Old 09-07-2008, 09:21 AM   #7186
BobbyS's Avatar
Thanks robk and decibels! I got some crush tubes yesterday at the lhs and have everything back together now. I'll keep a look out for bearing wear this time! Other than that though, this is the most dialed car I've ever had!
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 09-07-2008, 11:24 AM   #7187
Verndog's Avatar
Trader Rating: 16 (100%+)
Default Setup plate
I had many requests for a TC5 setup plate. I have just completed the first run. These are working very well on the Mi3 and were tested at the IIC with great reviews. Besides removing tweak it can be used for accurately checking droop, working on car, storeage and travel.
As many know, the ITF (2mm rubber type R) chassis is awesome on asphalt, but susceptible to tweak (twist front to rear). It also works equally as well on the 2.5mm chassis. Problem is solved with the bulkhead holes that go thru the plate so you can tighten from underneith while clamped dead flat (loosen bulheads / top deck before loading and clamping). Clamp system mounts in under 1 minute making for fast inspection of chassis after a hard hit.
I have limited quantities and prob. will be some time before we run these again.
More info on the webpage.
http://www.ppdbillet.com/associated_tc5.html
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 09-07-2008, 11:44 AM   #7188
Maybell's Avatar
And can also be used as a chassis caddy!
I must have one! Great work Verndog!
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 09-07-2008, 11:55 AM   #7189
Verndog's Avatar
No problem...I have at least 2 set aside for you and Keven Hebert....if you can make Wednesday I can bring it.
---Team Hoarders---
Old 09-07-2008, 12:21 PM   #7190
Trader Rating: 38 (100%+)
Will it work without the middle hold-down? I have my ppd base plate shoe-gooed into my car.
or8ital is offline   Reply With Quote
Old 09-07-2008, 12:38 PM   #7191
Verndog's Avatar
Yes it will. The important areas for clamping are the corners near the bulheads and arm mounts to be flat and parallel end to end. The center clamp was added just to assure a small center bow gets pulled down, but that should not effect the more important mount ends of chassis.
---Team Hoarders---
Old 09-07-2008, 02:18 PM   #7192
Trader Rating: 26 (100%+)
im going to be running carpt rubber for the first time. am i to use a one way or a spool and whats the difference
eddie10 is offline   Reply With Quote
Old 09-07-2008, 02:34 PM   #7193
yodace's Avatar
R/C Tech Charter Subscriber
what are u guys doing to stop the robison spurs from rubbing on the top deck?
yodace is offline   Reply With Quote
Old 09-07-2008, 02:58 PM   #7194
geeunit1014's Avatar
the diffrence is, the spool is a full time solid axle, and the one way is a solid on power, but lets the tires free wheel off power (no front brakes) what you should run depends on the track conditions, what class your running and how your driving style is. lower bite youd generally run a spool, higher bite a one way. also, i tend to see more people run one ways in stock than mod. a solid will be easier to drive if its your first time out, but dont be suprised if a one way is the ticket
geeunit1014 is offline   Reply With Quote
Old 09-07-2008, 03:08 PM   #7195
Trader Rating: 23 (100%+)
hey guys, just got my car on the track for the first time today. looks great. my problem is that the car, every time i go thru a corner the car slips and does like a 270 degree spin or more. the diff and ride hight are set and the camber. (i am on carpet) ive slimmed it down to the tires just being worn. any of you have any other suggestions that may help my problem?
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 09-07-2008, 03:41 PM   #7196
Maybell's Avatar
Since you mentioned that you are running old tires...Are the sidewalls of those tires glued REALLY well? It is important to check and touch up the gluing on rubber tires often. I check them every run.
I ask this because before we get into your chassis setup it is good to eliminate these kind of problems first...
Old 09-07-2008, 04:33 PM   #7197
they are on there, havent used in a week or 2. maybe they just need to be cleaned extremely well and get some of my grip restorer on it.
Mike Adamec
Trackside Hobbies
Old 09-07-2008, 05:54 PM   #7198
should i be using a carpet body or asphalt body?
Old 09-07-2008, 06:09 PM   #7199
yodace's Avatar
is a fdr of 4.1 to low for 13.5 100X50 sprayed asphalt
ran a 66 spr with a 35p 3.77 motor temp was 195 degrees, which they said was to high,,,
should i file down the top deck to keep the spur from rubbing> or just get a kimbrough spur 66
Old 09-07-2008, 06:21 PM   #7200
most people who run carpet/rubber use rubber tire bodies, ie mazda 6, mazdaspeed 6, etc.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
