Old 10-09-2008, 03:24 PM   #7546
Scottmisfits's Avatar
What's with the wimpy 17.5 stuff Greg? You should be running the 13.5/19t with us.
And if you can find a 108 or slightly bigger spur, I have pinions up to a 41t that you can use if you want to run on Friday. Model Land might have some 64p spurs here locally.
Scottmisfits is offline   Reply With Quote
Old 10-09-2008, 03:49 PM   #7547
Trader Rating: 26 (100%+)
whats the deal with the diffs, it seems as the screw is to short.
eddie10 is offline   Reply With Quote
Old 10-09-2008, 03:57 PM   #7548
I noticed in my kit that they were about 1/16" too short. It's a good thing for me I had a bunch of them from when I kept snapping them on my Pro 4.
Old 10-09-2008, 04:44 PM   #7549
Swampracer's Avatar
Trader Rating: 69 (99%+)
19T about mid season once I get a few races with the TC5 Scott.
Working this weekend...no racing for me.
Cheers
Swampracer is offline   Reply With Quote
Old 10-09-2008, 07:09 PM   #7550
Johnny Wishbone's Avatar
You have to do the spring compression suggestion in the instructions, then you should be good for length.
Old 10-09-2008, 07:18 PM   #7551
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Make sure the nut is fully seated in the plastic piece. It does go in pretty deep.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-09-2008, 09:10 PM   #7552
I have built quite a few AE diffs. The spring compression and making sure the nut was in fully was done. It still didn't help. Both screws, front and rear diff, were short. I swapped them out with some I bought from a fastener supply store and it worked. A little bit of a pain but no biggie. The ones from my TC5 were fine, it's just the ones from the TC5R that were short.
Old 10-09-2008, 10:10 PM   #7553
poochy's Avatar
my brand new tc5r is now assembled. everything seems to be running really well except the pull to the left on hard acceleration. i run a mamba 7700 with maxamps 2s 6000mah - very fast car -
i checked the droop and its even between left to right-6 front 4 rear.
swapped tires around.
samething happens without the body.
the shock feels good
fr toe in shimmed 1.5m evenly on all 4 corners
rr toe in shimmed in the back 2 corners 3 degree in
wheel base spacers are fine
the car does sticks to the ground-awesome handling so far
the only obvious thing i saw was not all the arm mounts had the dots facing out-i relooked at the maunal and it indicated the arm mount's dots face outwward. does that matter? any other ideas?
poochy is offline   Reply With Quote
Old 10-09-2008, 11:01 PM   #7554
Catalyst's Avatar
Have you used a tweak board or scales to see if your weight is balanced with that LiPo? I don't have experience with a Maxamps 6000 to know how it weighs vs. the electronics side but if you haven't added weight to the LiPo side it will typically be several ounces lighter than the side with the motor which might be causing it to pull left on acceleration.
I run the PPD Billet base plate and side weight with my SMC packs and it makes it much easier to get balanced left to right and it's pretty close to dead on front to back as well.
Catalyst is offline   Reply With Quote
Old 10-10-2008, 03:02 AM   #7555
fathead's Avatar
Yes it definitely makes a difference!
All the mounts should have the dots pointing out, if they aren't the car will be different widths on either side.
Slavich Design
fathead is offline   Reply With Quote
Old 10-10-2008, 09:45 AM   #7556
poochy's Avatar
it was the arm mounts!!!! others might want to know this since it is easy as heck to install it wrong.
thanks everybody!
Old 10-10-2008, 02:58 PM   #7557
Trader Rating: 21 (100%+)
I would double check the nut sitting in the T like Kraig said. I thought they were to short also until I got it seated all the way down.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 10-10-2008, 05:32 PM   #7558
The pull to the left is related to slop between the servo saver tube and the steering bell crank. The hex shaped nut is loose. I used epoxy to bond the two together to eliminate this issue. Search my posts for more details.
Dave
AE TC5R, GTB, SS13.5
AE T4FT
RC_DAVE4 is offline   Reply With Quote
Old 10-11-2008, 05:05 PM   #7559
losithrasher's Avatar
how do i get losi 57 pistons to work, they are 2 small to fit on the shaft of my tc5 shocks and my trf shocks.
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 10-11-2008, 05:21 PM   #7560
Maybell's Avatar
you must have the wrong ones....its the offroad losi pistons that you need...for example, losa5046 is the part number for the correct #56 pistons...
you must have the JRXS pistons that wont work
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
