Old 10-25-2008, 06:40 AM   #7666
Gain Time's Avatar
I usually run foam until recently....well I am getting ready for our fall classic where there is going to be a rubber tire class. So far so good however I can not find anyone that has an ITF top deck in stock. I have tried it without and using some unusuall set up tricks I finally can get the car to handle ok in the corners but I will bet the boys that have the ITF will have a bit more grip overall.
Anyone know of a supplier that has this part in stock?
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 10-25-2008, 11:34 AM   #7667
Jsaves's Avatar
I just got one on the way from Rommel.
He has his store link in his sig.
Very quick service
God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 10-25-2008, 03:41 PM   #7668
ntc3racing's Avatar
Originally Posted by geeunit1014 View Post
gear up your FDR right now is about 5.. most 13.5 guys are running mid 4's depending on the layout.. try a 96/41 (about 4.7) and see what the temp is, as long as its under 170*f, its good
thank you for your help!!!!!
*TEAM ASSOCIATED*RCMADNESS*NOVAK*NTC3*RC18T*XRAY T2 008*KO PROPO*DIGGITY DESIGNS*TRINITY*SMC*
ntc3racing is offline   Reply With Quote
Old 10-25-2008, 03:43 PM   #7669
ntc3racing's Avatar
Originally Posted by Gain Time View Post
I agree you should run around a 4.7 however this will depend on the Diameter of your foams. I run 96/40 for 58 mm foams and once I get down just under 57mm on the foams I switch to 96/41 and once I get to 56 mm I go to 96/42. It runs right at the 170* mark.
If you are not wanting to run the motor on the edge then with 58 mm run 96/40 until you are at 56 mm then switch to 96/41.
Old 10-26-2008, 08:51 AM   #7670
MTRezNIN's Avatar
Default Black Roll Bar
Does anyone know the part number for the black anti roll bar?
Thx.
Altoona Raceway - Altoona, PA www.altoonaraceway.com
altoonaraceway@gmail.com
Team Losi Racing - 8ight 2.0 Buggy
PSN ID: MTRezNIN
MTRezNIN is offline   Reply With Quote
Old 10-26-2008, 09:10 AM   #7671
fiveoboy01's Avatar
Trader Rating: 17 (100%+)
Additive times were 20 mins on rear and 5 mins on front (both full width).
Noob question: I assume what you mean by this is you're applying the compound and letting it sit that long before burning off before the run?
31269
Bill
JR Vibe 50, and that's it!
fiveoboy01 is offline   Reply With Quote
Old 10-26-2008, 11:56 AM   #7672
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I broke a plastic outdrive on a TC5. We want to replace the plastic outdrives with the aluminum outdrives. Is there anything needed other than the aluminum outdrives and the cvd blades?
I am assuming the diff internals will simply swap over to the new outdrives.
Heres the part numbers I am looking at . . .
http://aedownloads.com/downloads/item_photos/31181.jpg
http://aedownloads.com/downloads/item_photos/31238.jpg
Old 10-26-2008, 12:59 PM   #7673
quietstorm76's Avatar
Does anyone have any sway bar tweak tips? I tried sway bars this weekend and could not get the car right, but everyone else is running them so I know it was something I screwed up. My problem s is that the arms won't lift equally from both sides. I'm running Josh H's IIC setup
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 10-26-2008, 01:26 PM   #7674
Trader Rating: 68 (100%+)
Andrew you got pm
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 10-26-2008, 01:39 PM   #7675
geeunit1014's Avatar
make sure the links for the bars are all equal length, and the distance from the collar to the end of the bar is the same length.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-26-2008, 01:55 PM   #7676
I did that but I just found out that the bars are not straight and they are brand new.
Primary Weapon: ?
Secondary Weapon: ?
Old 10-26-2008, 02:57 PM   #7677
Send a message via MSN to Bigger Brother
I apply the additive, let it sit that long then when the race before mine is 4 mins through, wipe the tires with a cloth, to remove 'wet' additive that is 'standing' on the surface still. Then place on the track and run it - no need to 'burn off' then. Have never liked the idea of burn offs anyway as it loads up the transmission unnecessarily.
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 10-26-2008, 03:14 PM   #7678
fiveoboy01's Avatar
Thanks for your reply
Bill
Old 10-26-2008, 03:34 PM   #7679
Rommel's Avatar
Very quick service
God Bless
I only had one in-stock and you got it.
Rommel is offline   Reply With Quote
Old 10-27-2008, 03:44 AM   #7680
poochy's Avatar
does anybody run better lap times with an unbalanced (no lipo weights) tc5 running lipos?
poochy is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
