Old 06-18-2008, 11:40 AM   #6196
AE-Reedy
Originally Posted by yyhayyim View Post
Thanks Fathead and RobK.
So out of 1A or 2A, which gives the most reaction and agressive turn in in your opinion? Most team driver set ups seem to have 1A on there and wonder if that's the most agressive one.
What about the length of the drag link? Will making it longer or shorter effect the reactiveness of the steering on the car in some way?
Changing the length of the drag link will only affect the steering balance left to right. You always want to keep the servo arm and the drag link at or very close to 90 degrees. This will keep the balance left to right as even as possible.
Sean Cochran is offline   Reply With Quote
Old 06-18-2008, 12:43 PM   #6197
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by fathead View Post
The more the steering arm points to the rear of the car on the outside the more aggressive the steering is, I generally use 2A
So 1A should be more agressive than 2A
thanks...
yyhayyim is offline   Reply With Quote
Old 06-18-2008, 03:13 PM   #6198
sonic31's Avatar
oye you're not allowed to use 1a, only i can yohan, tc5 acere eso es picante ...
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 06-18-2008, 03:32 PM   #6199
yyhayyim's Avatar
you had 1B on your car Sunday...try 1A and see what happens
Old 06-18-2008, 04:01 PM   #6200
sonic31's Avatar
yohan i was using 2a in the front and 3a in the back. i changed it monday to 2a all around. rear toe at 2.5.
Old 06-18-2008, 06:14 PM   #6201
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by louielou View Post
whats up MR CRUM, i was running 0 toe in the rear in the first 2 qualifiers and then for the 3rd and the main, added 2 toe in the rear, but i also think i tighten up the belt to much on the rear compared to the front, and i was thinking maybe thats why the rear felt so loose on throttle. Thanks for the info fellas.
Luis Vega
hey man thanks try using 3 degrees and use metal shims cause the plastic ones crush when u tighten them ill see u sunday
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 06-19-2008, 03:48 PM   #6202
sonic31's Avatar
on the arm mount shims i use xray ones ... 0.4mm, 0.75mm, 1.15mm and 1.5mm ... so far so good no problems with handling, everytime i check my rear toe it comes up accurate using those shims
Old 06-19-2008, 06:41 PM   #6203
yyhayyim's Avatar
I've read in a couple places that some drivers are not using the blue foam pads on the shock bladders at all when running on outdoor asphalt....why is that? Will no foams on the bladders give better traction on low-med traction tracks?
Old 06-19-2008, 06:41 PM   #6204
yyhayyim's Avatar
I've read in a couple places that some drivers are not using the blue foam pads on the shock bladders at all when running on outdoor asphalt....why is that? Will no foams on the bladders give better traction on low-med traction tracks? maybe its something about the AE shocks that work better without the foams?
Old 06-19-2008, 06:44 PM   #6205
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Less rebound, which means slower reaction, which means more body roll and traction.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 06-19-2008, 06:47 PM   #6206
Maybell's Avatar
Im not an expert in this area but I do know that without the foam the shock will have less natural rebound...and less rebound is good on the TC5 for rubber tires....not sure about foam tire setups but I believe some of the team uses the small foam insert...
We need a ask Bob thread
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 06-19-2008, 07:20 PM   #6207
Suspended
Default Unofficial Launch of Social RC!
Being an Associated guy I had to post the first real announcement here! The team at Social RC (www.socialrc.com) has been working incredibly hard to build an innovative online community for RC Car Racing. Our goal is two fold: the first is to elevate the profile of RC Racing worldwide by giving racers, manufacturers and track operators what they have persistently been asking for - effective tools to network, stay in touch, swap stories/tips and learn about the latest trends and events in RC Racing Web 2.0 fashion! The second is get every single racer to become apart of Social RC, one track at a time (no easy task!).
While the site is still in beta mode, I wanted the Associated guys to take a first peak and let us know your preliminary thoughts and feedback. All feedback can be posted to the site. We have partnered with the manufacturers and track operators and plan on spreading the word to the masses over the next couple week! Racers ready, marshals ready!
Social RC Admin
www.socialrc.com
bpatel12 is offline   Reply With Quote
Old 06-19-2008, 07:30 PM   #6208
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Weren't you a Corally guy on the Corally thread?
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 06-19-2008, 07:34 PM   #6209
dbmartin's Avatar
apparently he is the losi guy as well
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 06-19-2008, 07:34 PM   #6210
K_King's Avatar
Hes a Losi guy too lol
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
