Old 06-30-2008, 12:11 PM   #6346
revo61's Avatar
Trader Rating: 18 (95%+)
Can I use 40weight oil and #3 pistons to get the same affect as #2 pistons and 35weight oil? I don't want to buy new pistons.
revo61 is offline   Reply With Quote
Old 06-30-2008, 12:16 PM   #6347
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
You can, but oil is temperature sensitive so keep that in mind.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 06-30-2008, 02:13 PM   #6348
BobbyS's Avatar
I just got a TC5F, I cranked the front spool down so that it's basically locked, is that the right way to set it or should there be some play when I turn the outdrives?
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 06-30-2008, 02:15 PM   #6349
Gain Time's Avatar
Originally Posted by TCRacer101 View Post
I'm using double pink, 56mm foams.
I will check my set up sheets when I get home from work and post the gears. I am at a 4.7 FDR and the motor was right at 160. You could probabl go up a couple of teeth since you are running the tires at a smaller diameter. But the gears will be a good starting point.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 06-30-2008, 02:26 PM   #6350
AE-Reedy
Yes you should tighten it down tight, you should not be able to slip the gear or least it should be very hard to move. I would recommend putting lock tite on the screw. Also you should retighten the diff bolt after a couple of batteries as it will loosen some as all the parts get seated togther.
Sean Cochran is offline   Reply With Quote
Old 06-30-2008, 02:32 PM   #6351
BobbyS's Avatar
Thanks Sean!
Old 06-30-2008, 04:17 PM   #6352
J_P
J_P's Avatar
Sean Cochran
^^^ Who's the new guy?^^^ lol!
JConcepts * Associated * Reedy
J_P is offline   Reply With Quote
Old 06-30-2008, 05:55 PM   #6353
revo61's Avatar
How do the suspension shims work? If I want 3 degrees of toe do I use one #2 shim and #1 shims?
Old 06-30-2008, 06:11 PM   #6354
mr crum's Avatar
Send a message via Yahoo to mr crum
u got it but wat i do is get out ur micrometers and find metal spacer that are 3 mm and get longer screws cause the plastic shim crush when u tighten them
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 06-30-2008, 08:00 PM   #6355
Gain Time's Avatar
I'm planning on getting a 13.5 brushless system, with 3800 Nimh batteries. What pinion gear should I use with the stock spur?
Ok using 48p gears start off with a 33 pin and 78 spur. Since you are running your tires at 56 mm you probably could go 35 Pin and 78 spur and be right at 160 degrees.
Old 06-30-2008, 08:42 PM   #6356
Verndog's Avatar
Trader Rating: 16 (100%+)
Read page 9 in the manual. Shims are 1.0 1.5 2.0 degs. So the thinnest and thickest shims will be 3.0 degs. rear toe with 0 deg. rear hubs.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 07-01-2008, 06:37 AM   #6357
Gain Time's Avatar
I use 2 degree at the arms and 1 degree hubs. This seems to work really well for me and several of the factory guys use this as well. The 0 degree hubs seem to cause the steering to be too agreesive for my tastes.
Old 07-01-2008, 04:11 PM   #6358
TCRacer101's Avatar
Send a message via MSN to TCRacer101
Ok. Like maybe 27/87? Higher?
E-Revo Brushless.....4s lipo/Coming SOON: HPI savage flux HP
Electric Monster Truck Association (EMTA)~~ electricmonster.webs.com
TCRacer101 is offline   Reply With Quote
Old 07-01-2008, 04:12 PM   #6359
TCRacer101's Avatar
Originally Posted by J_P View Post
Sean Cochran
Which one? LOL
Old 07-01-2008, 04:15 PM   #6360
TCRacer101's Avatar
Ok. Thanks!
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
