Old 09-17-2008, 09:24 PM   #7306
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Use the small thrust balls (like you were building a diff) and then put a little lock tight on the diff screw. The spool pads take the place of the diff balls in the diff pulley. Then you should be all set.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-18-2008, 02:59 AM   #7307
Default Tc5
How do you fix the front CVD from shudder besides turning the rate down.
I have my steering rate set at about 65% on the TX.
Blue springs front sliver rear and 40wt all round.
Basically am wanting more steering.
yeahyeah is offline   Reply With Quote
Old 09-18-2008, 06:19 AM   #7308
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
try running a shorter front link and dont dial up more dual rate or you will have to much of a slip angle and chatter the cvds.It is always better to get more steering from a suspension geometry change not by dialing in more steering.
hope it helps
warren
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 09-18-2008, 10:13 AM   #7309
Yeahyeah- one thing that helps quite a bit is if you glue a shim ( the one from the lower roll center to space out ) on the steering block so it hits the caster block. you won't loose steering throw, but it will help a lot with the chatter. I usually use the thin one
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 09-18-2008, 10:58 AM   #7310
If anyone wants a longer differental screw to make building/maintenance easier, order P/N 91251A109 from Mc Master Carr (www.mcmaster.com).
$3.94 for 25 ea. Cap Screws, 2-56 x 1", black oxide, alloy steel.
Dave
AE TC5R, GTB, SS13.5
AE T4FT
RC_DAVE4 is offline   Reply With Quote
Old 09-18-2008, 01:39 PM   #7311
Trader Rating: 38 (100%+)
Originally Posted by nutsisneat View Post
I'm running out of JAAD-Outdrives so i have to give the
AE Slipper-Spool a try now.
Question: i read somewhere that there is a better way to build the spool than
following the manual (to prevent from slipping).
Your thoughts on this?
Thanks....
Im not sure why some people say to use the thrust balls when building it. That doesn't make sense to me. For me I just used the old TC3 styule t-nut (the white one) with blue loctite and it holds very well.
or8ital is offline   Reply With Quote
Old 09-18-2008, 01:52 PM   #7312
AE-Reedy
The reason we started adding the diff balls is so the 2 diff halves are isolated.
If you hit something on the power and one side slips it can twist the screw and this results in the loosening. With thrust balls installed the slip force isn't transfered to the diff screw.
Sean Cochran is offline   Reply With Quote
Old 09-18-2008, 04:41 PM   #7313
Gain Time's Avatar
Originally Posted by decibels [View]
short links give you quicker response and more initial turn in but less mid corner. long links give you more roll which equals grip in the middle of the corner!! but you get less response! so he is running short link on front to get the initial response because he is running soft springs and he is running the long link on the rear to create an off balance which causes rotation, which is similar to generating more mid steering but with a stable feel! and he is using the higher rear roll centre to make the car again more stable but it also lets the front move around happily which is more or less the balance he feels happy with!!
Originally Posted by Josh H View Post
Couldn't have said it better myself.
So I take it the rear camber link is 3B?
The sheet didnt say where to put the rear ball stud and shim.....either that or I missed it.
Thanks.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 09-18-2008, 04:45 PM   #7314
Thanks.
In vegas I used the a-hole..........boy that sounds bad
Josh Hohnstein is offline   Reply With Quote
Old 09-18-2008, 04:57 PM   #7315
Does anyone know if these are the same lock nuts used in the TC5 diff?
http://www3.towerhobbies.com/cgi-bin...9&I=LXXG90&P=K
AE T4FT
Old 09-18-2008, 05:07 PM   #7316
Gain Time's Avatar
uhhhhh.....Yep that does sound bad.
Thanks. I have been running this car foam but I want to try a some rubber for awhile. thanks again.
Old 09-18-2008, 06:35 PM   #7317
katfish317's Avatar
That's funny!
katfish317 is offline   Reply With Quote
Old 09-18-2008, 06:45 PM   #7318
AE-Reedy
I didn't see the AE # but if it is a 2-56 aluminum lock nut it will work for the TC5 diff.
Old 09-18-2008, 08:25 PM   #7319
Not true, it depends on how big the hex is on the lock nut. The TC5 hex nut is really small compared to a typical 2-56 lock nut.
Dave
AE T4FT
Old 09-18-2008, 10:21 PM   #7320
Verndog's Avatar
Trader Rating: 16 (100%+)
Dave
Actually it is true. I'm running those exact lock nuts. They are TC3 locknuts and fit perfect. PN ASC3904.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
