Old 09-24-2008, 06:26 PM   #7411
http://www.aps-racing.net/
It is not listed on their website but they have a bearing kit for the tc5 !!
even their std bearing are very good quality.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 09-24-2008, 06:52 PM   #7412
Trader Rating: 38 (100%+)
If your local hobby shop can get the Speedrex tires then I think the APS bearings come from the same place. Might be worth asking.
or8ital is offline   Reply With Quote
Old 09-24-2008, 06:52 PM   #7413
mtbboy's Avatar
Default Tc5r
Kevin H.
I am ordering a tc5r .
What are some must have spares I should get as well?
Are there any upgrdes youre recommending right off the bat?
Dave.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 09-24-2008, 07:23 PM   #7414
carbon madness's Avatar
As for extra parts too look in to right away, I posted this about 5 pages back, but it is a great place to start for getting extra parts. (take it from me, I currently break more then Keven )
Originally Posted by carbon madness View Post
For parts I would stock up on castor blocks, steering blocks, a few a-arms, arm mount nuts, and the bushings that go in the castor blocks. Then later get more parts for if you might ever need them (and so you can keep running later in the day if you break early in the day). Also a few extra bearings wouldn't be a bad idea as well as a screw kit, and extra ball studs.
As for upgrades, the car IMO doesn't need any, but I would get a AE spring kit (it might say for the TC3, but it is the same thing), and then I would look a few set-up's that you might want to try running and get those shock oils.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 09-24-2008, 07:37 PM   #7415
yodace's Avatar
R/C Tech Charter Subscriber
New to the TC5R.. I had a similar problem this past weekend. With a loose rear-end. How do u get more rear toe in...?
yodace is offline   Reply With Quote
Old 09-24-2008, 07:48 PM   #7416
You can add spacers to the rear arm mounts or get some 0.5 or 1.0 degree toe in rear hubs.
itchynads is offline   Reply With Quote
Old 09-24-2008, 08:00 PM   #7417
Originally Posted by mtbboy View Post
Kevin H.
Dave.
Hi Dave,
I don't think you need any upgrade for the car. As for spare parts, CarbonMadness covered it all except I would get some more blade for the cvds.
As far as setup goes, there are 2 setup from the IIC on www.rc10.com and you can also take a look at Josh Hohnstein setup it should be a very good sart but I think he ran a one way.
hope this help ! Let me know if you have any question
Keven Hebert
Old 09-24-2008, 08:04 PM   #7418
you can add more rear toe from the rear hub or you can add from the arm mount by adding shims in between the bulkhead and the arm mount. You have to be carefull because if you use too many shims you will want a longer screw to make sure it won't fall off.
In your case, I would had toe from the arm mount because from the hub will generaly make the car steer more in the middle of the turn compared to more toe on the arm.
Another thing you might want to try is going to a longer rear link. (outside on the rear hub ) that will give you more roll in the rear and won't square up as fast and should be easier to drive.
Keven Hebert
Old 09-24-2008, 08:15 PM   #7419
fatbear's Avatar
Send a message via Yahoo to fatbear
And where on the web is the best place to get titanium screws for the TC5?
fatbear is offline   Reply With Quote
Old 09-25-2008, 04:35 AM   #7420
treemagnet's Avatar
Trader Rating: 17 (100%+)
Default tc5
hey everyone
im going to race 540 soon and need some advice on gearing. wat would be better start a 69 tooth or 72 tooth spur 48p?? and also would 32 pinion and 69 tooth reach each other??
thanks
treemagnet
treemagnet is offline   Reply With Quote
Old 09-25-2008, 04:48 AM   #7421
katfish317's Avatar
Originally Posted by treemagnet View Post
hey everyone
thanks
treemagnet
What wind motor, brushed or brushless???
katfish317 is offline   Reply With Quote
Old 09-25-2008, 04:52 AM   #7422
treemagnet's Avatar
Default tc5
just a silver can motor....
Old 09-25-2008, 07:28 AM   #7423
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
If it's a stock motor, you're gonna wanna be around 7 to 7.5 final drive. I believe the internal ration on the TC5 is 2.6 (Keven or Josh can correct me if I'm wrong). So, I don't remember what the stock spur is (as I have changed mine because i run a brushless) but a 69/24 would give you 7.475 (69/24 * 2.6). you could go up to a 25 tooth pinion and probably be ok. I'm not sure how well that would work as far as space and fitment, but that's a start.
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 09-25-2008, 07:30 AM   #7424
revo61's Avatar
Trader Rating: 18 (95%+)
Internal Ratio is 2.0. You can go to gearchart.com and find what gears would give you 7.0 - 7.5.
revo61 is offline   Reply With Quote
Old 09-25-2008, 08:39 AM   #7425
AssocRacer's Avatar
Alright then, you'll have to readjust your gears with the new internal ratio
Lots O' Planes
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
