Old 09-01-2008, 11:37 AM   #7096
I just got a TC5 a couple days ago and I was wondering what motor I should start off with.
Shirk is offline   Reply With Quote
Old 09-01-2008, 12:29 PM   #7097
quietstorm76's Avatar
What class do you want o run? If new to racing I'd say go with stock 27T brushed or 17.5 brushless.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 09-01-2008, 01:42 PM   #7098
fatbear's Avatar
Send a message via Yahoo to fatbear
Originally Posted by or8ital View Post
I've had the car for a year and have never broken a rear hub. How much more durable do they need to be? C-Hubs break when you crash into the wall with your wheel turned. The aluminums will break too with a hard enough hit.
I look at it this way. AE wants the best touring car on the market. If they thought the aluminum stuff made a big difference towards that then they would include them. Just my .02.
I am not saying that you do need aluminium parts on your car, (Because I think you don't) but have a look at Keven Heberts car from the IIC. He is quite clearly running aluminium C Hubs and I believe he was also running Aluminium rear hubs. You just can't see them in this photo.
Now if Associateds top Foam driver is running them there must be something in it.
http://www.rc50.com/modules.php?name...bum=53&pos=286
fatbear is offline   Reply With Quote
Old 09-01-2008, 01:52 PM   #7099
Trader Rating: 8 (90%+)
He was running the Integy Aluminum Steering Knuckles and the Integy Aluminum Rear Hubs. He was running the stock Castor Blocks, i couldnt tell if they were the hard versions or not. Im sure he will shed some light on this topic.
Johnny Carey is offline   Reply With Quote
Old 09-01-2008, 02:24 PM   #7100
The main reason why I ran an aluminum rear hub is to get a thick smaller rear camber link since the one I had could achieve it. tamale made them. As far as the steering block, it is something I was testing to see how much difference it could make on high bite and to be honest, there is not much advantage running them !
Hope this help
Keven
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 09-01-2008, 02:48 PM   #7101
artwork's Avatar
Trader Rating: 59 (100%+)
Hope this help
Keven
Kevin-
Your car looked so good in Vegas. I was really impressed. I was gonna come over and bug you, but you looked pretty busy.
I run the aluminum for the increased durability...and it seems to work great on all of my other cars. I have found through my own durability testing that rear hubs don't break but in a crash the screw likes to rip out the threads, and then you have to replace it. I think Aluminum rear hubs are a must for me.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 09-01-2008, 03:43 PM   #7102
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by artwork View Post
Kevin-
How much or how long is the threaded part of the ballstud? The more thread you can put in there the better off you are. Especially when you are running spacers to raise the outer end.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-01-2008, 03:47 PM   #7103
Super Moderator
Kraig's Avatar
Keven, nice job at IIC. You are proving to many people that you don't need a $450+ car to compete at the top level. Keep it up!
Old 09-01-2008, 06:04 PM   #7104
hanulec's Avatar
Trader Rating: 27 (100%+)
Keven and Josh - could you both please post your foam 13.5 and 10.5 setups from IIC. After seeing foam touring run at IIC I'm thinking about getting a car and right now the TC5F is #1 on my list.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-01-2008, 06:17 PM   #7105
fatbear's Avatar
Hope this help
Keven
Hi Keven,
Sorry but I don't quite understand what you mean by thick smaller rear camber link. Could you try and explain it again. Also, what were you trying to achieve?
Old 09-01-2008, 07:40 PM   #7106
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Josh H is it possible for you to post your a main rubber tire setup please
wallstreet is offline   Reply With Quote
Old 09-01-2008, 07:44 PM   #7107
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Default Tc5 slipper sppol vs spool
What is better and will hold up longer? One of my racing buddies tried the slipper spool and it would loosen up in the turns on each race. I know the regular spool has no give. So it would be easier to tear the front up when you hit things. Which is better?
BIG DADDY8 is offline   Reply With Quote
Old 09-01-2008, 07:45 PM   #7108
artwork's Avatar
I asked Josh before we left Vegas and he said that it might be a few days before he could get the setup posted. Should be coming pretty soon.
Old 09-01-2008, 08:32 PM   #7109
I was trying to get a smaller upper camber link and by using that rear hub I could get a hole further inside. I did it so it free up the car mid corner as the rear end doesnt roll as much.
I will post my setup in the next few days.
Keven
Keven Hebert
Old 09-01-2008, 08:56 PM   #7110
Verndog's Avatar
Trader Rating: 16 (100%+)
Keven...Excellent job at the IIC! I was wondering if you were running the Reedy LiPo in mod and if you used the PPD lower base plate with it? Hope that is working for you. Mike Blackstock and Juho both have them also but I haven't gotten feedback from them.
I also have a new TC5 setup / tweak plate coming out this week similar to this for Mi3 http://www.ppdbillet.com/schumacher_mi3.html.
Let me know if your interested and I'll give you a killer deal....PM me if interested.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
