Old 06-11-2008, 06:06 PM   #6151
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Originally Posted by TeckLancer View Post
well guys i figured out what was clicking. it was in the spur i took it apart lube the bearings and put it back togther and it stop clicking. but after that i rolled it without a pinion and stil didnt roll to much futher. so i lube all the bearings and lossened the screws in the back of the top plat, just alittle and it seemed to roll alot futher. after i pulled out my pro 4 just to test to see how much futher it would roll and my hpi seemed to roll much futher then the tc5. so i dont know what to do know. i mean i got the tc5 to roll alot i mean alot further but my pro4 4 seems to roll even further any suggestion ????
your pro4 will roll alot further than most any belt car. The shaft cars are more effiecent as far as roll and are a touch smoother. That is why shaft cars are very popular in asia cause they have that 23t motor class.
If you found out it was a bearing that was clicking i would think about getting some spare bearings... they dont have to be expensive either... Its good to replace the bearings every so often especially if you race alot.
wallstreet is offline   Reply With Quote
Old 06-11-2008, 11:31 PM   #6152
S_fender's Avatar
Originally Posted by Rick Hohwart View Post
The anti-dive is what I was seeking. I only used the 6 degree caster blocks to returnb the caster so that is as close to the desired position as I can get using anti-dive. Optimally, I would use 7 degreee blocks for 6 degree caster AND anti-dive. but this is not available. Although it could be an interesting tuning part for an aftermarket parts company - 3, 5, and 7 degree blocks for those that run anti-dive.
I went to the inside position on the rear arm as a result of my Tamiya experiences. The Tamiya car used different shock position front and rear which resulted in the use of the same springs all-around. I never ran "split" springs front and rear with Tamiya so I thought I would try and set up the TC5 so I could do the same thing. That is why I used the green springs all around.
All these changes happened at a point in the event that I did not play with it much more. The car was so good I did not want ot mess with it further. But we have our Nationals next week so I will work on it a bit more and see what happens.
Thanks for this clear explanation and Good luck for your Nationals.
Sébastien
S_fender is offline   Reply With Quote
Old 06-12-2008, 11:21 PM   #6153
treemagnet's Avatar
Trader Rating: 17 (100%+)
Default tc5
hey everyone. i just bought a second hand TC5 and was just wondering if there is anythings i should know bout the chassis like parts that are prone to failing or anything
thanks....
treemagnet is offline   Reply With Quote
Old 06-13-2008, 05:24 AM   #6154
katfish317's Avatar
Treemagnet:
The really major failures are none!! Mostly wheel bearing from taking one too many rails that's about it. Also look into getting a good P-dub front bumper they help protect the front end better then the stock one.
katfish317 is offline   Reply With Quote
Old 06-13-2008, 08:48 AM   #6155
S_fender's Avatar
Rick,
Another question concerning your setup.
I've found 2 setup from the reedy race :
One with 40WT front and 45 WT (rc10.com) rear and one with 45 front and 40 rear (http://www.petitrc.com/reglages/asso...ce20080525.pdf), which one is right ?
Thanks.
Sébastien
Old 06-13-2008, 08:56 AM   #6156
Rick Hohwart's Avatar
Originally Posted by S_fender View Post
Rick,
Thanks.
Sébastien
45F and 40R
Rick Hohwart is offline   Reply With Quote
Old 06-13-2008, 09:06 AM   #6157
Rick,
Thanks.
Sébastien
45F and 40R
Old 06-13-2008, 10:07 AM   #6158
Just Wondering if anyone has tried any of the progressive springs from other cars such as the xray?
Would like to try them on the car with rubber tires outdoors.
Slick990 is offline   Reply With Quote
Old 06-13-2008, 02:16 PM   #6159
sonic31's Avatar
hey slick wasup, i've been using the white front and yellow rear xray springs and the car has been working well. hope that helps you out bro, laterz
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 06-14-2008, 02:41 PM   #6160
Anybody know where to find a TC5F kit? AE's website says the release date is June 2008 but I can't seem to find one anywhere
aviaar is offline   Reply With Quote
Old 06-14-2008, 04:59 PM   #6161
PartTime's Avatar
I just put the new stock tc5r setup on mine. The only diffrents is I dont have a spool so I cranked down the front diff. Its no spool but it is really stiff.
Slapped an old G6 body with take off 32's and its very neutral and stable. Has a slight over steer off power and a touch of push on power with very little snap around on the slow corners. Very nice starting point.
I have a race tomorrow at a new place. Will report how it went.
DK
PartTime is offline   Reply With Quote
Old 06-14-2008, 08:13 PM   #6162
geeunit1014's Avatar
DK
try running a mazdaspeed 6 body, itl get you more downforce overall than the G6 (= more grip)
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 06-14-2008, 08:48 PM   #6163
PartTime's Avatar
Ya, this is just what I had laying around. When im ready to get a new one that is the one I will be picking up.
DK
Old 06-14-2008, 09:31 PM   #6164
Rocksmith's Avatar
Got this email from a lil birdie. Im sure the TC5F will be the same. Although Tower now says late june instead of mid June. I will have my TC5r tuesday..........
Rocksmith is offline   Reply With Quote
Old 06-15-2008, 05:00 PM   #6165
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Hey guys, I've noticed that most of the on-road set up w/ rubber tires are running no sway bars...why is that? Most of the on-road set ups with other cars like HB Cyclones, Serpent S400, MI3, Losi, Xray, etc, prety much everybody team runs swaybars on rubber tire asphalt...with the exeption of the TC5 team drivers...I think all of them run no- sway bars at all since 2007 till today.
Its pretty interesting and would like to know if anyone can give good reasons as to why AE drivers dont run sway bars most of the time on on-road asphalt.
yyhayyim is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
