Old 08-26-2008, 09:04 PM   #7021
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by louielou View Post
i need to find out where i can purchase an aftermarket spool for my tc5 that does not need to use blades, that is alot freer and loser through turns, durability and longevity is important, and just uses dogbones from the tc5. Please let me know exactly everthing i need to purchase so i don't have to wait weeks for spool parts to arrive. i want to order everthing at once. i know alot of these companies are located over seas. i know alot of u guys have experiences with these aftermarket spools, so help would be appreciated.
i noticed the steel solid axle on the muchmore uk site,does this just use the dogbones from the tc5???
thanks
Luis
hey Loius , get me your old spool i have someone that can make one for you
Old 08-26-2008, 10:49 PM   #7022
well guys ......a quick report from vegas
After the first day of practice things are looking good for the team.
The mod guys look to be on pace in foam and I think they will be right up there in rubber also.
My car is pretty good in 13.5 rubber. My foam car is pretty good also but my foam driving still needs work....tomorrow is another day.
I'll try to give an update tomorrow also.
Josh Hohnstein
Josh Hohnstein is offline   Reply With Quote
Old 08-27-2008, 05:58 AM   #7023
Trader Rating: 38 (100%+)
Originally Posted by yodace View Post
My stock spool seems ok? Only four runs on it...
Dum question:when u say blades what are u guys referring to?
I looked on the Jaad site for after market spools, all i saw was tamiya parts?
Blades are the plastic half circle pieces that go on the end of the CVD and into the outdrives of the spool/diff. With the solid aluminum TC5 spool the blades have a tendency to break in a hard crash and then chew up your spool. The new R kit comes with a slipper spool which fixes that. JAAD racing makes an aluminum spool with plastic outdrives that allow you to just use the dogbones in it. The problem with it though it the plastic tends to wear out quickly and you start to get play in there. Ive tried the solid aluminum, JAAD, and slipper spool and so far Im most happy with the slipper spool (once I put a new t-bolt in it).
or8ital is offline   Reply With Quote
Old 08-27-2008, 06:14 AM   #7024
rccrazy4587's Avatar
Originally Posted by revo61 View Post
A TC5 is 1/10th scale.
are you sure i thought it was 1:12 scale
A good friend would bail you out of jail. A true friend would be sitting next to you saying........damn that was fun!!
rccrazy4587 is offline   Reply With Quote
Old 08-27-2008, 06:19 AM   #7025
revo61's Avatar
Trader Rating: 18 (95%+)
Look for yourself. I am 101% sure.
http://rc10.com/ae/tc5/tc5_home.htm
revo61 is offline   Reply With Quote
Old 08-27-2008, 07:32 AM   #7026
geeunit1014's Avatar
dont be confused, the new asc. 1/12 is the R5, the TC5 is a 1/10 TC thats been out for a while
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 08-27-2008, 08:39 AM   #7027
oh im sorrta new at onroad im deffinatly getting one i love my tc3 besides the whole direct drive
Old 08-27-2008, 04:35 PM   #7028
quietstorm76's Avatar
Originally Posted by itchynads View Post
Having some issues finding a t-nut for the rear alloy diffs on my tc5r.
I have a spare plastic outdrive kit but he t-nut that comes with it does not seem to fit very well, the 'wings' are thinner.
Is there a part number for a t-nut to suit the alloy outdrives?
I used associated part #6575
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-27-2008, 10:11 PM   #7029
Trader Rating: 23 (100%+)
hey guys, gunna buy the tc5r as my new carpet setup. does it come with an antenna mount or not because mine doesnt match that blue aluminum color. (its a tamiya blue color from my tamiya.)
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 08-27-2008, 10:15 PM   #7030
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
yes, the black plastic antenna mount comes with the kit and screws into the top deck.
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 08-27-2008, 10:18 PM   #7031
ok good, thanks for the fast reply.
Mike Adamec
Trackside Hobbies
Old 08-28-2008, 09:19 AM   #7032
Hey Guys - Any of you have a reference for a setup? Open Asphalt track, a little bumpy, rubber tires. Tires that seem to be working on the track are RP36. I tried the Howart setup from the Assoc site with Green springs, and the sides of the chassis rubbed in corners. Too soft.
Thanks - Mark
markg is offline   Reply With Quote
Old 08-28-2008, 09:22 AM   #7033
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
But if the car is hooking, then the set up is working. You can try sway bars to keep the chassis from rolling too much but that might loosen the car up a bit.
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 08-28-2008, 09:59 AM   #7034
hanzo3's Avatar
Trader Rating: 55 (100%+)
Are you running mod? The howart setup is for mod motors. For 13.5, the basic rubber setup from the manual works great. I have been using blue springs front, and silver in rear.
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 08-28-2008, 10:09 AM   #7035
AssocRacer's Avatar
+1
Lots O' Planes
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
