Old 08-29-2008, 08:07 PM   #7051
decibels's Avatar
Originally Posted by yodace View Post
How would i fix a loose rear end? I'm running the kit Tc5R setup? Asphalt sprayed with pop>>
Do kimbrough spurs work will on the car?
be careful with spur gears some hit the top deck you best off running thin ones!
Has anyone mucked around with the camber links??
Because ive made a mod to make the links longer (more grip in middle of corner) ive taken the link off the shock tower and i am running it on bulkheads where you can undo the 4 screws to pop diff out! and with blue springs and black swaybar front, silver springs rear and silver swaybar plus 25 wieght oil with number one pistons! car was awesome and that was on average pair of tyres and no goop! p.s shocks lent over 2 holes all round and outside on suspension arms, lowest roll center front a1, and touch higher on the rear a2 and three degrees rear toe, 0 degree front toe and a touch more droop on rear than front!! (rubber asphalt) and i also didnt have to crank up the steering to get the car whippin around still had plenty to go! Was also using diff in front done up all the way with tamiya antiwear grease in thrust and center of diff! just some thought for the tc5 drivers!!!!!!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 08-29-2008, 09:37 PM   #7052
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
I should hope that Kimbroughs work, considering that's what they come with from Associated As far as the loose condition, when is it? Enter a corner, mid way thru the corner, or exiting?
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 08-30-2008, 08:10 AM   #7053
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
If you run something thinner than a Kimbrough make sure that the threads of the screw do not come in contact with the belt pulley. So you can run thin ones but just pay attention when you install them.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-30-2008, 11:00 AM   #7054
TC5AE's Avatar
Smile spur gear
hey guys im not an expert but did build the tc5. i dodnt like the spur gear it came with so bought a hopup part. i forgot what it was but got it from precisionracingsystems.com if ur interested i have annother one im running and it is fast also from precision racing it is 48 pitch and 81 tooth.and it is very FAST! not dragging or hitting the deck.
well good luc kwith ur car!!
-TC5AE
TC5AE is offline   Reply With Quote
Old 08-30-2008, 11:03 AM   #7055
TC5AE's Avatar
Default more spur gear info
i would go with the 48 pitch not the 64 at precisionracing but its really ur choice.
GOOD LUCK!!
Old 08-30-2008, 11:31 AM   #7056
I plan on racing rubber tire on carpet this fall. Should I get the TC5R or the TC5F for rubber tire on carpet racing? The track I race at does get some pretty high grip at times.
MACHFIVE is offline   Reply With Quote
Old 08-30-2008, 11:39 AM   #7057
Hide's Avatar
TC5R = Rubber
TC5F = Foam
Losi 8ight-E 2.0, LRP Shark, Xray M18T custom extended, Traxxas VXL Revo
Hide is offline   Reply With Quote
Old 08-30-2008, 12:20 PM   #7058
Originally Posted by Hide View Post
TC5R = Rubber
TC5F = Foam
No, really?
I know with the Corally alot of guys run the foam setup for rubber on carpet (thick chassis, stiffer arms, etc). Just seeing if it's the same with the TC5?
Old 08-30-2008, 01:53 PM   #7059
LOW ET's Avatar
Trader Rating: 95 (100%+)
anyone running a lrp brushless 10.5t/lipo in a tc5? what gear ratio are you using?
looking at an ae setup sheet, it reads droop measured above ride height. how should i set this?
LOW ET is online now   Reply With Quote
Old 08-30-2008, 07:29 PM   #7060
Super Moderator
Kraig's Avatar
I would think the trade-off between the cars is what you want to look at. I myself ran the 5R car and just purchased some of hard suspension parts for when the traction came up.
Old 08-30-2008, 08:17 PM   #7061
quietstorm76's Avatar
Set your ride height then lift the car. I use an exacto. The droop measurement is how many mm above R/H the car lifts before the wheels leave the setup board.
Hope this makes sense.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-30-2008, 10:44 PM   #7062
Vision's Avatar
Trader Rating: 38 (98%+)
Quick question, other than the tires/rims that come with the tc5r and tc5f, what else do they offer over the tc5 kit ?.
Vision is offline   Reply With Quote
Old 08-30-2008, 11:28 PM   #7063
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
I do not believe either kit comes with tires, but for each kit you can use the tires below:
TC5R - Rubber tires
http://www.nexusracing.com/index.php?cPath=144_188_191
TC5F - Foam Tires
http://www.nexusracing.com/index.php?cPath=144_188_84
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 08-31-2008, 04:32 AM   #7064
LOW ET's Avatar
thanks, i figured that's what they ment but it seems everyone's doing it differently.
if guys are setting droop by lifting the car, what good are all the droop gauges being sold?
would the plastic spacers in the shocks be considered downstops? i'm using this setup, http://www.teamassociated.com/racerh...birds_2008.pdf and it looks as though i need more stroke in the rear arms. once i set ride height and lift the rear of the car the arms do not droop down, it's like the suspension is at max stroke while at ride height.
Old 08-31-2008, 04:33 AM   #7065
Hide's Avatar
So if I just buy the Hudy blocks, will I also need a setup board?
Also, I have the SMC 5000 LiPo and the weights for balancing. Can I just use the stock battery strap (here) and posts (here).
Here is a pic of the car without strap or posts but with the plate in:
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
