Old 10-14-2008, 06:11 AM   #7576
poochy's Avatar
hey guys, i bent my B side front bearing cap - are there any better aftermarket parts than the stocked bearing caps=these look like potential benders not breakers.
poochy is offline   Reply With Quote
Old 10-14-2008, 07:38 AM   #7577
poochy's Avatar
Originally Posted by RC_DAVE4 View Post
The pull to the left is related to slop between the servo saver tube and the steering bell crank. The hex shaped nut is loose. I used epoxy to bond the two together to eliminate this issue. Search my posts for more details.
Dave
Thats good you figured it out-my pull on hard throttle appears to be a missing 2mm wheelbase shim on the front left inner hinge pin.
Old 10-14-2008, 08:00 AM   #7578
Rick Hohwart's Avatar
Originally Posted by treemagnet View Post
just wondering if anyone uses the hard parts on asphlat using rubber?? someone said to me if i change to hard parts i should softening up my springs and shocks a little bit. does this sound right?
I and most other team driver use hard parts all the time. The car will not be as forgiving as it will be with the softer parts, but it is ultimately faster.
The biggest single change will be going to hard caster blocks, then hard front arms, then hard rear arms. Hard tteering blocks and hub carriers will not really make any difference.
You won't need to make any changes to your setup when going to hard parts.
Rick Hohwart is offline   Reply With Quote
Old 10-14-2008, 08:54 AM   #7579
yodace's Avatar
R/C Tech Charter Subscriber
To get 2.75 rear toe which shims do i use? just wanna make sure i do it right LOL.
yodace is offline   Reply With Quote
Old 10-14-2008, 11:44 AM   #7580
poochy's Avatar
Dave
RC_DAVE4--you have to be missing a bearing if you have slop there?
tc5r maunal page 5 step 4--you need 2 bearings to stablize the steering post
also make sure you have the steering post spacer there too--page 5 step 5
i thought i fixed my hard pull to the left on hard throttle by correcting my arm shim installation-it helped but theres still a slight pull to the left on hard throttle---i think i see the missing part that is causing it---a 2mm wheelbase shim on the fron left inner hinge pin is missing---might explain why smooth throttle is fine and hard throttle is bad
check that--make sure you use 8 wheel base shims total on the car--2 for each inner hinge pin
Old 10-14-2008, 01:20 PM   #7581
Vision's Avatar
Trader Rating: 38 (98%+)
Ok finished my car, did notice one issue. When going straight it's tracks pretty true, but for some reason in reverse it pulls to the left ?. Any ideas guys ?
Pic of my finished car -
Vision is offline   Reply With Quote
Old 10-14-2008, 01:22 PM   #7582
Vision's Avatar
forgot to add I have 0 toe in front and using the middle thickness shim for the rear arms to give me some toe in.
Old 10-14-2008, 01:58 PM   #7583
Jamesalex's Avatar
Questions??
I am looking at this car and a mi3.5 and was wondering how easy the car is to work on change set up and fit lipos the hole hog basically any feed back would be great
cheers in advance
Jamesalex is offline   Reply With Quote
Old 10-14-2008, 02:00 PM   #7584
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
I would look at parts availability before anything. I'm sure that you'll find that most hobby shops will stock parts for the TC5 and not so many shops will stock parts for the Schumacher car.
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 10-14-2008, 02:01 PM   #7585
AssocRacer's Avatar
real rc race cars don't have reverse so we wouldn't know
Lots O' Planes
Old 10-15-2008, 04:17 AM   #7586
MTRezNIN's Avatar
Default Servo
I was thinking of trying the AE DS1313 (173 oz. Torque, .13 Speed) in my TC5.
Any experirnce with this servo - is it enough?
Should I go with the JR 9100S, or is that overkill.
I am racing competitively, rubber tires on carpet.
Thanks!
Altoona Raceway - Altoona, PA www.altoonaraceway.com
altoonaraceway@gmail.com
Team Losi Racing - 8ight 2.0 Buggy
PSN ID: MTRezNIN
MTRezNIN is offline   Reply With Quote
Old 10-15-2008, 04:40 AM   #7587
revo61's Avatar
Trader Rating: 18 (95%+)
I would say both are overkill. A Hitec 625 would be good. These cars are so light they don't need a lot of torque.
Thanks!
revo61 is offline   Reply With Quote
Old 10-15-2008, 05:45 AM   #7588
Scottmisfits's Avatar
For the kind of money you're looking at spending, the AE 1015 or the futaba 9551 would be better choices. Based on speed, not torque
Scottmisfits is offline   Reply With Quote
Old 10-15-2008, 05:46 AM   #7589
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
give the car about .5 degree of toe in at the front, that should cure the issue. you will have that with zero degree of toe.
good looking car by the way, is that a drift car?
bigemike is offline   Reply With Quote
Old 10-15-2008, 07:07 AM   #7590
AssocRacer's Avatar
I agree, the 9551 is fast as hell. I use a hitec HS6965HB servo, karbonite geared servo. This thing is insanely fast. .08 transit time. It's one of those servos where if you turn your transmitter wheel and then let it go, the wheels bounce with the spring action on the transmitter
Lots O' Planes
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
