Team Associated TC5
#6961
if i gear a 13.5 at 66/35> would give me 3.774 for a orion vortex/mamba or lrp speedo> would that gearing be ok> I cant remember the size of the track. will find out>>>
#6963
U guys ever mess with the motor timing for a 13.5? vortex orion
#6964
I mostly run rubber tires on carpet. When i compare the TC5 to my colleagues cars (PHI, 416), they have a lot more corner speed i think.
Mainly the Corally carries off-power a lot more speed around the corners.
They run a similar set-up (droop, shocks, tires, additive).
Is there a way to improve the corner speed?
BTW: i run ITF chassis and top-deck
Thanks...
Thanks...
After being at the novak race this past winter... Brian Jucha had his car dialed and it had more corner speed than the corally phi on foam tires... I see no reason this same corner speed would not cross over into the rubber tire department.
Josh H will have all the info you need .... he will be in vegas and after he comes back bags a little heavier..... he will have an outstanding setup for us all to run.
#6965
leave the timing low and use gearing for speed. motor will run cooler. timing only changes the powerband on a bl, a timing change is nothing a pinion change cant accomplish, and with low timing the motor runs cooler
#6966
But Josh's car looks great in practice and is my pick to win the IIC
#6969
tc5
hi what do u think off this
a friend of mine is an engineer and has done theese parts for me brongs motor in line and lowers the spurgear 5mm made out of t6 aliminium
any questions just ask
#6970
Rear diff is in backwards in the picture. How well do the belts fit with this mod?
