Old 06-04-2008, 02:40 PM   #6106
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Not sure if this had anything to do with it, maybe you guys in here can tell me, but my brother's (Teck) motor (co27) in his tc5 was found to not have the top teflon/nylon shim (whatever the big brown round one is) when we used it at the JBRL. Would this cause heating issues as hes mentioning?
Only thing i can think of is break the car down and clean and lube all the bearings if the shim thing wasnt an issue...
and eric, check you're spelling foo!
also, and this is also for Teck, could somebody post a setup sheet thats good for low-med traction asphalt with the tc5? It has no ITF stuff if that helps. Thanks.
Eric, read the next few posts! lol
Syber Serulean is offline   Reply With Quote
Old 06-04-2008, 02:42 PM   #6107
Trader Rating: 38 (100%+)
Originally Posted by TeckLancer View Post
do u guys know could bind in the tc5 ? i pretty sure mine isnt but my motor is coming off the track real real hot and i can figure why im running a 6.26 final at a parking lot track and just comes off hot. ive tried everything.
any suggestions?
Have you tried to spin the spur without the motor attached to see if anything is binding? Try it with the wheels turned in each direction. Hope it helps...
or8ital is offline   Reply With Quote
Old 06-04-2008, 02:55 PM   #6108
sonic31's Avatar
here's a pic of the jaad spool ...
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 06-04-2008, 03:06 PM   #6109
TeckLancer's Avatar
Trader Rating: 16 (100%+)
yea it rolls fine just
Eric Arellano
TC5,RC18-b,PRO4,FS,EIGHT-E 2.0,TLT,TF-5,Nitro MT
Panther tires, Speedtech r/c, Murfdogg Motorworks
check oout my forsale thread http://www.rctech.net/forum/r-c-items-sale-trade/401576-wts-b44-b4-losi-8e-hpi-nitro-mt-few-lipos.html
TeckLancer is offline   Reply With Quote
Old 06-04-2008, 03:11 PM   #6110
AE-Reedy
Originally Posted by overflow View Post
Thanks Sean, Left to right is fine, its more of a slight bow upwards front to rear. I am going to look at a few more things tonight to see if i can get it to sit flat without the washers. I think i might bevel out the holes for the screws more so when i tighten, it doesnt pull it towerds center.
Another item one of the guys mentioned to check is to make sure the height of the steering post is not causing an issue. Also bent screws or just bad screws could cause the issue. If you have changed as much stuff as you say maybe just try replacing the screws. Another thing you could try is putting the top deck on up side down with button head screws. This would eliminate the screws heads pulling the bulkheads together.
Sean Cochran is offline   Reply With Quote
Old 06-04-2008, 03:30 PM   #6111
overflow's Avatar
if you are going to be at la mirada on sunday come see me. i will check it out for you and give you a setup. also, mark will probably be there and im sure if you ask him nice he will check the motor for you.
Dennis Vice
[HOTBODIES] [SPEED PASSION]
overflow is offline   Reply With Quote
Old 06-04-2008, 03:35 PM   #6112
geeunit1014's Avatar
Teck, what motor and what size is the track?
syber - this is what i ran for a while, it pushes on entry a bit but its easy to drive.
front solid axle/ rear diff med. tight
silver springs all around
30wt oil
1a arm mounts all around
1a/1 camber link positions w/ .5mm shim under rear ballstud
1a shock mount positons
1a steering link position
no sway bars.
2/2.5 deg camber f/r
0* rear hubs/2mm toe shims
.5 deg toe out front
2mm wheelbase shim fr and rear (those shims in setup sheet positions)
jaco green tires
mazdaspeed 6 body
o-rings under 4 rear screws (try the fronts if you want more steering)
5mm ride hieght all around
4mm uptravel in front/5mm in rear (not the downstop gauge positions)
like i said not the best but its easy to drive. ive since gone to the stock setup from the R kit, and i like that better(turns more), but for a low bite track this may be better
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 06-04-2008, 04:47 PM   #6113
TeckLancer's Avatar
it more of a low med traction parking lot and im running a blue can. runs fine in all my other cars but just runs super hot in the tc5.
Eric Arellano
Old 06-04-2008, 05:17 PM   #6114
Trader Rating: 46 (100%+)
If you use the new washers that they are providing in the TC5R for the top deck you will elminate it on the car. Mine had the same problem and I still ran it. I have since switched my car to the washer setup like the 5R but haven't had a chance to run it yet but the problem went away.
Yeah, i have some on order. I am sure that will take care of it. Just didnt know if others were having the same problem.
do you guys have a part number or info where to get those washers??
thanks
josh short is offline   Reply With Quote
Old 06-04-2008, 06:04 PM   #6115
AE-Reedy
thanks
AE# 89229 they come 10 to a package.
Old 06-04-2008, 06:14 PM   #6116
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Originally Posted by PitNamedGordie View Post
Gordie i dont know if you know this but instead of buying that part ,,, Team Associated has come out with new Cam Holders with more slots to aid in getting the belts a little looser. I would rather run the new cam holders than buy that part. I am sure the cam holders are cheaper too.
Here is the part number for the new cam holders 31184
wallstreet is offline   Reply With Quote
Old 06-04-2008, 06:22 PM   #6117
PartTime's Avatar
We need to know EXACTLY what motor your running. A blue motor doesnt tell us anything.
DK
PartTime is offline   Reply With Quote
Old 06-04-2008, 06:28 PM   #6118
PartTime's Avatar
Ya but, this would make it that much easyer to swap pinions. Its such a pain to regear this car.
DK
Old 06-04-2008, 06:40 PM   #6119
Do we know if these new style cam holders come in the soon to be released TC5R and TC5F kits? And......Do you think the release date of the new kits for mid June (Tower site) is accurate?
By the way all the information on this thread is great. Thanks to all you posters.
Bob
Babalu is offline   Reply With Quote
Old 06-04-2008, 07:31 PM   #6120
blue can you mean co27? my local track is approx 110ft and i run a 6.7 on that motor, which would explain your overheating.
something for those to consider on the exotek cams, by lowering the spur it will open up certian gearing combos, because lowering the spur moves it closer to the motor.
Mike Gee
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
