Old 10-01-2008, 10:51 PM   #7456
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
http://www.nexusracing.com/newsdesk_...newsdesk_id=60
still the best way to mount them IMO. Of course, ignore the first half and skip down to "tip 1"
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 10-01-2008, 11:01 PM   #7457
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by eddie10 View Post
How is the hard cased lipo such as trak power or reedy insalled so it doesnt fall out. I can see the orions working because of the bottom is contoured like a 6 cell pack?
Forget the humps keeping your battery in with the Orions. Your better off sanding them off and using a baseplate. We carry a 3oz baseweight in stainless steel for $22.00 that several of the AE team members are running. You'll need a small amount of side weights on the outside of the pack that will also help you use less total weight to balance being outside the battery.
http://www.ppdbillet.com/RC_accessories.html
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-02-2008, 05:22 AM   #7458
cdee's Avatar
Originally Posted by John Schoenauer View Post
I just received my LiPo weight from Manutech. The machine work is impressive. Excelent fit in the chassis. Chris Doerr has been good to buy from. Link to his site. Chris Doerr [cwdoerr@yahoo.com]
Thanks John Schoenauer
john... thanks for the feedback, and glad that you like it! ... cdee
cdee is offline   Reply With Quote
Old 10-02-2008, 11:09 AM   #7459
Hide's Avatar
Do you guys use tape or the stock battery strap to hold down LIPO's? The Strap seems very tight when I used it and on one occasion the battery fell out.
Losi 8ight-E 2.0, LRP Shark, Xray M18T custom extended, Traxxas VXL Revo
Hide is offline   Reply With Quote
Old 10-02-2008, 11:11 AM   #7460
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
The strap doesnt work well at all, and it can cause chassis tweak when tightened down. I have been using the diggity lipo brace and CF strap, and both my Checkpoint 5400 lipos have shifted and the cases cut by the belt. I will be using tape instead....
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 10-02-2008, 11:23 AM   #7461
Trader Rating: 38 (100%+)
I have both and have had neither of those problems. You have to make sure you shim up the diggity holder and strap holders. I think its 1.5MM but I would need to double check. The battery won't shift and you won't get tweak in your chassis (I have the PPD Tweak Plate and have checked on there).
or8ital is offline   Reply With Quote
Old 10-02-2008, 11:40 AM   #7462
artwork's Avatar
Trader Rating: 54 (100%+)
Good quality tape is the only way to go...
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 10-02-2008, 12:51 PM   #7463
Verndog's Avatar
The batttery strap can be used but it must be set correctly as posted. There are those that claim tape only, and it likely is the safer alternative, especially if the strap isn't set correctly.
The strap must be straight, not at all bowed when you tighten. This means just touching or just off the top of battery. Once you induce bow into the strap, it will bow further on impact and risk loosing batteries, especially Nimh's. I've hit the wall 4ft off the ground off a dot at full speed and driven my TC5 away (using strap)...and finished the race.
---Team Hoarders---
Old 10-02-2008, 01:01 PM   #7464
Orbital, I shimmed the diggity brace as well since I am using the PPD Lipo weights. Verndog, I have had quite a few hits as well where all is fine, still, there are times when the battery jumps the lipo brace. I have found that with or without the Diggity brace, my battery strap does not line up with the thumbscrews. This also was causing some tweak problems.
Old 10-02-2008, 01:31 PM   #7465
Im using the PPD lipo weights as well. My diggity holder is shimmed high enough that I can't imagine a scenario where it could jump out. Even if I wasn't running the battery strap it would likely stay in the car. I will try to post pictures of my setup. Sounds like I have everything you do (Diggity, PPD base weight, Checkpoint Battery (technically I have the Trakpower Version)).
Old 10-02-2008, 01:58 PM   #7466
Hide's Avatar
Well I am also using the PDD weights. I think that my problem was that the guy I bought them from taped the plate to the chassis, when I think it should be on the LIPO. Am I correct? If so I need another since I have two batteries.
I'm actually racing the M18B this week because I blew my ESC for the TC5. Does anyone know how I send an LRP speed control for a repair?
Old 10-02-2008, 02:07 PM   #7467
If you are using the PPD weight and not using the Diggity brace then the weight should be attached to the battery. If you use the diggity brace then the weight can be attached to the chassis. Either way you need to make sure the strap is shimmed property. If should barely touch the battery or sit slightly above the battery. It just keeps it from falling out if the car were to turn upside down. It doesn't really hold it in the car.
Old 10-02-2008, 02:10 PM   #7468
poochy's Avatar
wrap tape around the battery strap and lipo-taping them as one unit-never fails or comes loose
poochy is offline   Reply With Quote
Old 10-02-2008, 02:10 PM   #7469
Hide- Here you go: Link
Old 10-02-2008, 02:20 PM   #7470
Hide's Avatar
I bought it from Amainhobbies from the UK. Do you think they would let me send it from here?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
