Old 09-23-2008, 12:51 PM   #7381
Hide's Avatar
Wow its lucky I only put a tiny drop on the motor screws. I also did the mount but that was lightly too, except for one where a little bit more came out. Should be okay I hope.
Losi 8ight-E 2.0, LRP Shark, Xray M18T custom extended, Traxxas VXL Revo
Hide is offline   Reply With Quote
Old 09-23-2008, 02:54 PM   #7382
geeunit1014's Avatar
I have a general setup question -
running foam tire on carpet, my car is dialed in the high speed portions of the track, but in the slower corners, the car pushes, and it wants to lift. any ideas on how to get rid of it(ilfting) without making the car a total dump truck?
geeunit1014 is offline   Reply With Quote
Old 09-23-2008, 03:05 PM   #7383
artwork's Avatar
Trader Rating: 56 (100%+)
Try some more droop and some sway bars...
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 09-23-2008, 03:07 PM   #7384
carbon madness's Avatar
Hide, blue loc-tite is the best thing to use if you want to use any (same thing as AE's stuff). Also you can get loc-tite form any hardwhere store, or department store (like wal mart, in the auto section)
is one side of it lifthing (left or right side when in the turn), or is just a corner of the car lifting.
If it was the first thing I said, then balance your car, and check to see if there is a tweek in it (check to be sure everything is equal, or blanced). If it is the 2dn thing I said, then I really don't know, but I think it could be that your car is too soft.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 09-23-2008, 03:36 PM   #7385
The only other places (besides where the manual states) I use BLUE loctite are on the tiny screws that hold the hinge pins in place, the screw on the chassis side for the steering bell crank post (so when tightening the screw on the top deck you don't loosen the bottom screw) and the screws in the blue wheel hex's.
Dave
AE TC5R, GTB, SS13.5
AE T4FT
RC_DAVE4 is offline   Reply With Quote
Old 09-23-2008, 03:40 PM   #7386
more droop will make the lifting problem worse, sway bars in this case are not an option
it lifts on both left and right hand corners, so i dont think its out of balance or tweaked. The car isnt too soft, i have stiff springs on it (car in this case isnt a TC5, but ive seen alot of useful setup tips here, thats why im asking here)
Old 09-23-2008, 05:44 PM   #7387
Trader Rating: 46 (100%+)
i got 2 tc5s for sale check sale section
josh short is offline   Reply With Quote
Old 09-23-2008, 07:22 PM   #7388
yodace's Avatar
R/C Tech Charter Subscriber
Whats the part number for the mugen wheel nuts(grey)? also whats a good place to get wheel bearings?
yodace is offline   Reply With Quote
Old 09-23-2008, 07:27 PM   #7389
fathead's Avatar
Is it lifting both inside tyres, or just the front or the back, and when is it lifting, into/out of the corner, on/off throttle?
Slavich Design
fathead is offline   Reply With Quote
Old 09-23-2008, 07:59 PM   #7390
artwork's Avatar
mugen b0716 for the locking nuts
Avid or boca bearings is a good place to get bearings
Old 09-23-2008, 08:01 PM   #7391
it lifts both (but never rolls), going into slow corners (off power).
Old 09-23-2008, 08:10 PM   #7392
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
raise both roll centers maybe? Why are sway bars not an option?
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 09-23-2008, 09:02 PM   #7393
mtbboy's Avatar
Sorry to barge in here guys but is it worth buying the TC5R?
Or
Should I get the foam edition and make some subtle changes so as to use it for rubber?
I would like the option of running both competitively.
How has the "R" been in your opinions?
Dave.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 09-23-2008, 09:19 PM   #7394
artwork's Avatar
Or
Dave.
Great car...best car out for the money. If you are going to run rubber tire get the TC5R, if you want to run foam get the TC5F. Each can be converted to the other with a little bit of work and the opposite chassis setup.
Old 09-23-2008, 09:37 PM   #7395
Its an xray M18. atomic makes one, but id have to find a couple sets... pretty much im limited to springs/mounting options, tires/trackwidth/ca, toe, caster, ackerman, droop, diffs, and ride height.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
