Old 09-03-2008, 08:10 PM   #7141
Gain Time's Avatar
well looks like most everyone is out of the ITF chassis top and bottom deck. If I am running on high grip carpet do you think I might be able to get away with running the original chassis and top deck and still be competitive?
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 09-03-2008, 08:26 PM   #7142
Trader Rating: 38 (100%+)
Why not just by a TC5R? Assuming you have a current TC5 it would probably be cheaper to sell your current then buy a new than the price of the top and bottom chassis? Plus you get the new slipper spool, cam holders, etc. Just a thought, that's what I did.
or8ital is offline   Reply With Quote
Old 09-03-2008, 09:12 PM   #7143
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Questions??
What all did they change/update on the TC5R? When i bought mine (TC5) last december i didn't know they were gonna make 2 versions?
BIG DADDY8 is offline   Reply With Quote
Old 09-03-2008, 10:34 PM   #7144
artwork's Avatar
Trader Rating: 59 (100%+)
TC5R
ITF top deck
ITF chassis
Slipper spool/diff in the front
Aluminum outdrives front and rear
Couple of other small things...
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 09-04-2008, 01:34 AM   #7145
LOW ET's Avatar
Trader Rating: 95 (100%+)
Originally Posted by Herc Driver View Post
Guys,
I love associated cars I have a T4 now (for whatever that's worth)...anyway I have never had good luck building Associated shocks...I even have Losi's on my truck.
As far as the TC5 goes how are the shocks? Are they the same or are they more Tamiya"ish"?
I am looking hard at the TC5...just need some feedback on what I have always had a hard time with...sorry if this is a dumb question...
Paul
in my opinion the tc5 shocks are the easiest shocks i've built. i wish all shocks went together like these.
LOW ET is offline   Reply With Quote
Old 09-04-2008, 02:52 AM   #7146
getpip's Avatar
I run the standard chassis with an ITF top deck with the O ring mod and it goes really well. I am using sorex 24s and as the grip comes up I sometimes need to tune some of it out by refitting the original top deck.
Its worth a try.
getpip is offline   Reply With Quote
Old 09-04-2008, 05:05 AM   #7147
Trader Rating: 18 (100%+)
Default setup for superior's track
Hi i am gonna go give superior hobbies track a try on sunday what would be a good all around setup obviously a tc5 orion 4800 lipo jaco blues itf top deck o-ring mod lrp tc spec 13.5 dna 2 shell if ya need anymore info please lemme know so i know what info to provide thanks for any and all help provided
icantdrivetc5 is offline   Reply With Quote
Old 09-04-2008, 05:10 AM   #7148
Gain Time's Avatar
Its worth a try.
Thanks. I will give it a try. I have been racing foam and havent tried rubber yet so wanted to see what others were doing on carpet which I know is alot different than rubber on Asphalt. thanks again.
Old 09-04-2008, 07:28 AM   #7149
BobbyS's Avatar
Originally Posted by robk View Post
Sometimes it helps to score the hub where the bearing fits in a radial pattern with a xacto knife. This slightly raises the edge of the hub where the bearing goes and tightens things up.
Everything is seated ok, just loose, might be time for a pair of those aluminum hubs...
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 09-04-2008, 12:15 PM   #7150
Originally Posted by BobbyS View Post
I"m starting to see "a lot" of play in the rear hub carriers when I grip the rear wheels and toggle 'em. Is this normal? The bearings feel smooth and there are no cracks in the hubs, cvd's are straight.
I added two shims behind the pin and bearing in the front stearing block and tried to do the same in the rear but two shims were too tight so I left it loose with the one shim. Can you add another shim to tighten it up?
AE TC5R, GTB, SS13.5
AE T4FT
RC_DAVE4 is offline   Reply With Quote
Old 09-04-2008, 12:32 PM   #7151
BobbyS's Avatar
Not a bad idea, I was going to wait until this weekend to tear it down but might go ahead and look at it tonight. What did you use for shims?
Old 09-04-2008, 02:11 PM   #7152
Trader Rating: 20 (100%+)
Send a message via AIM to Jamie Fredericks Send a message via MSN to Jamie Fredericks
What does the TC5R updates provide over the standard TC5? Does the stiffer chassis transfer weight to the tires better? Aluminum outdrives for durability? What brushless systems is everyone using right now in stock?
Jamie Fredericks is offline   Reply With Quote
Old 09-04-2008, 02:23 PM   #7153
islander360's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to islander360
It comes with the ITF chassis and top plate that allow more flex for low grip conditions. The outdrives allow harder acceleration. Brushless is 17.5 for R.O.A.R but ask your local track.
JConcepts - BMI Racing - Speed Passion - KustomRCGraphics - Core R/C
islander360 is offline   Reply With Quote
Old 09-04-2008, 02:38 PM   #7154
corally01's Avatar
Default rollout
Can some one tell me what pinion I should start with on the TC5ft for carpet. I have a 116 spur and I'm starting out with a CO27, and 57mm foam tires. Our track is 150'x75' set up with the vegas layout. Thanks.
Time is only wasted when your wasted all the time.
Jrxs type R
Losi 8t e 2.0
Rc 12.1 R
corally01 is offline   Reply With Quote
Old 09-04-2008, 05:34 PM   #7155
I used the TC5 shim kit. It's bascially another set of shims for the car.
http://www3.towerhobbies.com/cgi-bin...?&I=LXRUR9&P=Z
AE T4FT
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
