Old 09-10-2008, 01:43 PM   #7246
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
To continue with the shock building skills, Juho posted this on the AE Forum.
Normally no rebound means that when you push the shock shaft in it stays in. 25% would mean that is comes out about 25% of its lenght. The easiest way to get the rebound you want is to build the shock shaft as far in as you want it to end up. For example, press it in half way, place the bladder on the shock and press it down so all the extra oil comes out. The place the black plastic piece on the bladder and carefully put the blue collar on.
When the bladders get old they tend to swell up a bit and that can make the shock a bit difficult to build.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-10-2008, 02:55 PM   #7247
Originally Posted by artwork View Post
In Vegas I was running 94/41 with the Novak 13.5 with a rubber tire car. The 94 was a Precision racing systems spur!
17.5 I was running 94/50 and they all fit just fine.
I have a PRS 96 spur and I am having problems getting it to spin free without rubbing the top deck. The center of the PRS is thicker than the stock gear.
gfarb is offline   Reply With Quote
Old 09-10-2008, 02:58 PM   #7248
Trader Rating: 26 (100%+)
im hearing alot of talk about 17.5s. how are they comparing to a stock brushed motor? and which ones are performing well
eddie10 is offline   Reply With Quote
Old 09-10-2008, 03:20 PM   #7249
KHoff7's Avatar
The 17.5's are a stock equivalent, some say a tic slower or faster. Pretty much all of them are good but I would say the new trinity motors are the fastest.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 09-10-2008, 07:09 PM   #7250
katfish317's Avatar
You will need to back the screws out of the spur gear as they are pulling in too tight, just put some blue thread lock on them and snug up the bolts, they should be fine. I have had the same problem and that fixed it!!!
katfish317 is offline   Reply With Quote
Old 09-10-2008, 07:11 PM   #7251
katfish317's Avatar
I have run both and have found out that on a longer track that brushless 17.5 is the better motor especially when you go up to seven and eight minute manis. You do not have to worry as much about heat with them, and yes the Trinity motor with the vented can is alot better temprature and power wise from my personal testing.
Old 09-10-2008, 08:37 PM   #7252
MR1035's Avatar
Trader Rating: 29 (100%+)
Default Spur gear
I had that same problem when I built my TC5, I took off a very small amount of the inside edges of the top deck with a file and it fixed the problem...
MR1035 is offline   Reply With Quote
Old 09-11-2008, 01:39 AM   #7253
Thanks to all who posted about shock rebound I will be trying this out. All my shocks are built the same way, shaft all the way out, fill up with oil, put bladder on - checking for no air bubbles under it - and screw cap on. This results in - since I tested it - about 90% rebound. I see most people like between 25% and 50% so I will try and get this feel in them now.
Interested to know what I should feel in the car with this new set up, I will be running it tomorrow indoors and will post what I think I feel.
Thanks again all of you
hedge1970 is offline   Reply With Quote
Old 09-11-2008, 02:27 PM   #7254
artwork's Avatar
Trader Rating: 56 (100%+)
Anyone got a good alternative to the stock diff thrust bearing?
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 09-11-2008, 02:57 PM   #7255
Trader Rating: 38 (100%+)
Tamiya pre-built with the HPI t-nut and screw. It will be very smooth.
or8ital is offline   Reply With Quote
Old 09-11-2008, 03:09 PM   #7256
artwork's Avatar
do you have a part number on those?
Old 09-11-2008, 04:56 PM   #7257
HPI73522
TAM9949300
Old 09-11-2008, 07:10 PM   #7258
Ty
Ty's Avatar
My TC5 is for sale in the for sale threads. Please let anyone know who is interested please. Thanks.
Ty is offline   Reply With Quote
Old 09-11-2008, 07:21 PM   #7259
MR1035's Avatar
Default Shocks
Originally Posted by robk View Post
In addition, before step #1, put the spring retainer on the bottom of the shock. Then in step #4, push the shaft all the way in. It usually results in perfect rebound. Credit Brian Jucha for this tip.
Thanks for this tip I tried it and it worked great!!!
Old 09-11-2008, 10:52 PM   #7260
decibels's Avatar
tamiya one is no good go to precision rc and look at the jade ones they are about 10 dollars each and are ceramic! these are the best i have seen or used for the price!!! my brother swears by them for mod!!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
