Old 09-05-2008, 11:16 PM   #7171
BobbyS's Avatar
Originally Posted by Sean B. View Post
Diggity Designs makes them.
Excellent quality for a good price.
http://www.diggitydesigns.com/D3_OnR...iated_TC5.html
Thanks, Sean! (And great prices on the bearings!)
But hey, with all this talk about bearings can anybody tell me why/how they're getting THRASHED with normal running? I just tore down my rear hubs because of a noticable wobble in the right rear and the bearing was completely shredded, the crush tube was scored about half-way through and the hex adapter was so gouged I couldn't use it either. What is causing this!? I just now replaced the two outer bearings on both rear hubs with some Tamiya metal shielded bearings I had and need to come up with a crush tube, but I don't think I can afford (or want) to run this car if I have to replace these parts every couple of weeks.
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 09-06-2008, 04:12 AM   #7172
decibels's Avatar
are you running the spacers in between the bearings which makes them a bit stronger cause so far i havnt had any probs and i have whacked a couple of walls in the side that are pretty solid.
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 09-06-2008, 09:18 AM   #7173
AeRacer805's Avatar
Originally Posted by AeRacer805 View Post
Is anyone using a futaba 9551 or 9550 for their steering servo??? What spacer did u use when u mounted the servo.
Is anyone running one of these servos
"When you are not practicing someone else is and when you meet that person they will beat you."
TC6, Top Photon, B4.1, SC10 FT, Orion Motors and Servos, Tekin RS
AeRacer805 is offline   Reply With Quote
Old 09-06-2008, 09:43 AM   #7174
Catalyst's Avatar
I'm running the S9551 and no spacer. Just mounted the servo to the aluminum mount with a small washer included in the servo hardware between the screw and the servo tab.
Catalyst is offline   Reply With Quote
Old 09-06-2008, 10:10 AM   #7175
AeRacer805's Avatar
Thank you Catalyst
Old 09-06-2008, 01:18 PM   #7176
Hide's Avatar
Does anyone know what part number the screws are for holding the associated battery posts to the chassis are? And for the top ones too?
Is it worth using ca glue on the edges of the battery strap?
Thanks, Jacob.
Losi 8ight-E 2.0, LRP Shark, Xray M18T custom extended, Traxxas VXL Revo
Hide is offline   Reply With Quote
Old 09-06-2008, 01:59 PM   #7177
BobbyS's Avatar
Unhappy
Yes, the spacers are there, someone reported the problem a while back on this thread.
Old 09-06-2008, 06:41 PM   #7178
Trader Rating: 26 (100%+)
Whats the servo of choice for the top drivers on foam carpet?
eddie10 is offline   Reply With Quote
Old 09-06-2008, 07:40 PM   #7179
A few pages back someone had mentioned having problems getting any droop in the arms. I just finished assembling a TC5F and was having the same problem.
I had to file down the arms (front and back) and a little on the carriers/hubs.
The rear arms being the worst, would sit just level and no further (with no shocks). The front arms were not quite as bad, they would sit just below level.
Does anyone know if AE has any plans on resolving this issue?
I was kinda hoping to leave all the filing/sanding/part fitting, back with the TC3
Otherwise, can't wait to try it
Sean B. is offline   Reply With Quote
Old 09-06-2008, 08:37 PM   #7180
That does not sound right, what mounting blocks are you using for the arms, there are three types; 1, 2 and 3 dots. Each set the arms at a different heigth. I am using 2's and have to cut back on the droop with the screws.
By the way, I don't like that the screws come in contact with the chassis so I made up four brass shims and used epoxy to bond them to the chassis so the droop screws impact the brass, not the chassis.
Dave
AE TC5R, GTB, SS13.5
AE T4FT
RC_DAVE4 is offline   Reply With Quote
Old 09-06-2008, 08:40 PM   #7181
Here is my newly built TC5 with the HPI Saleen body.
This car rocks!
Dave
AE T4FT
Old 09-06-2008, 10:49 PM   #7182
robk's Avatar
Trader Rating: 22 (100%+)
The bearings in the hubs have been a problem for some guys. I have had a couple basically disintegrate myself. Bearing sets are pretty cheap from 3rd party vendors, and I haven't had a problem since going away from stock bearings.
Crush tubes should be easy to get at the LHS.
Old 09-07-2008, 03:02 AM   #7183
decibels's Avatar
well not everyone is gonna agree with me but when you build the car and put the cv's in the hubs there is a bit of play!! i didnt have time to shim it properly as i was in a hurry as i got the car 2 days before a big meet! now i have noticed that the plastic sheilds have worn a bit from the hex lock. which i think is why i havnt had any probs yet all my bearings are fine after about 7-8 race meets! so i guess some play in the right areas is not such a bad thing!
Team Wave Speedies
flying fox rc
Old 09-07-2008, 04:06 AM   #7184
LOW ET's Avatar
Trader Rating: 96 (100%+)
so, where's those 10.5t foam setups?
LOW ET is online now   Reply With Quote
Old 09-07-2008, 06:55 AM   #7185
Trader Rating: 38 (100%+)
I think Im running the thickest spacer. Or whatever one kept the steering linkage the most parallel.
or8ital is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
