Old 08-10-2008, 04:19 AM   #6856
hi,i was just wondering how prone to tweak is the itf chassis compared to the foam chassis?
tony6187 is offline   Reply With Quote
Old 08-10-2008, 07:06 AM   #6857
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by PW View Post
WOW...One weekend? Guess the signature change says it all...LOL
lol the opportunity came up and couldnt pass it up,
Originally Posted by dbmartin View Post
is it really surprising
no its not
Old 08-10-2008, 09:05 AM   #6858
PartTime's Avatar
I have only had a handfull of race's on the tc5 but I have never had a tweak issue with it. once its set, your done. Cant emagine the itf being any diffrent.
DK
PartTime is offline   Reply With Quote
Old 08-10-2008, 09:29 AM   #6859
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
Originally Posted by Verndog View Post
Team AE update. Keven Hebert is current TQ in mod sedan after 2 rounds at Fantasy World Summer Sizzler in Tacoma Wa. Sean Maybell I believe is 4th also. Conditions have been tough, wind gusts and some on and off showers have played havok. 3rd rounds and the mains will be tomarrow.
Keven's TC5 is dialed and he is one awesome wheel to watch ...oh...and a heck of a nice guy for a Canadian. j/k
He is a nice guy. I got all kinds of help from him and Bob Stellflue (sp?) at this years Novak race and my car was DIALED.
Associated B44.3/Viper/RevTech
Associated B5M/Hobbywing/Orion
S & N's Trackside
AssocRacer is offline   Reply With Quote
Old 08-10-2008, 09:44 AM   #6860
Trader Rating: 38 (100%+)
I have recently began experiences the bad wheel bearing issue others have been having on the rear wheel bearings. Any hints on how to prevent this from happening other then changing the bearings each time it happens? Would removing the bearing spacer help? Aluminum hubs? Anything?
or8ital is offline   Reply With Quote
Old 08-10-2008, 11:23 AM   #6861
hanzo3's Avatar
Trader Rating: 55 (100%+)
I am trying to learn how to setup my car. When I turn too abruptly, the car flips over upside down. this is a rubber asphalt setup. What adjustments can I make so this doesn't happen? Or is it just being a newbie?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 08-10-2008, 12:44 PM   #6862
robk's Avatar
Trader Rating: 22 (100%+)
Please let us know what your setup is, tires, springs, camber, etc. You may have an obvious problem, but it is much easier to help if we know where you are starting
Old 08-10-2008, 01:06 PM   #6863
hanzo3's Avatar
Sorex 36R, front yellow rear purple springs. Camber is 0. Using rear sway bar. standard chassis, not ITF.
Chris TRF419 TA05V2
Old 08-10-2008, 04:13 PM   #6864
Send a message via MSN to Bigger Brother
Straight off that sounds waaaaay too hard on the shock springs. Look at running something like Blue/silver as a start point on asphalt.
Also I'd look at running 1 to 2 degrees of camber. The 0 camber could mean as the outside tire loads up in a turn the edge bites too hard and causes the flip.
I'd give that a go to start with and then see what it's like from there
HTH
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 08-10-2008, 04:15 PM   #6865
getpip's Avatar
What ride height are you running ...
getpip is offline   Reply With Quote
Old 08-10-2008, 04:32 PM   #6866
robk's Avatar
As was posted earlier, your car is so stiff, it acts like a door hinge. Instead of the suspension working, the weight transfer flips the car over.
Try this
http://www.rc10.com/racerhub/setup/tc5_rubber.pdf
Old 08-10-2008, 08:50 PM   #6867
Do tamiya springs work on the tc5?
WEEZY is offline   Reply With Quote
Old 08-10-2008, 10:18 PM   #6868
Verndog's Avatar
Trader Rating: 16 (100%+)
Final results for the Summer Sizzler...Keven Hebert brings home the A main Mod winner for Team Associated!
Congrats Keven and awesome weekend!!
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 08-11-2008, 02:40 AM   #6869
KA
Hi guys,
I lost touch with RC for more then 10yrs and recently decided to pick up my old car (a HPI RS pro) and found that not only was the car destroyed (by roach and rats i guess) my electronics were all screwed..
So been deciding what to get next as i need to start all over.. and finally made up my mind on the TC05R. As my local hobby shop do not support AE, nor does most of the the shops ard here.. i have to order my stuff online.
So i was thinking if i could get some help from the season guys here on the following:
- What are the parts (extras) that i should order?
- What parts breaks off easier and need replacements most? Since my hobby shop dont support AE, i have to buy pretty much buy everything online and i hate to have a bent/broken part to ruined my week.
- Which stocklist (online) would you recomend for gd service and fast delivery? (i need one that ships internationally.)
- Does the Spool (from the box) wears out fast? Lifespan?
- Would TC5 parts be a direct fit to TC5R?
Thanks you in advance!
KA is offline   Reply With Quote
Old 08-11-2008, 03:15 AM   #6870
getpip's Avatar
**Depends which model u buy and where you intend to run .. nothing initially.
** Caster blocks 6d (other than that suck it and see .. i dont break much .. break 1 order 2!)
** I use RC mart HK and Jasminations (ebay) US
** I use aftermarket AE spool not sure if its the same part but wear is good and the blades are very cheap.
** Yes
Have fun .. I love my tC5
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
