Old 08-04-2008, 10:51 PM   #6766
Hyde's Avatar
i use the mamba max in my tc5 and its great the belts handle everything and very smooth high conering, car just wants to fly.
i also use the mamba max esc with a 3.5 motor and its insane a little cogging but i use cheapo packs when I'm bashing but I'm sure any brushless system is best used with lipo but I'm not a lipo guy.
i could send pics via email if you wana see my setup my tc5
Originally Posted by yodace View Post
Any one use a MamBa Max esc with there TC5R. If so do u guys have any pics on how your installing them in the car...?
DO the belts hold up pretty good on the asphalt?
I heard the TC5R is more for mod and not 13.5> is this rumor true?
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 08-04-2008, 11:42 PM   #6767
Robert_K's Avatar
I just ordered my TC5R today.. In special setup tips i should do during the build>>>
Get Rid of the rubber O rings and blue shims on the topdeck, just use the screws nothing else. Or else the car will have way to much flex!
Pre Compres the diff springs! That's nessesary.
And the nut of the differnetial should be put in the plastic holder before you build the diff, that will help you a lot more.
Good Luck
Greetings Robert Krens
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 08-04-2008, 11:46 PM   #6768
Robert_K's Avatar
Originally Posted by or8ital View Post
I mean the new slipper spool.
Why would you want to have that one? It's not working, and way to loose.
No one runs it here because it doesn't work as a spool.
Just get a JAAD spool, or the original TC5 Spool and run that one high, to spare the blades.
Old 08-05-2008, 12:18 AM   #6769
Hyde's Avatar
what do you mean run it high? would that save my blades from shredding? i have to buy some
Old 08-05-2008, 01:02 AM   #6770
hanzo3's Avatar
Trader Rating: 55 (100%+)
For 64P, which robinson spur gears do I get? Are they all universal? Are there any specific ones for the TC5?
hanzo3 is offline   Reply With Quote
Old 08-05-2008, 03:16 AM   #6771
I've had the opposite experience. The orings especially in the rear part of the top deck help with grip tremendously. Im running a plastic spool with sandpaper and its been great. Very light so I get lots of punch. Just need to tighten it every once and awhile.
naggalowmo is offline   Reply With Quote
Old 08-05-2008, 03:25 AM   #6772
Tucker101's Avatar
Send a message via MSN to Tucker101
What would be a good starting point with the gears for this car.
I'll be using a LRP 4.5 BL motor.
The track is reasonably small, but it definitely won't be the only track i race at.
I just need a starting point in gearing so i can tune and change gearing setups from there.
Just a starting point would be good.
Thanks.
Tucker101 is offline   Reply With Quote
Old 08-05-2008, 04:26 AM   #6773
ooliganRC's Avatar
Send a message via MSN to ooliganRC
on the ae forum it mentions using the thrust race balls when building the slipper spool.
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 08-05-2008, 04:28 AM   #6774
Robert_K's Avatar
You can place the diff with Cam Holder B High or Low. My Teammate noticed that when running it high the blade's stay more in tact. because of the line of the CVD's.
Putting your Diff (or spool) high wil affect on the set-up. Running Both Diff's High wil make the car have more roll, And putting the front low, and rear high will give more steering.
Greetings
Robert Krens
Old 08-05-2008, 04:40 AM   #6775
Hide's Avatar
When running 27t foam on carpet what is a good gear ratio? The track is quite small with plenty of turns. Also, what pinion gears should I buy, new the to the TC5 so I have no idea?
Losi 8ight-E 2.0, LRP Shark, Xray M18T custom extended, Traxxas VXL Revo
Hide is offline   Reply With Quote
Old 08-05-2008, 05:48 AM   #6776
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Thanks.
For a small outdoor asphalt track with rubber tires 10.0 FDR is a good starting point. For med size, start around 9.75, and large, 9.3 FDR
yyhayyim is offline   Reply With Quote
Old 08-05-2008, 06:57 PM   #6777
quietstorm76's Avatar
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-05-2008, 08:35 PM   #6778
yodace's Avatar
R/C Tech Charter Subscriber
does the TC5R come with a front diff or a spool or oneway?
yodace is offline   Reply With Quote
Old 08-05-2008, 08:38 PM   #6779
Super Moderator
Marcos.J's Avatar
Trader Rating: 167 (100%+)
slipper spool
Old 08-05-2008, 08:39 PM   #6780
Rommel's Avatar
It has the "spool" option for the front diff. Which is basically the slipper spool kit, part #31174.
Rommel is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
