Old 06-08-2008, 01:08 PM   #6136
TeckLancer's Avatar
Trader Rating: 16 (100%+)
i took the pinion off and it seems to roll fine but a keep hearing clicking sound. i think i might be coming from the spur as it seems to wobble a little bit. any suggestions? o yea i also bought the stock 87 to run cause it was running a 72, see if that helps
Eric Arellano
TC5,RC18-b,PRO4,FS,EIGHT-E 2.0,TLT,TF-5,Nitro MT
Panther tires, Speedtech r/c, Murfdogg Motorworks
check oout my forsale thread http://www.rctech.net/forum/r-c-items-sale-trade/401576-wts-b44-b4-losi-8e-hpi-nitro-mt-few-lipos.html
TeckLancer is offline   Reply With Quote
Old 06-08-2008, 05:51 PM   #6137
hpisims's Avatar
Sounds like it might be the belt hitting the screws that hold the spur on I had to get shorter screws cause I had same problem. Check that out and see what happens for ya.
J.SIMS
Team Associated TC6-Viper R/C Solutions-Sweep Racing-Fullthrottle Motorsports-APH
www.speedybillsrc.com
www.ovrccc.com
hpisims is offline   Reply With Quote
Old 06-08-2008, 06:42 PM   #6138
Rick Howard Reedy Race Setup
Potential useful resource
Arn0 is offline   Reply With Quote
Old 06-08-2008, 06:53 PM   #6139
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
if you here a clicking noise check the screws that you are using to hold the spur gear in place... you may have used screws that might have been to long and the screws could be making the clicking noise ... the screws or maybe just one screw might be scraping against the top deck.
wallstreet is offline   Reply With Quote
Old 06-08-2008, 08:04 PM   #6140
TeckLancer's Avatar
k thanks ill check that as soon as i have a chance
Eric Arellano
Old 06-08-2008, 08:10 PM   #6141
Sean Powers's Avatar
Hey guys, I posted this in the for sale/trade forum but I figured I would let you guys know about it too, I dont know if anyone is looking for another car for a backup or any thing but im selling two TC5's.
The rubber tire car has never been ran, the other car that was built for foam tires and has been ran about 4 race days.
Chassis on both cars have been sanded and sealed.
Both cars have all hard parts and aluminum diffs front and rear.
Rubber tire car has chassis protection film and IFT top deck.
The only spare parts that I have are the original plasitc parts that came with the car, I also have 2 mounted unpainted mazda 6 bodies.
Im asking $255 each, payment via pay pal, Sorry no trades.
Sean
Sean Powers is offline   Reply With Quote
Old 06-08-2008, 08:41 PM   #6142
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
If you are running the blue washers, as seen on the TC5R pictures and your spur gear wobbles, it might be hitting them. It has happened to me.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-09-2008, 11:36 AM   #6143
katfish317's Avatar
Just a note about Rick Hohward's setup posted. I tried it this past weekend in SC, track temp got up to 137* and I only made two small changes front springs went to silver and changed the front shock oil to 35 wt. Other then that it was great!!!!! I have only been racing TC for five months now and I was only half a second behind the fastest qualifier in the A main!! Was great. I am planning on saving this for hot track temps with medium traction!
katfish317 is offline   Reply With Quote
Old 06-10-2008, 11:43 AM   #6144
Rick Hohwart's Avatar
Originally Posted by Arn0 View Post
Sorry guys I lost track of who I have and have not sent my setup. Use this link if you have not received the setup via email. The setup should appear on AE's website soon as well.
Rick Hohwart is offline   Reply With Quote
Old 06-11-2008, 12:54 PM   #6145
S_fender's Avatar
Hello,
Thanks for posting your setup on AE's website.
I've some questions concerning this setup :
Why are you using anti-Dive and, please, can you explain the rear lower shock mount position?
Thank you,
Sebastien.
S_fender is offline   Reply With Quote
Old 06-11-2008, 01:00 PM   #6146
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by S_fender View Post
Hello,
Thank you,
Sebastien.
anti-dive will give you more turn-in steering
Old 06-11-2008, 01:28 PM   #6147
S_fender's Avatar
I've read the TC5R manual :
Anti-Dive :
Reduces weight transfer to the front on deceleration entering corners and
reduces caster.
and as a consequence :
Decreased caster gives a more responsive feel and more exit steering.
Kick-up :
More entry steering and more caster so :
Increasing caster reduce mid to exit corner and front is less responsive.
Why Rick have used 1 anti-Dive and 6 C-Hub (5 total caster) and not 1 kick-up + 4 C-Hub (5 total caster) ?
Is it because 5 caster was the best and anti dive was used for reducing the weight transfer ?
Or there is another answer ?
Sebastien
Old 06-11-2008, 01:55 PM   #6148
Anti-Dive :
reduces caster.
Kick-up :
Sebastien
The anti-dive is what I was seeking. I only used the 6 degree caster blocks to returnb the caster so that is as close to the desired position as I can get using anti-dive. Optimally, I would use 7 degreee blocks for 6 degree caster AND anti-dive. but this is not available. Although it could be an interesting tuning part for an aftermarket parts company - 3, 5, and 7 degree blocks for those that run anti-dive.
I went to the inside position on the rear arm as a result of my Tamiya experiences. The Tamiya car used different shock position front and rear which resulted in the use of the same springs all-around. I never ran "split" springs front and rear with Tamiya so I thought I would try and set up the TC5 so I could do the same thing. That is why I used the green springs all around.
All these changes happened at a point in the event that I did not play with it much more. The car was so good I did not want ot mess with it further. But we have our Nationals next week so I will work on it a bit more and see what happens.
Old 06-11-2008, 05:30 PM   #6149
TeckLancer's Avatar
well guys i figured out what was clicking. it was in the spur i took it apart lube the bearings and put it back togther and it stop clicking. but after that i rolled it without a pinion and stil didnt roll to much futher. so i lube all the bearings and lossened the screws in the back of the top plat, just alittle and it seemed to roll alot futher. after i pulled out my pro 4 just to test to see how much futher it would roll and my hpi seemed to roll much futher then the tc5. so i dont know what to do know. i mean i got the tc5 to roll alot i mean alot further but my pro4 4 seems to roll even further any suggestion ????
Eric Arellano
Old 06-11-2008, 05:35 PM   #6150
TeckLancer's Avatar
also what is a good gear to start with for a cobolt with the stock spur? i was thinking a 26 which will put me at a 6.69 final
Eric Arellano
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
