Old 06-16-2008, 04:17 PM   #6181
PartTime's Avatar
Originally Posted by yyhayyim View Post
Any try using HB Cyclone 39T pulley on the TC5? They should work...might be worth a shot to try overdrive on a TC5
I bet that would be killer on a big sweeping lay out. With a one way of course,
DK
PartTime is offline   Reply With Quote
Old 06-16-2008, 05:09 PM   #6182
sonic31's Avatar
yohan try using tc4 pulleys and traxxas 4tec arms its the hott ticket, and also 100 wt. oil and pink springs.......thats the hot setup these days bro
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 06-16-2008, 05:18 PM   #6183
yyhayyim's Avatar
Trader Rating: 26 (100%+)
the reversible grasshopper arms work better on bumpy surfaces, though.
yyhayyim is offline   Reply With Quote
Old 06-16-2008, 05:29 PM   #6184
yyhayyim's Avatar
DK
I've heard the opposite...it would be great in tight technical layout due to the increase in steering with the overdrive
Old 06-16-2008, 05:32 PM   #6185
yyhayyim's Avatar
DK
Also, using 36T pulleys and the 20 center pulleys can get a 1.8 internal ratio. Which is quite helpfull when gearing for 17.5 and 13.5 or 10.5 even. A bit easier to get the low gearing with a 1.8, and the 2.0 is nicer for mod
Old 06-17-2008, 09:13 AM   #6186
artwork's Avatar
Trader Rating: 59 (100%+)
One ways are for large sweeping tracks where you don't have to brake very hard or at all. If you brake with a one way you will pretty much spin out every time. I really only use a one way on carpet with rubber tires. Outside I use a spool...still carries a lot of corner speed and you can break with it. On a really tight track I will use a diff.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 06-17-2008, 09:24 AM   #6187
louielou's Avatar
Trader Rating: 16 (100%+)
can someone help me and explain the effects of belt tension and when should it be used as a setup option. i also want to know which belt should be tighter as apossed to the other or does it matter?
Luis Vega
louielou is offline   Reply With Quote
Old 06-17-2008, 03:22 PM   #6188
Tower Hobbies is already listing the TC5R for $369 I think its a great price with the usual $25 off they give in discount.
Xtreme2008 is offline   Reply With Quote
Old 06-17-2008, 04:14 PM   #6189
mr crum's Avatar
Send a message via Yahoo to mr crum
Luis Vega
HEY LOUI THE BELTS ARE ALL THE SAME I HAVENT YET FOUND A DIFFRENTS IN TENSION MAYBE WE COULD COMPARE NOTES AND SEE IF WE COULD HELP EACHOTHER 2 CARS TWICE AS MUCH DATA UR CAR LOOKED PRETTY DIALED HOW MUCH TOE IN THE REAR ARE U USING
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 06-17-2008, 04:41 PM   #6190
AE-Reedy
Luis Vega
You should try to keeep the belt tensions close to even. The problems will show up if the front belt is a lot looser than the rear. When you hit the throttle and the front belt is loose it will take longer for the front wheels to start to "pull" the car and the car will be RWD only for an instant. This can cause the car to be very loose on throttle.
Sean Cochran is offline   Reply With Quote
Old 06-17-2008, 08:46 PM   #6191
yyhayyim's Avatar
What have you guys found to make the car more reactive and or increase turn in w/ bellcrank settings:
1A
2A
1B
2B
Old 06-17-2008, 09:08 PM   #6192
robk's Avatar
Trader Rating: 22 (100%+)
Go with 1a or 2a. The forward hole on the bellcrank is more reactive.
Old 06-17-2008, 11:53 PM   #6193
fathead's Avatar
The more the steering arm points to the rear of the car on the outside the more aggressive the steering is, I generally use 2A
Slavich Design
fathead is offline   Reply With Quote
Old 06-18-2008, 07:25 AM   #6194
yyhayyim's Avatar
Thanks Fathead and RobK.
So out of 1A or 2A, which gives the most reaction and agressive turn in in your opinion? Most team driver set ups seem to have 1A on there and wonder if that's the most agressive one.
What about the length of the drag link? Will making it longer or shorter effect the reactiveness of the steering on the car in some way?
Old 06-18-2008, 08:56 AM   #6195
louielou's Avatar
whats up MR CRUM, i was running 0 toe in the rear in the first 2 qualifiers and then for the 3rd and the main, added 2 toe in the rear, but i also think i tighten up the belt to much on the rear compared to the front, and i was thinking maybe thats why the rear felt so loose on throttle. Thanks for the info fellas.
Luis Vega
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
