Old 06-28-2008, 06:43 PM   #6316
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by TCRacer101 View Post
I'm planning on getting a 13.5 brushless system, with 3800 Nimh batteries. What pinion gear should I use with the stock spur?
final drive ratio shold be between 4.5 depending track and motor temp 4.5 to 5.0 somewhere in that range for a track 130 x 60
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 06-28-2008, 06:44 PM   #6317
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by revo61 View Post
So basically I need to soften my setup? I was also looking at using just the ITF top deck. I have the part number for the washers, but what is the part number for the screws? I will also go to 35 weight oil all around with blue and silver springs. I really like the look of the lotus body, do you think the proline high downforce wings will help it? I still have the high downforce wing from a old Hot bodies mazda body. i may try that. I hate to dump the new body after only one race.
If you want to be competitive and drive a consistant car, body choice is very important. There's a reason why the good guys drive Mazda 6, Mazda Speed6, or DNA2 bodies 99% of the time. They give you the best handling and downforce and performance.
Do yourself a favor and get one of those three. As was already recommended try the Mazda 6 or Speed6...your car will handle much better with a good set up.
yyhayyim is offline   Reply With Quote
Old 06-28-2008, 06:48 PM   #6318
yyhayyim's Avatar
87T 48P Spur with 35T 48P pinion = 4.97FDR
Dont know if with the 87T Spur you'll ge the 35T pinion to mesh...might be too big. You should get a smaller Spur ASAP. Ideally a 72 or 75 is good size for 13.5 /10.5 motors
Old 06-28-2008, 07:12 PM   #6319
Verndog's Avatar
Trader Rating: 16 (100%+)
It is to big, he'll never get there with the 87T. You'll want a 78 maximum with 31 is close to 5.0. As posted even a 75T.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 06-29-2008, 05:03 AM   #6320
TCRacer101's Avatar
Send a message via MSN to TCRacer101
Ok. Thanks guys. I have a question. Is the Parma Mohawk a good downforce body for carpet?
This is my 5th year in R/C racing, but I still don't know everything. I probably never will!
E-Revo Brushless.....4s lipo/Coming SOON: HPI savage flux HP
Electric Monster Truck Association (EMTA)~~ electricmonster.webs.com
TCRacer101 is offline   Reply With Quote
Old 06-29-2008, 05:57 AM   #6321
Gain Time's Avatar
Well this is what I have found. Using the set up posted on here by Robk for carpet with foam tires the mohawk doesnt handle as well as the Mazda 6. It handles ok but it tends to push just a little bit. I have adjusted the suspension for it but I still feel the car handled better with that little lip on that is on the front of the Mazda 6 body even though I am running foams.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 06-29-2008, 06:00 AM   #6322
Gain Time's Avatar
Also I have the R9 body ordered. I am wondering if it will be better than the Mazda 6. The DNA pushed while the DNA 2 had way too much front downforce for foams......and yes I know that it was designed for rubber tire but I always try everything to see how it works. Ya never know when you are going to find that little edge that puts you in front by trying something out of the norm.
Old 06-29-2008, 06:17 AM   #6323
Gain Time's Avatar
Will you be running foams or rubber tires? The rollout is a more accurate picture of the gearing. In foams the gearing changes as the tires wear down.
Rubber tire the wear is negligible so the gearing will remain the same. I can look at my set up sheets from when I was running 48p gears and give you and idea of what I used for 60 MM foams though. Maybe this evening as I am packing the truck to go racing this afternoon.
l8r.
Old 06-29-2008, 06:22 AM   #6324
Gain Time's Avatar
ok from what I know of the set up I got off this thread and how the Mazda 6 body performed I think the R9 body is going to be spot on. I just took another peak at the pics that Dale posted and that little lip on the front, I believe, will give that little bit of front downforce missing in the DNA and MoHawk bodies.
I can not wait to give it a try.
Old 06-29-2008, 06:29 AM   #6325
TCRacer101's Avatar
I do have a Mazdaspeed 6 body. I'm gonna go racing today, so I may bring the Mohawk and the MS 6. What about protoform Nemesis? It has a lip on it (at least mine does).
Old 06-29-2008, 06:31 AM   #6326
TCRacer101's Avatar
l8r.
I'm using double pink, 56mm foams.
Old 06-29-2008, 12:13 PM   #6327
revo61's Avatar
Trader Rating: 18 (95%+)
Is it true that running the aluminum servo mounts causes the servo arms to break.
revo61 is offline   Reply With Quote
Old 06-29-2008, 12:36 PM   #6328
Trader Rating: 38 (100%+)
No
or8ital is offline   Reply With Quote
Old 06-29-2008, 01:53 PM   #6329
stanislow's Avatar
Send a message via MSN to stanislow
56mm prisms?
56 is pretty darn small
Speedpassion, Team Trinity, AVID bearings, Titanium Racing
Eastridge Hobbies
RC Canwest Xray Jaco SMC
Mad Scientist Motors
stanislow is offline   Reply With Quote
Old 06-29-2008, 04:01 PM   #6330
BadSign's Avatar
Trader Rating: 15 (100%+)
can anyone tell me if the TC4 and 5 bumpers have the same bolt hole patterns?
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
