Old 06-28-2008, 07:48 AM   #6301
Rick could you shoot me a pic of the Brass Weight you were using at the ROAR Nats and weight of each. I am going to get my brother in Law to machine me some out. Thanks Matt
beanster is offline   Reply With Quote
Old 06-28-2008, 08:41 AM   #6302
artwork's Avatar
Trader Rating: 54 (100%+)
Really the best way to do it is to figure out how much weight you have to offset and build the pieces to match your car. Everyone typically runs different electronics and motors so it is best to build your own based on your own needs. Try to place the weight as low as you can get it...under the battery is a good place, and I try to keep all of my weight inside the chassis line. Everyone is a little different!
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 06-28-2008, 08:53 AM   #6303
Trader Rating: 38 (100%+)
Rick posted that they would be selling the weights soon.
or8ital is offline   Reply With Quote
Old 06-28-2008, 09:37 AM   #6304
Verndog's Avatar
Trader Rating: 16 (100%+)
That is exactly what this weight will do for you. The concealed channel lets you add up to 1.75oz of addditional weight that comes with it, and it's out of sight once mounted.
Its flush to chassis edge and will not dent or lose form like lead because its polished stainless steel.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 06-28-2008, 12:46 PM   #6305
revo61's Avatar
Trader Rating: 18 (95%+)
I had my first race with my TC5. We run in parking lot and use foams. I had absulutley no traction. I have the stock chassis. What can do to get more traction, using stock chassis? I am currently using the box setup. I am using a HPI Lotus body. Should I use softer oil or springs? I need a setup for low to medium traction on asphalt. Please help me!
revo61 is offline   Reply With Quote
Old 06-28-2008, 01:28 PM   #6306
racer x 1's Avatar
Trader Rating: 27 (100%+)
forget the set-up for now, you need a better body with more downforce like a protoform stratus,mazda 6 ,mazdaspeed 6 and DNA1. That body is not known for its downforce and is probably the reason why car is not handling very well. As far as set-up goes I would say look up the tc5r set-up because that is a asphalt set-up that should work alright.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 06-28-2008, 02:39 PM   #6307
Maybell's Avatar
If you are running the stock setup witch is a foam carpet setup, the first thing you should do is get the spring kit pt#3988 and start with silvers in the rear and blue up front...that will help alot because you are way too stiff right now...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 06-28-2008, 03:12 PM   #6308
revo61's Avatar
So basically I need to soften my setup? I was also looking at using just the ITF top deck. I have the part number for the washers, but what is the part number for the screws? I will also go to 35 weight oil all around with blue and silver springs. I really like the look of the lotus body, do you think the proline high downforce wings will help it? I still have the high downforce wing from a old Hot bodies mazda body. i may try that. I hate to dump the new body after only one race.
Old 06-28-2008, 03:20 PM   #6309
BadSign's Avatar
Trader Rating: 15 (100%+)
3 questions:
1: What compound tire did you use?
2: Did you use traction additive, and what kind?
3: Was anything added to the track surface (sugar water, coke syrup, etc.)?
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 06-28-2008, 03:26 PM   #6310
revo61's Avatar
Foam tire 35/37
No traction additive for tires
Soda was sprayed on track.
Old 06-28-2008, 03:30 PM   #6311
Maybell's Avatar
Yes. You need to soften the car. ITF topdeck and chassis when you can. The o-ring trick on the 4 rear topdeck screws will help to. get some 3x8 and some 3x10mm screws for that and some washers. Just get a Protoform Mazda 6 body....it is the best overall for rubber tire..
Old 06-28-2008, 03:32 PM   #6312
Maybell's Avatar
Foam tire 35/37
For traction additive....find out what the fast guys at your track are running and get some...
Old 06-28-2008, 04:33 PM   #6313
BadSign's Avatar
I had a feeling this was it. Cover your rears completely and the inside 1/2 of the fronts about 20 min. before each race and let it sit. In the old days we used suntan lotion...
Old 06-28-2008, 05:18 PM   #6314
Maybell's Avatar
For rubber tire asphalt 99% of the time we sauce the whole front.
Old 06-28-2008, 06:21 PM   #6315
TCRacer101's Avatar
Send a message via MSN to TCRacer101
I'm planning on getting a 13.5 brushless system, with 3800 Nimh batteries. What pinion gear should I use with the stock spur?
E-Revo Brushless.....4s lipo/Coming SOON: HPI savage flux HP
Electric Monster Truck Association (EMTA)~~ electricmonster.webs.com
TCRacer101 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
