Old 09-02-2008, 08:44 PM   #7126
Originally Posted by revo61 View Post
I would still start with 27 turn or 19 turn. A 27 turn in a touring car is much faster, than you think. Look at what classes are run on the local track. The default rubber and foam setups work ok with stock to 19 turn classes.
I'm going with a 13.5
Shirk is offline   Reply With Quote
Old 09-02-2008, 10:20 PM   #7127
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
Speaking from experience.....27T is pretty quick in a touring car. when i made the jump to the 13.5 it was a night and day difference. It was like going from a V6 mustang to a 500hp Corvette.
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 09-03-2008, 01:44 PM   #7128
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Originally Posted by BIG DADDY8 View Post
What is better and will hold up longer? One of my racing buddies tried the slipper spool and it would loosen up in the turns on each race. I know the regular spool has no give. So it would be easier to tear the front up when you hit things. Which is better?
Anyone have an answer????????
BIG DADDY8 is offline   Reply With Quote
Old 09-03-2008, 01:51 PM   #7129
Trader Rating: 38 (100%+)
Use the old style (white) t-nut in the slipper spool with plenty of blue loctite on it and the slipper spool won't loosen on you. You then will get the performance of a spool with durability b/c it will slip on a crash.
With the solid you will break blades and then the dogbone will dig into the aluminum and it will begin to develop "play" in it.
or8ital is offline   Reply With Quote
Old 09-03-2008, 02:14 PM   #7130
artwork's Avatar
Trader Rating: 59 (100%+)
Originally Posted by Josh H View Post
I ran hard arms, castor blocks and steering knuckles.
Josh-
Was there a specific reason you ran the hard parts, or is it what you had? In my thinking the hard parts are more suited for the foam car, but on carpet i could see how it might work as well.
Thanks,
Art
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 09-03-2008, 02:22 PM   #7131
Originally Posted by artwork View Post
Josh-
Thanks,
Art
Art,
As traction comes up I find that hard parts are more consistant, also I feel that they have a little more corner speed.
For club racing I don't think there is a difference......unless you race on a very high bite track.
Josh
Josh Hohnstein is offline   Reply With Quote
Old 09-03-2008, 02:26 PM   #7132
BobbyS's Avatar
I"m starting to see "a lot" of play in the rear hub carriers when I grip the rear wheels and toggle 'em. Is this normal? The bearings feel smooth and there are no cracks in the hubs, cvd's are straight.
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 09-03-2008, 03:05 PM   #7133
artwork's Avatar
Could be either the rear hub or the arm...If you start noticing some inconsistencies in the car then I would look at replacing them. It is a nice feeling to replace a part due to wear then due to breakage embrace it!
Old 09-03-2008, 03:45 PM   #7134
BIG DADDY8's Avatar
Do you know of a part #?
Old 09-03-2008, 03:56 PM   #7135
BobbyS's Avatar
I do! I do!
Old 09-03-2008, 04:20 PM   #7136
BobbyS's Avatar
The one in this kit --> http://www3.towerhobbies.com/cgi-bin...?&I=LXPA07&P=7
Old 09-03-2008, 04:23 PM   #7137
I will look and see. There is a part that is just the nut and screw. Don't need to buy the whole rebuild kit for the TC3.
Old 09-03-2008, 04:57 PM   #7138
robk's Avatar
Trader Rating: 22 (100%+)
Sometimes it helps to score the hub where the bearing fits in a radial pattern with a xacto knife. This slightly raises the edge of the hub where the bearing goes and tightens things up.
robk is online now   Reply With Quote
Old 09-03-2008, 06:56 PM   #7139
I think I can handle a 13.5
Old 09-03-2008, 07:17 PM   #7140
Herc Driver's Avatar
Guys,
I love associated cars I have a T4 now (for whatever that's worth)...anyway I have never had good luck building Associated shocks...I even have Losi's on my truck.
As far as the TC5 goes how are the shocks? Are they the same or are they more Tamiya"ish"?
I am looking hard at the TC5...just need some feedback on what I have always had a hard time with...sorry if this is a dumb question...
Paul
Herc Driver is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
