first since I'd like a little less toe in anyhow.
Catalyst is offline   Reply With Quote
Old 10-27-2008, 01:18 PM   #7682
mo
mo's Avatar
I ran a modified version of Joel's carpet setup this weekend at the Region 12 asphalt champs. I finished 2nd in 10.5 and 3rd in 13.5 but had a car good enough to win both. I'll post the setup as soon as I get it into acrobat.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 10-27-2008, 02:08 PM   #7683
losithrasher's Avatar
im selling my tc5r.
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 10-27-2008, 05:42 PM   #7684
baf1's Avatar
Default why,
why, josh are you selling your tc5r,...and how much. pm me.
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 10-27-2008, 07:23 PM   #7685
geeunit1014's Avatar
Originally Posted by losithrasher View Post
im selling my tc5r.
dont do it man! youll regret it!
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-27-2008, 07:26 PM   #7686
I'm trying to set up my TC5 for VTA and have run into a problem.The rear end is loose.It mostly happens in the right-hand, high speed sweeper.It starts as a slow spin just after corner entry.I run at a carpet track.Here is my set up.
ride height=5mm, front&back
40w shock oil, 100% rebound
gold front springs, silver rear springs
front shock mount 3B, rear shock mount 3B
front camber link 5A, rear camber link 3
front droop=3, rear droop = 5
batteries, 4 cell NimH in the foward position.
ITF chassis and top deck.
I tried new tires,old tires.saucing, no saucing
The radio's dual rate is @ 50%
The shocks are equal length,the chassis isn't tweaked.
Any help will be appreciated.
outlandr91 is offline   Reply With Quote
Old 10-27-2008, 07:30 PM   #7687
Scottmisfits's Avatar
Try moving the battery to the middle. It will just put weight over the rear wheels a little more.
Scottmisfits is offline   Reply With Quote
Old 10-27-2008, 07:32 PM   #7688
Do you have weight added to the battery side of the chassis?? You will be about 140 grams light on that side with only 4 cells.
Josh Hohnstein is offline   Reply With Quote
Old 10-27-2008, 07:34 PM   #7689
try 45f/35r shock oil, with less rebound, and batt in middle
Mike Gee
Old 10-27-2008, 09:40 PM   #7690
decibels's Avatar
Originally Posted by quietstorm76 View Post
Does anyone have any sway bar tweak tips? I tried sway bars this weekend and could not get the car right, but everyone else is running them so I know it was something I screwed up. My problem s is that the arms won't lift equally from both sides. I'm running Josh H's IIC setup
adjust all your tweak on the car as per normal. then put on your sway bars and check tweak! if it is out then you can adjust your length of each side to get them even! then your tweak will be perfect
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 10-27-2008, 11:03 PM   #7691
hanzo3's Avatar
Trader Rating: 55 (100%+)
how much of a difference would the ITF main chassis make for rubber asphalt? I have been running the regular one. Is it worth the $50 bucks to upgrade?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 10-28-2008, 02:04 AM   #7692
@Bigger Brother
You need to use the new Slipper Spool. Then the outdrives is longer and you will not break any blads, when making front wider. You can keep the wider front and car will be even better.
/Joel
Joel Myrberg is offline   Reply With Quote
Old 10-28-2008, 03:05 AM   #7693
Send a message via MSN to Bigger Brother
Originally Posted by Joel Myrberg View Post
@Bigger Brother
/Joel
Thanks - thats what I had thought. Have one on order so will try it out as soon as possible. Thanks again for the setup, it really did help out massively.
Cheers
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 10-28-2008, 06:08 AM   #7694
IH8Racing's Avatar
Hey guys I have a few questions about some of the set-up sheets I've seen.
So I'm still building the car and see that some people are using Losi pistons in the shocks and or Losi oil.
Now are these types of changes making a huge difference or should I start with the box set-up then try those changes on my own to see what happeneds.
Thanks for the help!
Sean
[URL="http://dontblamejesus.com"]http://dontblamejesus.com[/URL]
[B]HE [/B]changed me. [B]I believe, I am saved.[/B]
Born to GOD
[B]Stephen Shook [/B]Monday Evening, the 6th of October 2008. I will always remember you and what you did for me.
IH8Racing is offline   Reply With Quote
Old 10-28-2008, 06:15 AM   #7695
portyansky's Avatar
Trader Rating: 54 (100%+)
Whats a good starting pinion spur set-up for a short track using a gtb/10.5?
edit: running on carpet using rubber. 5000 2cell lipo
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
