Old 10-03-2008, 12:24 PM   #7486
poochy's Avatar
the mamba will cut itselft off around 250.
your setup should overheat - i say drop down to between 14-16 pinion.
poochy is offline   Reply With Quote
Old 10-03-2008, 12:28 PM   #7487
poochy's Avatar
btw, how much drag braking do you guys use on the mamba for asphalt racing?--say on a normal track.
ive asked around and heard not to use drag brake-but I sort of disagree.
Old 10-03-2008, 12:38 PM   #7488
carbon madness's Avatar
I don't run any drag brake any any of my cars (that inclueds my off-road cars). Once you get the hang of the way the car rolls at neutural throttle then you will be able to run some fast laps, other wise I would say if you want to use the drag brake as a fail safe when driving in to the turn, then it might help for if were to get into a lot of dust, or if the track is very loose (but a set-up change will help that).
Your best bet is not to use it, but at the same time it is a great way to learn to drive as as your car will slow down a little faster so you can hold a tight line a little better. Also the drag brake will cause things to heat up, and heat will slow you down durring the run.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 10-03-2008, 03:26 PM   #7489
Hide's Avatar
I noticed that without a drag brake it was easier to get fast laps (different ESC though). I prefer to keep of the brakes and just let the car coast (of course braking manually if I need to) when cornering.
Losi 8ight-E 2.0, LRP Shark, Xray M18T custom extended, Traxxas VXL Revo
Hide is offline   Reply With Quote
Old 10-03-2008, 06:19 PM   #7490
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
My drag brake is set at 10% and where running on asphalt. If I go to a 14 or 16 Will I have allot of bottom end ?
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 10-03-2008, 09:08 PM   #7491
poochy's Avatar
you can probably put a 6 pinion on that 7700 and still have more than enough top/bottom end
Old 10-04-2008, 05:15 AM   #7492
robk's Avatar
Trader Rating: 22 (100%+)
To be honest, the car will get faster with more drag brake most of the time. Start w/50%, watch the lap times, and go from there.
Old 10-04-2008, 05:26 AM   #7493
poochy's Avatar
drag brake advice - please keep them coming!
i am also running a mamba 7700-i think you need to set drag brake if you are running mod class-maybe not the other classes-am i right or wrong?
Old 10-04-2008, 01:54 PM   #7494
Scottmisfits's Avatar
I ran the kit with the box stock set up last night for the first time with rubber on carpet. I ran 13.5 and the body I was using was the Protoform R9R. I ended up lengthening my down travel (reduced droop?) both front and rear and changed the sront springs from blue to silver for silver all around. I was looking for a little more rear grip low speed. I have been reading alot of the R9R body saying that might be a big part of the problem. Try another body, which I have, or just play with set up some more? What would you guys do first?
Scottmisfits is offline   Reply With Quote
Old 10-04-2008, 03:45 PM   #7495
Johnny Wishbone's Avatar
You can't go wrong with the Mazda6 on rubbber/carpet. Give it a try. You could also try moving the rear wing around, I'm playing with that right now with foam on carpet, but same sort of issue.
Old 10-04-2008, 05:02 PM   #7496
I've already changed the wing getting ready for our practice day. Then I'll be changing bodies to see how much of a difference it will really be.
Thanks Johnny Wishbone. Hopefully see you in a month or so.
Old 10-04-2008, 05:47 PM   #7497
artwork's Avatar
Trader Rating: 59 (100%+)
Josh H's vegas setup is good...give it a try.
Silver in the front and green's in the rear...
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 10-04-2008, 06:00 PM   #7498
I have that set up as well. But if you look he's running the Mazda 6 body. I think most of my problems are coming from the body, with the current set up I have. I'm chasing this set up down at the moment, and the next logical step for me in the set up is the body.
Old 10-04-2008, 06:07 PM   #7499
artwork's Avatar
I have run something very close to Josh's setup with a Speed and the new R9R. I dropped 6 tenths with the R9R no changes to setup only a couple of less clicks with Dual rate.
Old 10-04-2008, 06:14 PM   #7500
Maybe I'll try that after the body change. I went from 100% down to 60% on my dual rates trying to control the back end. I lost way to much initial and exit doing that and the the back end would still be unpredictable for me. I think I enev have a mohawk body I could try.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
