Old 09-25-2008, 01:21 PM   #7426
nutsisneat's Avatar
Hello all
I have a problem with bump steer. I have changed to short camber links in the front due to high grip (camber link pos. 4 instead of 3). It seems that i have now a lot more bump steer. Where do i have to add shims to avoid this?
I have added a shim on the C-Hub, it has limited the suspension travel but not much the bump steer.
With the long link, i had virtually no bump steer...
Any ideas?
nutsisneat is offline   Reply With Quote
Old 09-25-2008, 03:12 PM   #7427
BobbyS's Avatar
Originally Posted by treemagnet View Post
hey everyone
im going to race 540 soon and need some advice on gearing. wat would be better start a 69 tooth or 72 tooth spur 48p?? and also would 32 pinion and 69 tooth reach each other??
thanks
treemagnet
The stock 72 tooth spur should work fine.
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 09-25-2008, 03:22 PM   #7428
fatbear's Avatar
Send a message via Yahoo to fatbear
Originally Posted by fatbear View Post
And where on the web is the best place to get titanium screws for the TC5?
Has anybody got any answers for this question?
fatbear is offline   Reply With Quote
Old 09-25-2008, 03:30 PM   #7429
Trader Rating: 38 (100%+)
Here you go
or8ital is offline   Reply With Quote
Old 09-25-2008, 04:00 PM   #7430
Default TC5
Treemagnet : you will also need to get a drill to the top slot of your motor mount just a very light skim so the motor screws lineup for a silver can.
72 spur is fine -if your track is about or bigger than 2 tennis courts run about 4.1 with a few straights if its tight hairpins etc 4.2 -4.3
If you have a motor cooler use it.
Oil the bushings everytime you run the motor.
Good luck
yeahyeah is offline   Reply With Quote
Old 09-25-2008, 06:05 PM   #7431
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by nutsisneat View Post
Hello all
Any ideas?
Shim on the c hub like caster block or the steering knuckle?
If you are having bump steer issues, you need to add spacers under the ball stud on the steering knuckle. Usually this is more due to a change in caster.
Old 09-25-2008, 10:34 PM   #7432
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Hello everyone this is my first electric car I run 1/8 scale, Im setting my car up and its asking for droop I dont know if droop is the same as downstops, I just need to know how to get the right droop
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 09-26-2008, 01:34 PM   #7433
robk's Avatar
The amount you can lift the chassis up past ride height before the wheels leave the ground is droop.
Old 09-26-2008, 06:04 PM   #7434
geeunit1014's Avatar
yes and no. if your running rubber tires where the tire size doesnt change, you can use the downstop gauge to meaure droop, because the downstop value will produce the same chassis travel for all rubber tires. If your running foams, you will want to measure the chassis travel above ride height in mm for droop, because the downstop value will be diffrent for diffrent sized tires. you can also use the foam method on rubber tires (i do this, more convienient to measure than taking the tires off and busting out the downstop gauge.)
geeunit1014 is offline   Reply With Quote
Old 09-26-2008, 08:30 PM   #7435
Thanks allot I ran my car today and its handles like it's on rails, really fun and fast
Old 09-26-2008, 08:36 PM   #7436
Maybell's Avatar
Just in my opinion Lunsford Ti screws are the best...they do have a set for the TC5, but you have to order it directly from them...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 09-27-2008, 04:25 PM   #7437
nutsisneat's Avatar
How much weight will you save with a complete set of titanium screws?
Approx? (in grams please..)
Old 09-27-2008, 05:13 PM   #7438
decibels's Avatar
for every 10 to 15 screws you save about 10 grams, it just depends on how many screws you have! but dont bother with titanium screws because with lipo coming in you will need to add 200 grams to your car! and if you still want to put some put them up high so you can add weight down low to give you better centre of gravity. and try to keep your weight in the middle, faster reactivity, and the rest ude to balance left to right. and prob get a lipo tray as it helps add wieght under the battery because you may run out of room to put weight every where else. hope this helps you. And if you dont have lipo go roar legal packs, gauranteed quality and safety!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 09-27-2008, 06:28 PM   #7439
Victory Side's Avatar
Send a message via Skype™ to Victory Side
Thanks for the help and for recommending ppdbillet.com I am having troubles balancing and think this will help.
WWW.RICHFIELDRACEWAY.COM
"There are only two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle." ~Albert Einstein
"Do you want to know who you are? Don't ask. Act! Action will delineate and define you.'
Victory Side is offline   Reply With Quote
Old 09-27-2008, 07:27 PM   #7440
poochy's Avatar
Hi, I just orderd the TC5R-314.99 at highvelocityracing.com with 10% discount-til 9/30. Is that a good deal?
Can somebody please tell me what is a good pinion to start with on the stock tc5r-48 pitch 87T spur. I will be running a Mamba Max 7700 with Maxamps 2s 6000mah lipos on the tc5r.
Thanks!
poochy is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
