Old 08-17-2008, 01:07 PM   #6931
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
icantdrivetc5, Your definition of a decent size track and someone else's might be different. If you could let us know the track name or the dimension's it would help us.
If anyone is looking to pickup a TC5 click here. I just don't have time to race anymore so it is time for me to move on.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-17-2008, 06:13 PM   #6932
yodace's Avatar
R/C Tech Charter Subscriber
is it a good idea to put CA glue on the edge of the chassis?
yodace is offline   Reply With Quote
Old 08-17-2008, 07:32 PM   #6933
katfish317's Avatar
I have heard of people doing it, I did it on the ITF chassis when I changed it out.
katfish317 is offline   Reply With Quote
Old 08-17-2008, 07:44 PM   #6934
quietstorm76's Avatar
Originally Posted by Maybell View Post
Try the o-ring trick on the 4 rear topdeck screws.
Also using 0 deg. rear hubs with at least 3 deg. rear toe should lock in the rear.
I'm going to try this next time out because as of right now I;m at 2deg toe. What about track width. I've noticed my car is not 190mm, it's about 186. Does everyone run like this? The only shims I have on the car are the ones adjusting the rear toe in. I wondering should I widen it.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-17-2008, 07:45 PM   #6935
Trader Rating: 38 (100%+)
Well you should CA the battery slots if you are running nimh batteries to keep them from shorting out on the chassis. Most CA the edges of the chassis to keep it from splitting. I don't. I just lightly file the edges to take the sharp corner off then run loctite around it to darked the edge. I've never had a problem only doing that and it looks great.
or8ital is offline   Reply With Quote
Old 08-17-2008, 08:23 PM   #6936
LOSI123's Avatar
Trader Rating: 63 (100%+)
When building the tc5r i am not sure of a couple of things on the rubber setup sheet.
do you put any Inboard toe on the front arms?
also is the 1.5 degree on the alignment of the front toe refer to toe out?
by turning the links?
or inboard toe?
LOSI123 is offline   Reply With Quote
Old 08-17-2008, 08:50 PM   #6937
geeunit1014's Avatar
or inboard toe?
the 1.5* is in the links. there should be no toe shims on the arms mounts. ive seen people run toe shims on the front pair of front mounts, but ive never seen a tc5 setup sheet with this adjustment.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 08-17-2008, 10:02 PM   #6938
Super Moderator
Kraig's Avatar
I ran my car on carpet with at least the 1.5 degree shims on the front. I always felt my car was easier to drive this way all the time. I would recommend that you give it a try.
Old 08-18-2008, 02:25 AM   #6939
Send a message via MSN to Bigger Brother
I usually run a 1.5 degree spacer on both front arm mounts.... I found that the slightly wider track width just calmed down the front of the car and made it a little easier to drive.......
However last few meetings I have struggled for enough front end bits and taking these spacers out helped in this situation
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 08-18-2008, 08:40 AM   #6940
PW
PW's Avatar
Send a message via AIM to PW
Also be careful when running shims on the front arm mounts because the driveshafts sit further out on the outdrives.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 08-18-2008, 09:42 AM   #6941
Does any one run spacers on the rear mounts other than the ones used for toe?
Primary Weapon: ?
Secondary Weapon: ?
Old 08-18-2008, 10:01 PM   #6942
no, but if you look at some of the factory driver setups you will see the run spacers between the wheel and the hex to widen the car out. the advantage of that is you get the wider car w/o altering any of the susp. geometry that would occur with widening the car using arm shims
Mike Gee
Old 08-19-2008, 12:46 AM   #6943
LOSI123's Avatar
anyone know if the angle at the back suspension pins matters,
like is it not jamming on an anlge when you make it have 3 degree rear toe
Old 08-19-2008, 10:26 AM   #6944
Maybell's Avatar
I usually use metal shims instead of the stock plastic clips...The clips are fine to use, they will just break down over the long-run a little bit...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 08-19-2008, 10:33 AM   #6945
Maybell's Avatar
As long as you are using the stock wheelbase shims there should not be any binding when using 3deg. inboard toe....and dont worry about the arm mounts being "stretched"....they will be ok.
Hope that answers your question...
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
