Old 09-01-2008, 10:00 PM   #7111
Trader Rating: 7 (89%+)
Great job in Vegas Kev. Hopefully what we talked about will work out. I cannot wait. Planning on practicing at FastCats to get ready for the Classic. Ill let you know when I'll be up there, eh.
Johnny Carey is offline   Reply With Quote
Old 09-01-2008, 10:02 PM   #7112
fatbear's Avatar
Send a message via Yahoo to fatbear
Originally Posted by Keven H View Post
I was trying to get a smaller upper camber link and by using that rear hub I could get a hole further inside. I did it so it free up the car mid corner as the rear end doesnt roll as much.
I will post my setup in the next few days.
Keven
Thanks Keven,
That now makes more sense to me. I guess you could also make a new shock tower with new holes to make a shorter link.
I watched the mod final on Live RC. You could just see the difference on the overhead camera shots between your car and Paul Lemieux's car. Your car just looked like it was ever so slightly stopping mid corner where as his didn't. Other than that the car looked great.
Well done on a great run.
fatbear is offline   Reply With Quote
Old 09-02-2008, 03:51 AM   #7113
treemagnet's Avatar
Trader Rating: 17 (100%+)
Default tc5
just a random TC5 question but does anyone run their car without a front sway bar?? was even thinking bout putting the thicker sway bar on the rear and putting thinner bar on the front. any thoughts? i havent had a chance to run the car with these changes yet.....
thanks
treemagnet
treemagnet is offline   Reply With Quote
Old 09-02-2008, 07:36 AM   #7114
I'll try to get the setups posted by the end of the day.
I want to thank the guys at associated for making me feel at home on the team. Its very rare that teams work as well together as this one does.
Great car, great team and great support......I couldn't ask for anything more.
Josh Hohnstein is offline   Reply With Quote
Old 09-02-2008, 08:51 AM   #7115
quietstorm76's Avatar
thanks
treemagnet
I've only been running the car for a month now but I've taken both my sway bars off. I'm running rubber on asphalt and my car is easier to drive without them. Putting a thick on rear/thin on front will make the car rotate better if that's what you are looking for. More steering, looser rear end.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 09-02-2008, 11:43 AM   #7116
Rubber setup from iic
I qualified 3rd and finished 3rd...........the car was good (11.9's in 13.5) but my driving was a little off.
Old 09-02-2008, 11:50 AM   #7117
Trader Rating: 38 (100%+)
Did you use the R suspension parts or the hard parts?
or8ital is offline   Reply With Quote
Old 09-02-2008, 11:53 AM   #7118
I ran hard arms, castor blocks and steering knuckles.
Old 09-02-2008, 11:56 AM   #7119
Cool. Thanks. It looks like you were trying to stiffen things up a lot with the heavier oil in the front and no o-rings but were also running things very loose with the light springs. I will have to give it a shot and see how it works at my carpet track.
Old 09-02-2008, 02:25 PM   #7120
Originally Posted by yodace View Post
is it a good idea to put CA glue on the edge of the chassis?
I went one step further and used 30 min epoxy on every side edge surface on the chassis, shock towers and upper deck. Epoxy is very strong and it also gives the edges a nice shine to match the top and bottom.
AE TC5R, GTB, SS13.5
AE T4FT
RC_DAVE4 is offline   Reply With Quote
Old 09-02-2008, 06:47 PM   #7121
corally01's Avatar
Default tc 5
I just finished CA ing the chassis and top deck with quick set and it came out so smooth. What weight shock oil should I try for a foam set up?
Time is only wasted when your wasted all the time.
Emaxx
HPI Blitz
Ax10
corally01 is offline   Reply With Quote
Old 09-02-2008, 07:12 PM   #7122
What type of racing?? Motor and track. I would start roughly 55wt front 35wt rear.
Old 09-02-2008, 07:13 PM   #7123
katfish317's Avatar
You can always use the factory foam setup or download a setup from the AE website, you cannot go wrong either way.
katfish317 is offline   Reply With Quote
Old 09-02-2008, 08:29 PM   #7124
Originally Posted by quietstorm76 View Post
What class do you want o run? If new to racing I'd say go with stock 27T brushed or 17.5 brushless.
Well I have been racing off-road for almost 7 years so I am not new to rc, I just wanted to try some on road.
Shirk is offline   Reply With Quote
Old 09-02-2008, 08:52 PM   #7125
revo61's Avatar
Trader Rating: 18 (95%+)
I would still start with 27 turn or 19 turn. A 27 turn in a touring car is much faster, than you think. Look at what classes are run on the local track. The default rubber and foam setups work ok with stock to 19 turn classes.
revo61 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
